I’m trying to create a device that will use and lcd display to present a message once a light dependent resistor detects light and control a servo from the push of a button.
My code concerning the servo works just fine but I can’t seem to get my lcd display to work. Here are my error messages:
sketch_mar05a:71: error: ‘lcd’ does not name a type
lcd.begin(16,2);
sketch_mar05a:78: error: expected ‘;’ at end of member declaration
void Update()
sketch_mar05a:80: error: ‘ldrState’ does not name a type
ldrState = digitalRead(ldrPin); //read the digital state of ldrPin with digitalRead() function and store the value in ldrState variable
sketch_mar05a:82: error: expected unqualified-id before ‘{’ token
sketch_mar05a:163: error: expected ‘}’ at end of input
sketch_mar05a:73: error: expected unqualified-id at end of input
const int ldrPin = 7; // light dependent resistor pin
exit status 1
Here’s my code:
#include <Wire.h>
#include <Servo.h>
LiquidCrystal_I2C lcd(0x3F, 16, 2);
class Twist
const int servoPin = 9; // servo pin
Servo servo; // the servo
int pos = 0; // variable to store the servo position
int directionState = 0;
int increment; // increment to move for each interval
int updateInterval; // interval between updates
unsigned long lastUpdate; // last update of position
const int buttonPin = 8; // pushbutton pin
int buttonState = 0;
public:
Twist(int interval)
updateInterval = interval;
increment = 1;
void Attach(int pin)
servo.attach(9);
void Detach()
servo.detach();
void Update()
if((millis() - lastUpdate) > updateInterval) // time to update
lastUpdate = millis();
pos += increment;
buttonState = digitalRead(buttonPin);
if (directionState == 0) {
if (buttonState == HIGH) {
directionState = 1;
for (pos = 20; pos < 180; pos = pos + 1) {
servo.write(pos);
} else if (directionState == 1) {
directionState = 0;
for (pos = 180; pos > 1; pos = pos - 1) {
servo.write(pos);
Twist twist1(15);
class Display
lcd.begin(16,2);
int ldrState; // local variable to hold ldr states
public:
void Update()
if (ldrState == HIGH)
lcd.clear();
lcd.setCursor(0,0); //Start at character 0 on line 0
lcd.print("Open the damn");
lcd.setCursor(0,1); // Start at character 0 on line 1
lcd.print("blinds!");
// scroll 13 positions (string length) to the left
// to move it offscreen left:
for (int positionCounter = 0; positionCounter < 13; positionCounter++) {
// scroll one position left:
lcd.scrollDisplayLeft();
// scroll 29 positions (string length + display length) to the right
// to move it offscreen right:
for (int positionCounter = 0; positionCounter < 29; positionCounter++) {
// scroll one position right:
lcd.scrollDisplayRight();
// scroll 16 positions (display length + string length) to the left
// to move it back to center:
for (int positionCounter = 0; positionCounter < 16; positionCounter++) {
lcd.clear();
for(int i = 0; i< 3; i++)
lcd.backlight();
lcd.noBacklight();
lcd.backlight();
lcd.print("Or else, innocent");
lcd.setCursor(0,1);
lcd.print("plants will die.");
Display display1();
twist1.Attach(9);
twist1.Update();
display1. Update();
void Update()
In any of your other functions, what goes between the ) and the {? Hint: NOTHING. Why did you try to change that here?
You really should define your classes in a header file and implement them in a source file. Then, you’d understand why the class knows nothing about the lcd instance.
Okay, so I’m not entirely sure if I did what you said to but I’m getting this error message now:
/Users/caitlinpeterson/Documents/Arduino/Blinds_Controller/Blinds_Controller.ino:13:19: fatal error: Twist.h: No such file or directory #include “Twist.h”
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
Here’s the modified code:
#ifndef Twist_h
#define Twist_h
#ifndef Display_h
#define Display_h
#include <Servo.h>
#include <Wire.h>
#include "Arduino.h"
#include "Twist.h"
#include "Display.h"
class Twist
public:
Twist(int interval)
increment = 1;
servo.attach(9);
void Detach()
servo.detach();
void Update()
pos += increment;
directionState = 1;
servo.write(pos);
directionState = 0;
servo.write(pos);
Twist twist1(15);
#endif
class Display
lcd.begin();
public:
void Message1()
lcd.clear();
void Message2()
lcd.clear();
lcd.backlight();
lcd.noBacklight();
lcd.backlight();
lcd.setCursor(0,1);
Display diplay1();
#endif
twist1.Attach(9);
twist1.Update();
display1.Message1();
display1.Message2();
I’m not necessarily sure what you mean by including two guards in one file. In addition, I do have four different files. I followed this: Arduino - LibraryTutorial – in attempting to fix my code.
Here’s my error message:
/Users/caitlinpeterson/Documents/Arduino/Blinds_Controller/Blinds_Controller.ino: In function ‘void loop()’:
Blinds_Controller:188: error: ‘display1’ was not declared in this scope
exit status 1
Here’s my current code:
#ifndef Twist_h
#define Twist_h
#include "Twist.h"
#include <Servo.h>
class Twist
public:
Twist(int interval);
void Attach(int pin);
void Detach();
void Update();
#include "Twist.h"
Twist::Twist(int interval)
increment = 1;
void Twist::Attach(int pin)
servo.attach(9);
void Twist::Detach()
servo.detach();
void Twist::Update()
pos += increment;
directionState = 1;
servo.write(pos);
directionState = 0;
servo.write(pos);
#endif
Twist twist1(15);
#include <Servo.h>
#include <Wire.h>
#ifndef Display_h
#define Display_h
class Display
lcd.begin();
public:
void Message1();
void Display::Message1()
lcd.clear();
lcd.clear();
lcd.backlight();
lcd.noBacklight();
lcd.backlight();
lcd.setCursor(0,1);
Display display1();
#endif
twist1.Attach(9);
twist1.Update();
#ifndef Twist_h
#define Twist_h
#include "Twist.h"
#include <Servo.h>
class Twist
public:
void Detach();
void Update();
#endif
#ifndef Display_h
#define Display_h
#include <Wire.h>
class Display
public:
void Message1();
#endif
Here’s Display.cpp:
lcd.begin();
lcd.clear();
lcd.clear();
lcd.backlight();
lcd.noBacklight();
lcd.backlight();
lcd.setCursor(0,1);
lcd.clear();
lcd.backlight();
lcd.noBacklight();
lcd.backlight();
lcd.setCursor(0,1);
New errors:
In file included from /Users/caitlinpeterson/Documents/Arduino/Blinds_Controller/Blinds_Controller.ino:1:0:
Display.h:12: error: ‘lcd’ does not name a type
lcd.begin();
Blinds_Controller:20: error: request for member ‘Message1’ in ‘display1’, which is of non-class type ‘Display()’
exit status 1
#ifndef Twist_h
#define Twist_h
#include <Servo.h>
class Twist
public:
void Detach();
void Update();
#endif
#ifndef Display_h
#define Display_h
#include <Wire.h>
class Display
lcd.begin();
public:
void Message1();
#endif
lcd.begin();
lcd.clear();
lcd.clear();
lcd.backlight();
lcd.noBacklight();
lcd.backlight();
lcd.setCursor(0,1);
lcd.clear();
lcd.backlight();
lcd.noBacklight();
lcd.backlight();
lcd.setCursor(0,1);
I’m having a couple issues with my code. The code should be able to display a message on an lcd when a light dependent resistor senses light and operate a motor via a button push.
lcd.begin();
exit status 1
#ifndef Twist_h
#define Twist_h
#include <Servo.h>
class Twist
public:
void Detach();
void Update();
#endif
#include <Wire.h>
class Display
lcd.begin(16, 2);
public:
void Message1();
#endif
Here’s Display.cpp:
lcd.clear();
lcd.clear();
lcd.backlight();
lcd.noBacklight();
lcd.backlight();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
How long will it take this loop to tell the servo to go to position 179? What will the servo position be when the code tells the servo to go to position 179?
class Display
Why is the lcd instance not a member of the class?
Does that comment provide ANY value? Anyone can see that digitalRead() is used, and that the result is stored in ldrState.
What needs explaining is why an analog device is being read as though it was a digital device.
