I am currently working on a project that will utilize this camera:
The code that sparkfun provides is a bit outdated, so after looking a while for updates I currently have the code below. The problem with this however is that it seems as though nothing is happening, and mySerial.available() always ends up as 0 so the loops never do anything. If anyone can please provide some help as to what I can do to get this working I would greatly appreciate it. Thanks everyone.
#include <SoftwareSerial.h>
byte incomingbyte;
SoftwareSerial mySerial(4,5); //RX 4, TX 5
int a=0x0000,j=0,k=0,count=0; //Read Starting address
uint8_t MH,ML;
boolean EndFlag=0;
void SendResetCmd();
void SendTakePhotoCmd();
void SendReadDataCmd();
void StopTakePhotoCmd();
Serial.begin(19200);
mySerial.begin(38400);
Serial.println("Serial has begun");
//Print what's in the Serial port and Reset
SendResetCmd();
Serial.println("Sent Reset Command");
delay(4000);
//After reset, wait 2-3 second to send take picture command, check again
Serial.println("BEfore send tak photo command");
SendTakePhotoCmd();
Serial.println("After sendtakephotocommand");
int numOfSer=mySerial.available();
Serial.println(numOfSer);
while(mySerial.available()>0)
incomingbyte=mySerial.read();
Serial.println(incomingbyte, HEX);
byte a[32];
Serial.println("Byte Array Initialized");
while(!EndFlag)
Serial.println("Entering While Loop");
j=0;
k=0;
count=0;
SendReadDataCmd();
Serial.println("Read Data Command Sent");
delay(25);
k++;
if((k>5)&&(j<32)&&(!EndFlag))
a[j]=incomingbyte;
if((a[j-1]==0xFF)&&(a[j]==0xD9)) //Check if the picture is over
EndFlag=1;
j++;
count++;
for(j=0;j<count;j++)
{ if(a[j]<0x10)
Serial.print("0");
Serial.print(a[j],HEX);
Serial.print(" ");
} //Send jpeg picture over the serial port
while(1);
//Send Reset command
void SendResetCmd()
Serial.println("in send reset cmnd");
mySerial.write(0x56);
mySerial.write(byte(0x00));
mySerial.write(0x26);
//Send take picture command
Serial.println("in send take photo cmnd");
mySerial.write(0x36);
mySerial.write(0x01);
//Read data
Serial.println("in send read data cmnd");
MH=a/0x100;
ML=a%0x100;
mySerial.write(0x32);
mySerial.write(0x0c);
mySerial.write(0x0a);
mySerial.write(MH);
mySerial.write(ML);
mySerial.write(0x20);
a+=0x20; //address increases 32£¬set according to buffer size
Serial.println("in send stop take photo cmnd");
mySerial.write(0x03);
