Need help coding LED and Servo
Good evening.
I am looking to turn on an LED, with a couple second delay, then turn it off. While this is happening, I am also wanting to turn a servo 45 degrees, then return to 0 once the delay is done. Any help would be appreciated. Thanks
    ARDUINO LIGHT SENSOR CONTROLS LED
    By: TheGeekPub.com
    More Arduino Tutorials: https://www.thegeekpub.com/arduino-tutorials/
// constants won't change
const int LIGHT_SENSOR_PIN = A0; // Arduino pin connected to light sensor's  pin
const int LED_PIN          = 3;  // Arduino pin connected to LED's pin
const int ANALOG_THRESHOLD = 500;  // this sets the the threshold for when the LED turns on.
// variables will change:
int analogValue;
  pinMode(LED_PIN, OUTPUT); // set arduino pin to output mode
  analogValue = analogRead(LIGHT_SENSOR_PIN); // read the input on analog pin
  if(analogValue < ANALOG_THRESHOLD)
    digitalWrite(LED_PIN, HIGH); // turn on LED
    digitalWrite(LED_PIN, LOW);  // turn off LED
i'm bored too..
here..
#include <Servo.h>
#define LED_PIN 3
#define SERVO_PIN 10
Servo MyServo;
unsigned long lastAct = 0;
int intervalAct = 2000;
byte pos = 0;
  MyServo.attach(SERVO_PIN);
  MyServo.write(0);
  unsigned long now = millis();
  if (now - lastAct >= intervalAct) {
    lastAct = now;
    digitalWrite(LED_PIN, !digitalRead(LED_PIN));
    if (pos == 0) {
      pos = 45;
      MyServo.write(pos);
      pos = 0;
      MyServo.write(pos);
have fun.. ~q
Is this not the time to mention the posted sketch does not match the description?
The posted sketch has a photo resistor turn an LED on when light is bright and off when light is not bright... and I think that is backwards. My lights turn on in the dark and turn off in the light.
