Need help to read usb mouse readings from pico
we are working on a project where our bot moves using the values from the (specifically) usb mouse (kind of like pid control) i tried building an usb host .uf2 file using pico-examples/usb/host/host_cdc_msc_hid at master · raspberrypi/pico-examples · GitHub
but when i conected the wires to any of the gpios it didnt work because USB is a high-speed differential protocol that needs a host controller or a USB PHY (or a proper software PIO-USB implementation).
if any of you have done this kind of thing please can you give some advice?
I moved your topic to an appropriate forum category @karuto12.
In the future, when creating a topic please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
What does that mean?
I am not able to understand your word salad. BTW, that is a pre-req skill to be a programmer. I suggest you start with a library example and build from there.
KISS, just get the mouse working, forget the rest then package it as a module to be used anywhere.
Most people would plug a USB mouse into a USB connector. There is only one on the PICO, so that might be a good choice.
Otherwise, try following a USB host example with wiring instructions. The one you linked doesn't seem to have any.
USB host can be done using the rp2040 PIO controller.
Adafruit has a board with USB type A connector and Arduino TinyUSB lib with examples. Or you can try wiring up a type A connector to your board.
According to what I understood from gpt, usb communication works at high speed without acknowledgement so gpios have to be at exact sync to decod it but gpios are not build for that, ig
Trying that only. My plan was to use two Pico one to get mouse movements and the other for controlling the bot. To make it modular.
But the issue is I did not want to use the usb port on Pico but use gpios. But if no other options I would have to use the usb port only.
ChatGPT? I've done projects with the Pico using USB host mode. I can say with some confidence that ChatGPT doesn't know what it's talking about.
And adding a second Pico to the mix will only add unnecessary complexity that you are unlikely to overcome.
But in host mode how can I communicate with pico, because now I cannot use the usb port, unless I use UART, so I wanted some other pico or Arduino UNO to do UART with the pico-with-mouse and the other microcontroller to talk to my laptop
But, in theory, the USB Host code you linked to does it anyway, because it has a near-magic "pio" interface capable of operating at the speeds required.
(although, mice are typically "low speed" peripherals, so the speed isn't even that high.)
I don't know a lot about it, other than that it is really is supposed to work.
You will probably need the Philhower pico core, rather than the Arduino one.
I was able to build host_hid (bare minimum), but I cannot confirm its working because I am not sure if I can use the pico-usb-port or better gpios,
Can you look into pico-examples/usb/host/host_hid at master · kalikaruto/pico-examples · GitHub, this is supposed to work but I cannot test untill I connect the mouse somehow and do some rx/tx communication
I have normal pico
I am going to connect the mouse using otg and then do rx/tx communication, if you have any suggestions please let me know
not sure what you are attempting to do? e.g. connect a mouse to a RP2040 using OTG HOST
using the Pico-PIO-USB library referenced by @customcontroller in post 6 I can use a RPi Pico RP2040 to read the mouse ID information etc
// RPi Pico RP2040 USB OTG Host device_info
// library https://github.com/sekigon-gonnoc/Pico-PIO-USB/tree/main
// File>Examples>Pico-PIO-USB>device_info
// USB OTG connections GPIO2 D+ GPIO3 D- GND and 5V
 Adafruit invests time and resources providing this open source code,
 please support Adafruit and open-source hardware by purchasing
 products from Adafruit!
 MIT license, check LICENSE for more information
 Copyright (c) 2019 Ha Thach for Adafruit Industries
 All text above, and the splash screen below must be included in
 any redistribution
// pio-usb is required for rp2040 host
#include "pio_usb.h"
#define HOST_PIN_DP   2   // Pin used as D+ for host, D- = D+ + 1
#include "Adafruit_TinyUSB.h"
#define LANGUAGE_ID 0x0409  // English
// USB Host object
Adafruit_USBH_Host USBHost;
// holding device descriptor
tusb_desc_device_t desc_device;
// the setup function runs once when you press reset or power the board
  Serial1.begin(115200);
  delay(2000);
  //while ( !Serial ) delay(10);   // wait for native usb
  Serial.println("TinyUSB Dual Device Info Example");
// core1's setup
void setup1() {
  Serial.println("Core1 setup to run TinyUSB host with pio-usb");
  // Check for CPU frequency, must be multiple of 120Mhz for bit-banging USB
  uint32_t cpu_hz = clock_get_hz(clk_sys);
  if ( cpu_hz != 120000000UL && cpu_hz != 240000000UL ) {
    Serial.printf("Error: CPU Clock = %u, PIO USB require CPU clock must be multiple of 120 Mhz\r\n", cpu_hz);
    Serial.printf("Change your CPU Clock to either 120 or 240 Mhz in Menu->CPU Speed \r\n", cpu_hz);
    while(1) delay(1);
  pio_usb_configuration_t pio_cfg = PIO_USB_DEFAULT_CONFIG;
  pio_cfg.pin_dp = HOST_PIN_DP;
 #if defined(ARDUINO_RASPBERRY_PI_PICO_W)
  /* https://github.com/sekigon-gonnoc/Pico-PIO-USB/issues/46 */
  pio_cfg.sm_tx      = 3;
  pio_cfg.sm_rx      = 2;
  pio_cfg.sm_eop     = 3;
  pio_cfg.pio_rx_num = 0;
  pio_cfg.pio_tx_num = 1;
  pio_cfg.tx_ch      = 9;
 #endif /* ARDUINO_RASPBERRY_PI_PICO_W */
  USBHost.configure_pio_usb(1, &pio_cfg);
  // run host stack on controller (rhport) 1
  // Note: For rp2040 pico-pio-usb, calling USBHost.begin() on core1 will have most of the
  // host bit-banging processing works done in core1 to free up core0 for other works
  USBHost.begin(1);
// core1's loop
void loop1()
  USBHost.task();
// TinyUSB Host callbacks
// Invoked when device is mounted (configured)
void tuh_mount_cb (uint8_t daddr)
  Serial.printf("Device attached, address = %d\r\n", daddr);
  // Get Device Descriptor
  tuh_descriptor_get_device(daddr, &desc_device, 18, print_device_descriptor, 0);
/// Invoked when device is unmounted (bus reset/unplugged)
void tuh_umount_cb(uint8_t daddr)
  Serial.printf("Device removed, address = %d\r\n", daddr);
void print_device_descriptor(tuh_xfer_t* xfer)
  if ( XFER_RESULT_SUCCESS != xfer->result )
    Serial.printf("Failed to get device descriptor\r\n");
    return;
  uint8_t const daddr = xfer->daddr;
  Serial.printf("Device %u: ID %04x:%04x\r\n", daddr, desc_device.idVendor, desc_device.idProduct);
  Serial.printf("Device Descriptor:\r\n");
  Serial.printf("  bLength             %u\r\n"     , desc_device.bLength);
  Serial.printf("  bDescriptorType     %u\r\n"     , desc_device.bDescriptorType);
  Serial.printf("  bcdUSB              %04x\r\n"   , desc_device.bcdUSB);
  Serial.printf("  bDeviceClass        %u\r\n"     , desc_device.bDeviceClass);
  Serial.printf("  bDeviceSubClass     %u\r\n"     , desc_device.bDeviceSubClass);
  Serial.printf("  bDeviceProtocol     %u\r\n"     , desc_device.bDeviceProtocol);
  Serial.printf("  bMaxPacketSize0     %u\r\n"     , desc_device.bMaxPacketSize0);
  Serial.printf("  idVendor            0x%04x\r\n" , desc_device.idVendor);
  Serial.printf("  idProduct           0x%04x\r\n" , desc_device.idProduct);
  Serial.printf("  bcdDevice           %04x\r\n"   , desc_device.bcdDevice);
  // Get String descriptor using Sync API
  uint16_t temp_buf[128];
  Serial.printf("  iManufacturer       %u     "     , desc_device.iManufacturer);
  if (XFER_RESULT_SUCCESS == tuh_descriptor_get_manufacturer_string_sync(daddr, LANGUAGE_ID, temp_buf, sizeof(temp_buf)) )
    print_utf16(temp_buf, TU_ARRAY_SIZE(temp_buf));
  Serial.printf("\r\n");
  Serial.printf("  iProduct            %u     "     , desc_device.iProduct);
  if (XFER_RESULT_SUCCESS == tuh_descriptor_get_product_string_sync(daddr, LANGUAGE_ID, temp_buf, sizeof(temp_buf)))
  Serial.printf("  iSerialNumber       %u     "     , desc_device.iSerialNumber);
  if (XFER_RESULT_SUCCESS == tuh_descriptor_get_serial_string_sync(daddr, LANGUAGE_ID, temp_buf, sizeof(temp_buf)))
  Serial.printf("  bNumConfigurations  %u\r\n"     , desc_device.bNumConfigurations);
// String Descriptor Helper
static void _convert_utf16le_to_utf8(const uint16_t *utf16, size_t utf16_len, uint8_t *utf8, size_t utf8_len) {
  // TODO: Check for runover.
  (void)utf8_len;
  // Get the UTF-16 length out of the data itself.
  for (size_t i = 0; i < utf16_len; i++) {
    uint16_t chr = utf16[i];
    if (chr < 0x80) {
      *utf8++ = chr & 0xff;
    } else if (chr < 0x800) {
      *utf8++ = (uint8_t)(0xC0 | (chr >> 6 & 0x1F));
      *utf8++ = (uint8_t)(0x80 | (chr >> 0 & 0x3F));
      // TODO: Verify surrogate.
      *utf8++ = (uint8_t)(0xE0 | (chr >> 12 & 0x0F));
      *utf8++ = (uint8_t)(0x80 | (chr >> 6 & 0x3F));
    // TODO: Handle UTF-16 code points that take two entries.
// Count how many bytes a utf-16-le encoded string will take in utf-8.
static int _count_utf8_bytes(const uint16_t *buf, size_t len) {
  size_t total_bytes = 0;
  for (size_t i = 0; i < len; i++) {
    uint16_t chr = buf[i];
    if (chr < 0x80) {
      total_bytes += 1;
      total_bytes += 2;
      total_bytes += 3;
  return total_bytes;
static void print_utf16(uint16_t *temp_buf, size_t buf_len) {
  size_t utf16_len = ((temp_buf[0] & 0xff) - 2) / sizeof(uint16_t);
  size_t utf8_len = _count_utf8_bytes(temp_buf + 1, utf16_len);
  _convert_utf16le_to_utf8(temp_buf + 1, utf16_len, (uint8_t *) temp_buf, sizeof(uint16_t) * buf_len);
  ((uint8_t*) temp_buf)[utf8_len] = '\0';
  Serial.printf((char*)temp_buf);
serial monitor displays
Device 1: ID 045e:00a4
Device Descriptor:
  bLength             18
  bDescriptorType     1
  bcdUSB              0110
  bDeviceClass        0
  bDeviceSubClass     0
  bDeviceProtocol     0
  bMaxPacketSize0     8
  idVendor            0x045e
  idProduct           0x00a4
  bcdDevice           0001
  iManufacturer       1     Microsoft
  iProduct            2     Microsoft(R) Compact Optical Mouse
  iSerialNumber       0
  bNumConfigurations  1
EDIT: also have a look at Using a Mouse with USB Host
NOTE: for Adafruit TinyUSB library USB D+ GPIO16 D- GPIO17
