I need to figure out how to code this piece of code so that it will turn on when it is dark and off when it is light. I was going to use a photoresistor but I don't know what code to use if I want if to turn on in the dark and off in the light. Here is the code that I have so far. I need someone to maybe code this so that this whole thing will turn on in the dark and off when it is light.
const int hot = 87; //set hot parameter
const int cold = 75; //set cold parameter
void setup() { pinMode(A2, INPUT); //sensor pinMode(2, OUTPUT); //bluepinMode(4, OUTPUT); //red Serial.begin(9600); } void loop() { int sensor = analogRead(A2); float voltage = (sensor / 1024.0) * 5.0; float tempC = (voltage - .5) * 100; float tempF = (tempC * 1.8) + 32; Serial.print("temp: "); Serial.print(tempF); if (tempF < cold) { //cold digitalWrite(2, HIGH);digitalWrite(4, LOW); Serial.println(" It's Cold."); } else if (tempF >= hot) { //hot digitalWrite(2, LOW);digitalWrite(4, HIGH); Serial.println(" It's Hot."); }delay(10); }
You understand that code runs once in setup() and runs many times in loop()?
You read stuff like; Topic: How to get the best out of this forum (short version) and Topic: Read this before posting a programming question ... but still declined to put your properly formatted code in code tags, why?
You should post code by using code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
- press Ctrl-T for autoformatting your code
- do a rightclick with the mouse and choose "copy for forum"
- paste clipboard into write-window of a posting
www.google.de/search?as_q=arduino++photoresistor+demo+code
best regards Stefan
Does it really look like that in the iDE ?
lionchipmunkcoder11:
1. This is your hardware setup shown in Fig-1.
Figure-1: Hardware setup of Thermistor circuit.
2. This is your sketch made out of codes you have posted.
if (tempF < cold)
{ //cold
if (tempF >= hot)
{ //hot
delay(10);
Can you please, post the type number of your LDR or post a web link to it? I wish to know its responses (resistance values vs temperatures). At bright light, the resistance is about 500 ohms; at darkness, the resistance is about 200 k.
GolamMostafa:
Hot?
Cold?
Light?
Dark?
LDR?
Thermistor?
tempC?
What is going on here?
TheMemberFormerlyKnownAsAWOL:
Hot?
Cold?
Light?
Dark?
LDR?
Thermistor?
tempC?What is going on here?
I have just re-arranged OP's code; however, I missed the hot and cold parameters which I have entered now in the sketch.
