I need to hav 3 speed settings for the motor (low, medium, high)
The motor also needs a on/off button (preferably a slow start mode of some sort)
The actuator needs to have a up/down button
The brake function on the motor would have to be operated with a limit switch
And one final switch for all power off.
I know this is a lot, but I would really appreciate any help or advice given.
Please ask if more info is required.
The actuator is a candidate for relay control, simplest, but make sure the relay is chunky and
can handle large currents at DC (the stall current will be higher than the nominal full load
current of 3A, note).
For variable speed for the motor a full H-bridge is needed (or half-H-bridge if unidirectional,
or even a single switching device. However give up on the 3 speeds only idea, you need to
ramp-up the speed between the nominal levels smoothly if you want to keep the currents
sensible, these large motors will have stall currents in the 100's of A range perhaps. Ramping
up the speed will allow the motor to reach speed without pulling unduely high currents.
You still need a big motor driver that can handle large currents and has over-current cutout
I think - although the nominal current is perhaps 15A it will just rise and rise if the motor is
overloaded/stalled, the full stall current can be determined by measuring the motor's
resistance and calculating I = V/R.
