Need help with Arduino Joystick library and Limit Switch
Hello !
I want to connect two Limit Switch for an Joystick and Arduino Pro micro board.
I used this Joystick library : GitHub - MHeironimus/ArduinoJoystickLibrary: An Arduino library that adds one or more joysticks to the list of HID devices an Arduino Leonardo or Arduino Micro can support.
The wiring :
The arduino Sketch :
#include <Joystick.h>
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID, JOYSTICK_TYPE_GAMEPAD,
2, 0,                // Button Count, Hat Switch Count
false, false, false,  // 3 mores analogs inputs (for potentiometers for exemple). Set them to "true" if you need them.
false, false, false,     // Rx (potentiometer), Ry (Brake loadcell), Rz (potentiometers)
false, false,         // Rudder, throttle
false, false, false); // Accelerator, brake, stering
  Joystick.begin();
  Serial.begin(38400);
  // Buttons
  pinMode(2, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
  Joystick.setButton(0, !digitalRead(2));
  Joystick.setButton(1, !digitalRead(4));
  delay(50);
} // End loop
But it's not working ! When I push the limit switch I have nothing in my Joystick.
Can you help me ? Thanks.
Switches should go to ground not vcc..
good luck.. ~q
Thanks, but there is 3 GND holes, which is the good ?
take you pick, their all the same.. :slight_smile:
~q
your pinMode is INPUT_PULLUP, means they start HIGH..
Just need to bring the pin to ground to get a low..
otherwise, always HIGH..
~q
Thanks, I will try the 3 GND.
It worked !! Thanks you qubits-us :smiley:
