Need help for configuring code for multiple alarm with different stepper output and pinmode output using rtc ds1307 attached on arduino uno mega 2560.
What do you mean by 'configuring"?
the code sir
What code?
- DS1307 Time and Alarm memory handling example using the extended DS1307 library for handling alarms in
- the internal free NVRAM of the DS1307
- This example sketch shows how to use the extended DS1307 library. This library adds weekday alarms to the DS1307
- functionality. These alarms are stored in the DS1307 persistent RAM (NVRAM) so that it survives periods without
- power. For that it requires that the DS1307 is powered with an backup battery (e.g. CR2023 coin cell). This sketch
- shows:
- how to get the current time of the DS1307 chip and if not set yet it will set the time
- it shows various example how to set alarms
- in the loop part it shows how to check if there is an alarm that neds to go off.
- note: weekday alarms can only be set at 5 minute resulution, e.g. 8:10 is OK and 8:09 is not
- Circuit:
- see here for a nice istructable that shows how to connect the DS1307 to an Arduino
- http://www.instructables.com/id/Arduino-Real-Time-Clock-DS1307/
- Athor: Milé Buurmeijer
- Version: 0.6
- Date: 26/07/2012
- Version history:
- 0.1 Initial version that contains alarm structure, alarm retreive functionality and alarm triggering
- 0.2 Alarm set quick hack
- 0.3 Setting of alarms debugged
- 0.4 Removed alarmIsSetAddress *
- 0.5 first test of library usage
- 0.6 alarm clear function corrected
- Based on test sketch from the "DS1307new" library by Peter Schmelzer and Oliver Kraus (version 1.21)
#define DEBUG 1
#include <Wire.h> // for some strange reasons, Wire.h must be included here
#include "DS1307new.h" // extension to new DS1307 Arduino library that includes weekday alarms
#ifdef DEBUG
// init serial communication
while(!Serial) {} // for Arduino Leonardo
#endif
// uncomment line below if you explicitly want to set the time
//RTC.setRAM(timeIsSetAddress, (uint8_t *)&aspectIsNotSetToken, sizeof(uint8_t));
// check if flagged that time was already set in RTC
if (RTC.isTimeSet()) {
// OK RTCandA was properly set, so let get the time
RTC.getTime();
// only do this once to set the RTC
// this routine writes the token to the RTC NV-RAM memory for future reference
RTC.setDateTimeRTC();
//examples how to set alarms [alarms are defined at at 5 minute resolution]
RTC.clearAlarmNvramMemory(); // clears the DS1307 internal NVRAM to hold the alarms
RTC.listNvramMemory(); // print out the NVRAM memory values
// set alarm Mondays at 5:25,
// first parameter is day of the week (sunday = 0, monday = 1, ..., saturday = 6)
// second parameter is the hour in 24h style
// last parameter is the minutes in 5 minute resolution, i.e. 0, 5, 10, 15, 20, 25, 30, 35, 40, 45, 50, 55
RTC.setAlarm( 1, 5, 25);
RTC.setAlarm( 6, 0, 30); // set alarm Tuesdays at 16:05
RTC.setAlarm( 3, 12, 10); // aet alarm Wednesday at 12:10
RTC.setAlarm( 4, 11, 15); // set alarm Thursdays at 11:25
RTC.clearAlarm( 4); // clear alarm on Thursday
RTC.setAlarm ( 6, 20, 0); // set alarm Saturdays at 20:00
#ifdef DEBUG
Serial.println("DS1307 time and alarm memory module");
Serial.println("Format is "hh:mm:ss dd-mm-yyyy DDD"");
uint8_t CEST = RTC.isCETSummerTime();
Serial.print("isCETSummerTime=");
Serial.println(CEST, DEC);
#endif
- main loop of the sketch
if (RTC.setAlarm() {
pinMode (2,OUTPUT);
} else{
pinMode (3,OUTPUT);
delay(10000); // wait 10 seconds
You haven't described the hardware adequately to enable us to offer much help.
Please remember to use code tags when posting code
sorry I am new here but my problem is I have a project research development of medicine dispenser with a multiple stepper motor to dispense pill in specific time and day of the week
on the example code i have it can print on the serial monitor that alarm is passed but what I need is an output to a pin and a stepper motor.
