Need help making ccsniffer project work
Hello there, this is my first post, and although this is not really the right section, it's the only one where I'm allowed to post, so here goes:
I am trying to make this work: GitHub - studiofuga/ccSniffer: A sniffer for cc1101 chip.
But the source code is a .cpp file, and when I paste it into the sketch, I get a whole lot of errors, so I'm kind of stuck, since my knowledge of C++ and Arduino is rather minimal.
I'm wondering why somebody would share a project, while it's incomplete or incompatible.
Here's a snippet of the errors I get:
In file included from C:\snif\SRC\sniffer\main.cpp:5:0:
C:\snif\SRC\sniffer\RadioLib.h:75:4: warning: #warning "Low-end platform detected, stability issues are likely!" [-Wcpp]
And the list goes on and on.
I have copied the contents of main.cpp into the sketch window, and as you can see, there is a reference to the main.cpp file, so my best guess is that I started out the wrong way, but what is the right way, I wonder.
Thanks in advance for your help, and also the best holiday wishes!
Oh, and here's the entire main.cpp:
#include <Arduino.h>
#include "cc1101.h"
#include "PacketQueue.h"
#include "SerialHandler.h"
#include "radiolib.h"
#if defined (BOARD_HUZZAH32)
CC1101Tranceiver radio(25, 39, 34);
#elif defined (BOARD_NANO)
CC1101Tranceiver radio(10, 3, 2);
#endif
using UnprocessedQueue = RawPacketsQueue<4,64>;
UnprocessedQueue unprocessedQueue;
using Queue = PacketsQueue<4,64>;
Queue queue;
SerialHandler serial;
void irqRead(void);
void irqSent(void);
volatile int numSent = 0;
volatile int numTimeout = 0;
volatile int numRecvIrq = 0;
void PrintHex8(const uint8_t *data, uint8_t length, char const *separator) // prints 8-bit data in hex with leading zeroes
    for (int i = 0; i < length; i++) {
        if (data[i] < 0x10) { Serial.print("0"); }
        Serial.print(data[i], HEX);
        if (separator != nullptr) {
            Serial.print(" ");
uint8_t nibble(char n) {
    if (n >= '0' && n <= '9')
        return n - '0';
    if (n >= 'A' && n <= 'F')
        return n - 'A' + 10;
    if (n >= 'a' && n <= 'f')
        return n - 'a' + 10;
    return 0;
size_t hexToBin(const char *hex, uint8_t *bin, size_t maxbinlen) {
    size_t len = 0;
    while (true) {
        if (*hex == '\0') {
            return len;
        *bin = (nibble(*hex) << 4);
        ++hex;
        if (*hex == '\0') {
            return len;
        *bin = *bin | (nibble(*hex));
        ++hex;
        ++len;
        ++bin;
        if (len == maxbinlen)
            return len;
    serial.init();
    Serial.println(F("+ccSniffer"));
    Serial.print(F("+CC1101 Initializing ... "));
    auto state = radio.initialize();
    if (state == 0) {
        Serial.println(F("success!"));
        Serial.print(F("failed, code "));
        Serial.println(state);
        while (true) {}
    auto v = radio.getChipVersion();
    Serial.print("+Chip version: ");
    Serial.println(v);
    radio.setFrequency(868.3);
    radio.setBitrate(38.383);
    radio.setDeviation(20.63);
    radio.setReceiverBW(101.56);
    radio.setOutputPower(10);
    radio.setModulation(CC1101Tranceiver::Modulation::GFSK);
    radio.setSyncType(CC1101Tranceiver::SyncType::Sync30_32);
    radio.setPreambleLength(CC1101Tranceiver::PreambleTypes::Bytes4);
    radio.setSyncWord(0x2d, 0xc5);
    radio.enableCRC();
    radio.enableWhitening();
    radio.SPIsetRegValue(CC1101_REG_FSCTRL1, 0x06, 4, 0);
    radio.SPIsetRegValue(CC1101_REG_FSCTRL0, 0x05, 7, 0);
    radio.setReceiveHandler(irqRead, CC1101Tranceiver::SignalDirection::Rising);
    radio.setTransmitHandler(irqSent, CC1101Tranceiver::SignalDirection::Rising);
    radio.receive();
    Serial.println(F("+CC1101 Registers dump:"));
    for (int i = 0; i < 0x30; ++i) {
        if ((i%8) == 0)
            Serial.print("+");
        uint8_t value = radio.SPIreadRegister(i);
        PrintHex8(&value, 1, " ");
        if (i % 8 == 7) {
    Serial.println("+READY");
void irqSent(void)
    ++numSent;
void irqRead(void)
    ++numRecvIrq;
    size_t retries = 0;
    while(true) {
        if (++retries > 100) {
            // timeout
            ++numTimeout;
            radio.receive();
            return;
        auto fifo = radio.SPIgetRegValue(CC1101_REG_RXBYTES, 6, 0);
        if (fifo > 0) break;
    uint8_t str[128];
    auto status = radio.read(str, 128);
    if (status.len > 0 && status.errc != ReadErrCode::NoData) {
        unprocessedQueue.push(str, status.len);
    radio.receive();
void handleUnprocessed()
    int y= 0;
    do {
        noInterrupts();
        if (unprocessedQueue.empty()) {
            interrupts();
            if (y>0) {
                Serial.print(y);
                Serial.print(" ");
                Serial.println(queue.empty());
            return;
        uint8_t raw[UnprocessedQueue::MAX_PACKET_SIZE];
        uint8_t len = unprocessedQueue.pop(raw, UnprocessedQueue::MAX_PACKET_SIZE);
        interrupts();
        Queue::PacketType packet;
        packet.setRssi(raw[len-2]);
        packet.setLqi(raw[len-1] & 0x7f);
        packet.setStatus((raw[len-1] & 0x80) ? PacketOK : CRCError);
        packet.rawCopyFrom(raw+1, len-3);
        queue.push(packet);
        ++y;
    } while (true);
void handleReceived()
    if (!queue.empty()) {
        if (queue.pop(packet)) {
            Serial.print(F("*"));
            Serial.print(millis());
            Serial.print(F(","));
            Serial.print(packet.getRssi());
            Serial.print(packet.getLqi());
            PrintHex8(packet.data(), packet.len(), nullptr);
            if (packet.getStatus() == CRCError) {
                Serial.print(",BADCRC");
int cacheNumSent = -1, cachedNumTo = -1;
int cachedNumIrq = -1;
    if (cachedNumTo != numTimeout) {
        Serial.println("+CC1101 Timeout");
        cachedNumTo = numTimeout;
    if (cachedNumIrq != numRecvIrq) {
        Serial.print("+CC1101 IRQ:");
        Serial.println(numRecvIrq);
        cachedNumIrq = numRecvIrq;
    if (cacheNumSent != numSent) {
        Serial.print("+CC1101 ");
        Serial.print(numSent);
        Serial.println(" Preambles Recv/Sent");
        cacheNumSent = numSent;
    if (serial.lineAvailable()) {
        static char buf[128];
        auto sz = serial.copyLine(buf,128);
        buf[sz] = '\0';
//        Serial.print("Got ");
//        Serial.print(sz);
//        Serial.print(": ");
//        Serial.println(buf);
        static uint8_t pkt[64];
        auto pktlen = hexToBin(buf,pkt,64);
        radio.transmit(pkt, pktlen);
//        Serial.print("Sent ");
//        Serial.print(sn);
//        PrintHex8(pkt, pktlen, " ");
    handleUnprocessed();
    handleReceived();
Post this list, in code tags, just like the sketch.
Hi @h3nk ,
Welcome to the forum..
that's a warning not an error..
maybe the board you are using is not proper..
code looks like it was developed in VS but should be compatible..
what board you got??
good luck.. ~q
Yeah, here's the full list of misery:
Arduino: 1.8.18 (Windows 7), Board: "Arduino Duemilanove or Diecimila, ATmega328P"
C:\arduino-1.8.18\arduino-builder -dump-prefs -logger=machine -hardware C:\arduino-1.8.18\hardware -tools C:\arduino-1.8.18\tools-builder -tools C:\arduino-1.8.18\hardware\tools\avr -built-in-libraries C:\arduino-1.8.18\libraries -libraries C:\Users\Hank\Documents\Arduino\libraries -fqbn=arduino:avr:diecimila:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10818 -build-path C:\Users\Hank\AppData\Local\Temp\arduino_build_82520 -warnings=none -build-cache C:\Users\Hank\AppData\Local\Temp\arduino_cache_922814 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\arduino-1.8.18\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\arduino-1.8.18\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\arduino-1.8.18\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\arduino-1.8.18\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\arduino-1.8.18\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\arduino-1.8.18\hardware\tools\avr -verbose C:\snif\SRC\sniffer\sniffer.ino
C:\arduino-1.8.18\arduino-builder -compile -logger=machine -hardware C:\arduino-1.8.18\hardware -tools C:\arduino-1.8.18\tools-builder -tools C:\arduino-1.8.18\hardware\tools\avr -built-in-libraries C:\arduino-1.8.18\libraries -libraries C:\Users\Hank\Documents\Arduino\libraries -fqbn=arduino:avr:diecimila:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10818 -build-path C:\Users\Hank\AppData\Local\Temp\arduino_build_82520 -warnings=none -build-cache C:\Users\Hank\AppData\Local\Temp\arduino_cache_922814 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\arduino-1.8.18\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\arduino-1.8.18\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\arduino-1.8.18\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\arduino-1.8.18\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\arduino-1.8.18\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\arduino-1.8.18\hardware\tools\avr -verbose C:\snif\SRC\sniffer\sniffer.ino
Using board 'diecimila' from platform in folder: C:\arduino-1.8.18\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\arduino-1.8.18\hardware\arduino\avr
Detecting libraries used...
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\sniffer.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\sniffer.ino.cpp" -o nul
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\ArduinoHal.cpp" -o nul
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
  -> candidates: [EEPROM@2.0]
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\ArduinoHal.cpp" -o nul
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\Hal.cpp" -o nul
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\Module.cpp" -o nul
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\SerialHandler.cpp" -o nul
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\cc1101.cpp" -o nul
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\main.cpp" -o nul
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o nul
Generating function prototypes...
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\sniffer.ino.cpp" -o "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\arduino-1.8.18\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\ArduinoHal.cpp" -o "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\ArduinoHal.cpp.o"
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\Hal.cpp" -o "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\Hal.cpp.o"
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\Module.cpp" -o "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\Module.cpp.o"
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\SerialHandler.cpp" -o "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\SerialHandler.cpp.o"
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\cc1101.cpp" -o "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\cc1101.cpp.o"
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\main.cpp" -o "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\main.cpp.o"
"C:\\arduino-1.8.18\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\arduino-1.8.18\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\sniffer.ino.cpp" -o "C:\\Users\\Hank\\AppData\\Local\\Temp\\arduino_build_82520\\sketch\\sniffer.ino.cpp.o"
C:\snif\SRC\sniffer\main.cpp: In function 'void setup()':
main.cpp:76:18: error: 'radio' was not declared in this scope
C:\snif\SRC\sniffer\main.cpp:76:18: note: suggested alternative: 'random'
                  random
C:\snif\SRC\sniffer\main.cpp: In function 'void irqRead()':
main.cpp:137:13: error: 'radio' was not declared in this scope
             radio.receive();
C:\snif\SRC\sniffer\main.cpp:137:13: note: suggested alternative: 'random'
             radio.receive();
             random
main.cpp:140:21: error: 'radio' was not declared in this scope
C:\snif\SRC\sniffer\main.cpp:140:21: note: suggested alternative: 'random'
                     random
main.cpp:145:19: error: 'radio' was not declared in this scope
C:\snif\SRC\sniffer\main.cpp:145:19: note: suggested alternative: 'random'
                   random
C:\snif\SRC\sniffer\main.cpp: In function 'void loop()':
main.cpp:248:9: error: 'radio' was not declared in this scope
C:\snif\SRC\sniffer\main.cpp:248:9: note: suggested alternative: 'random'
         random
C:\snif\SRC\sniffer\sniffer.ino: In function 'void irqRead()':
sniffer:141:9: error: 'PacketQueueT' has not been declared
         PacketQueueT ::PacketT packet;
sniffer:143:13: error: 'packet' was not declared in this scope
             packet.setStatus(CRCError);
C:\snif\SRC\sniffer\sniffer.ino:143:13: note: suggested alternative: 'Packet'
             Packet
sniffer:144:9: error: 'packet' was not declared in this scope
         packet.setRssi(status.rssi);
C:\snif\SRC\sniffer\sniffer.ino:144:9: note: suggested alternative: 'Packet'
         Packet
sniffer:144:31: error: 'struct ReadStatus' has no member named 'rssi'
sniffer:145:30: error: 'struct ReadStatus' has no member named 'lqi'
         packet.setLqi(status.lqi);
C:\snif\SRC\sniffer\sniffer.ino: In function 'void handleReceived()':
sniffer:177:9: error: 'PacketQueueT' has not been declared
sniffer:178:33: error: 'packet' was not declared in this scope
         uint8_t len = queue.pop(packet);
C:\snif\SRC\sniffer\sniffer.ino:178:33: note: suggested alternative: 'Packet'
                                 Packet
Using library SPI at version 1.0 in folder: C:\arduino-1.8.18\hardware\arduino\avr\libraries\SPI
Using library EEPROM at version 2.0 in folder: C:\arduino-1.8.18\hardware\arduino\avr\libraries\EEPROM
exit status 1
The board is labeled as NANO, but it's just a run off the mill 328P clone, which works as a Duemilanove, and it works a treat with simple sketches, so the board is not the issue, exactly the same board is also used in the project.
And it's written by an Italian, and I see no contact info @ github, else I would have contacted him directly.
I think that the real issue is that this code is not really compatible with Arduino, but how to fix it, that's the big question!
From the error log:
Reposting error log without excess crlf
Compiling sketch...
                  random
             radio.receive();
             radio.receive();
             random
                     random
                   random
         random
             Packet
         Packet
                                 Packet
exit status 1
This seems to have failed on both conditions...
Check my previous post.
your good board is not getting selected then..
#endif
or radio would be declared..
that stinks, might want to abort..
where's this ino at, don't see it in the git..
i was thinking you my want to rename main.cpp to folder name .ino, or sniffer.ino and try that with Arduino IDE..
sorry.. ~q
The source code is several many files, all of which need to be part of your project.
Please tell us you made a tab for every file in the source code folder from the repository and copied each file's contents into the appropriate tab.
You can use an empty nameOfProject.ino file as the first tab. If you have all the other files, it should build successfully in the IDE.
Or not, for some other reasons. :expressionless:
HTH
a7
C programming is like LEGU (tm).
If you want to use red blocks, you have to buy and have red blocks nearby.
If you’re using green wheels, having them at school is no help. You need them right here on the same table.
The blocks in a large project rarely stand by themselves… you need to have a baseboard to hold them in alignment.
