Need help understanding error message & cause
I have created two sketches for the Pro Micro, one sends media control messages to VLC Player over USB while the other sends page-up and page-down commands to MS Word over USB. They both verify and work as designed. The problem occurs when I combine them into one sketch for the Pro Micro where they share a 6 button foot-switch and USB connection.
When I try to verify the sketch I get the error message as follows.
Arduino: 1.8.13 (Windows 7), Board: "SparkFun Pro Micro, ATmega32U4 (5V, 16 MHz)"
In file included from c:\users\mac\documents\arduino\libraries\hid-project\src\hid-apis\KeyboardAPI.h:29:0,
from c:\users\mac\documents\arduino\libraries\hid-project\src\hid-apis\defaultkeyboardapi.h:27,
from C:\Users\mac\Documents\Arduino\libraries\HID-Project\src/SingleReport/BootKeyboard.h:30,
from C:\Users\mac\Documents\Arduino\libraries\HID-Project\src/HID-Project.h:50,
from F:\Technical\Arduino\page_media_control_A\page_media_control_A.ino:6:
c:\users\mac\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:54:21: note: #pragma message: Using default ASCII layout for keyboard modules
#pragma message "Using default ASCII layout for keyboard modules"
In file included from F:\Technical\Arduino\page_media_control_A\page_media_control_A.ino:5:0:
C:\Users\mac\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:54:27: error: expected identifier before numeric constant
#define KEY_RETURN 0xB0
c:\users\mac\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:103:5: note: in expansion of macro 'KEY_RETURN'
KEY_RETURN = 40, // Alias
C:\Users\mac\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:54:27: error: expected '}' before numeric constant
Multiple libraries were found for "Keyboard.h"
Used: C:\Users\mac\Documents\Arduino\libraries\Keyboard
Not used: C:\Program Files (x86)\Arduino\libraries\Keyboard
C:\Users\mac\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:54:27: error: expected unqualified-id before numeric constant
c:\users\mac\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:521:1: error: expected declaration before '}' token
exit status 1
Error compiling for board SparkFun Pro Micro.
option enabled in File -> Preferences.
I do get the pragma message when verifying the media control sketch, but it seems to be informational only as the sketch verifies and runs properly. Something about having the HID-Project and Keyboard libraries together in one sketch causes a problem that causes the message about duplicate Keyboard libraries that does not occur when the page control sketch doesn't contain the media control statements. Code follows.
// page_media_control_A
// Mark Chambers 8/27/2023
// for Pro Micro
#include <Keyboard.h>
#include <HID-Project.h>
// constants won't change
const int pgup = 2;
const int pgdn = 3;
const int play = 4;
const int halt = 5;
const int rew = 6;
const int fwd = 7;
// variables will change
int pgupState;             // the current reading from the input pins
int pgdnState;
int playState;
int haltState;
int rewState;
int fwdState;
int lastPgupState = HIGH;  // the previous reading from the input pins
int lastPgdnState = HIGH;
int lastPlayState = HIGH;
int lastHaltState = HIGH;
int lastRewState = HIGH;
int lastFwdState = HIGH;
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
  pinMode(pgup, INPUT_PULLUP);
  pinMode(pgdn, INPUT_PULLUP);
  pinMode(play, INPUT_PULLUP);
  pinMode(halt, INPUT_PULLUP);
  pinMode(rew, INPUT_PULLUP);
  pinMode(fwd, INPUT_PULLUP);
  Keyboard.begin();
  Consumer.begin();
  // read the state of the page up switch into a local variable:
  int readingPgup = digitalRead(pgup);
  // If the page up switch state changed, due to noise or pressing:
  if (readingPgup != lastPgupState) {
    // reset the debounce timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer than the debounce
    // delay, so take it as the actual current state:
    // if the button state has changed:
    if (readingPgup != pgupState) {
      pgupState = readingPgup;
      // only send page up if the new button state is LOW
      if (pgupState == LOW) {
         Keyboard.write(0xD3);  // page up, 0xD3, 211
   // read the state of the page down switch into a local variable:
  int readingPgdn = digitalRead(pgdn);
  // If the page down switch state changed, due to noise or pressing:
  if (readingPgdn != lastPgdnState) {
    if (readingPgdn != pgdnState) {
      pgdnState = readingPgdn;
      // only send page down if the new button state is LOW
      if (pgdnState == LOW) {
         Keyboard.write(0xD6);  // page down, 0xD6, 214
  // read the state of the play switch into a local variable:
  int readingPlay = digitalRead(play);
  // If the play switch state changed, due to noise or pressing:
  if (readingPlay != lastPlayState) {
    if (readingPlay != playState) {
      playState = readingPlay;
      // only send play if the new button state is LOW
      if (playState == LOW) {
        Consumer.write(MEDIA_PLAY_PAUSE);
  // read the state of the stop switch into a local variable:
  int readingHalt = digitalRead(halt);
  // If the stop switch state changed, due to noise or pressing:
  if (readingHalt != lastHaltState) {
    if (readingHalt != haltState) {
      haltState = readingHalt;
      // only send stop if the new button state is LOW
      if (haltState == LOW) {
        Consumer.write(MEDIA_STOP);
  // read the state of the jump back switch into a local variable:
  int readingRew = digitalRead(rew);
  // If the jump back switch state changed, due to noise or pressing:
  if (readingRew != lastRewState) {
    if (readingRew != rewState) {
      rewState = readingRew;
      // only send jump back if the new button state is LOW
      if (rewState == LOW) {
        Consumer.write(MEDIA_PREVIOUS);
    // read the state of the jump forward switch into a local variable:
  int readingFwd = digitalRead(fwd);
  // If the jump forward switch state changed, due to noise or pressing:
  if (readingFwd != lastFwdState) {
    if (readingFwd != fwdState) {
      fwdState = readingFwd;
      // only send jump forward if the new button state is LOW
      if (fwdState == LOW) {
        Consumer.write(MEDIA_NEXT);
  // save the reading. Next time through the loop, it'll be the lastButtonState:
  lastPgupState = readingPgup;
  lastPgdnState = readingPgdn;
  lastPlayState = readingPlay;
  lastHaltState = readingHalt;
  lastRewState = readingRew;
  lastFwdState = readingFwd;
Any guidance you can provide will be much appreciated.
Thanks, Mark
HID-Project replaces the standard Keyboard library. Don't include both.
This tells you in which file the error occured and what the line and columm is
line 521 columm 1
If you haven't modified this file
There is missing a opening or closing curly brace or a round parenthesis somewhere.
Two ways to correct it:
carefully going through your code line by line checking the opening/closing braces / parenthesis
or
combining the two code completely new
best regards Stefan
Thank you very much for your help.
