I want the servos (I have 2) to connect together, and to do the same function. I don't know the first thing about coding especially c++, but maybe there's a way to combine the code?
// www.elegoo.com
// Include 'header' files (.h files) that contain necessary software libraries:
#include <Adafruit_MotorShield.h> // Libary for motor shield
#include <Servo.h> // Library for controlling servo motor
#include <NewPing.h> // Library for controlling the ultrasonic sensor
// Define pins for ultrasonic sensor:
#define TRIG_PIN 10 // Define the trigger pin as analog pin #0
#define ECHO_PIN 9 // Define the echo pin as analog pin #1
#define RIGHT_BLINK_PIN 1 //(TEST) LED indicator for right
// Define pin for servo motor:
#define SERVO_PIN 6 // Defines the pin to use for the servo to pin #9, which is connected to
// pins labelled 'SERVO_2' on the Motor Drive Shield
#define green_LED 2
#define red_LED 4
#define yellow_LED 3
// Create software 'objects' (part of 'object-oriented programming'):
Servo myservo; // Create servo object to control servo motor.
Adafruit_MotorShield myMotorShield = Adafruit_MotorShield(); // Create motor-shield object with the default I2C address
// Assign Adafruit_DCMotor objects to the 4 'ports' (connections) on the
// motor shield. The numbering of these motors assumes that the motors on left of car are
// wired to 'M1' and 'M2' on the Motor Shield, and the motors on right of car are wired to
// 'M3' and 'M4'. (It's OK to deviate from this convention, but you'll have to modify the
// 'turn_left' and 'turn_right' functions below.)
Adafruit_DCMotor *Motor_A = myMotorShield.getMotor(1); // Assign 'Motor_A' to 'port' M1 on motor shield
Adafruit_DCMotor *Motor_B = myMotorShield.getMotor(2); // Assign 'Motor_B' to 'port' M2 on motor shield
Adafruit_DCMotor *Motor_C = myMotorShield.getMotor(3); // Assign 'Motor_C' to 'port' M3 on motor shield
Adafruit_DCMotor *Motor_D = myMotorShield.getMotor(4); // Assign 'Motor_D' to 'port' M4 on motor shield
// Create a 'sonar' object, in which we define which Arduino pins to use as the trigger pin
// and the echo pin. (Pin numbers are defined above.)
NewPing sonar(TRIG_PIN, ECHO_PIN);
// Define the speed for car when travelling straight (on scale from 0 to 255). Car's actual
// speed will depend on the battery power and the floor surface (tile vs carpet).
int carSpeed = 75;
// Define speed for turning car (on scale from 0 to 255). This parameter and the 'turningDuration'
// parameter (below) will determine how far the car turns.
int turningSpeed = 200;
// Define the duration for turning the car, in milliseconds. Lengthen the delay time
// to turn more; shorten time to turn less.
int turningDuration = 500;
// Define variables that will contain the distances sensed to obstacles by the
// ultrasonic sensor:
int straightDistance ; // Distance to obstacle straight ahead (in cm)
int rightDistance ; // Distance to obstacle 90 degrees to right
int leftDistance ; // Distance to obstacle 90 degrees to left
int rightCenterDistance ; // Distance to obstacle 45 degrees to right
int leftCenterDistance ; // Distance to obstacle 45 degrees to left
// Run the 'setup' function at the beginning of the program:
Serial.begin(9600); // Starts the serial communication at the specified baud rate
Serial.println("============================================================");
Serial.println("================ Starting the program ======================");
myservo.attach(SERVO_PIN); // Attaches the servo pin to the servo object (SERVO_2 on the Motor Drive Shield)
myservo.write(90); // Tells the servo to position at 90-degrees (straight ahead).
pinMode (green_LED, OUTPUT);
pinMode (red_LED, OUTPUT);
pinMode (yellow_LED, OUTPUT);
myMotorShield.begin(); // Start the motor_shield with the default PWM frequency (1.6 kHz)
stop(); // Initially, stop all the DC motors
// Run the 'loop' function continuously:
// Check for obstacles ahead:
check_for_obstacles_ahead();
// Check that there is sufficient space directly ahead and 45 degrees to each side:
if ((straightDistance > 30) && (rightCenterDistance > 20) && (leftCenterDistance > 20))
// Obstacles in all 3 directions are far away, so move forward:
digitalWrite (green_LED, LOW);
digitalWrite (red_LED, LOW);
digitalWrite (yellow_LED, LOW);
go_forward(carSpeed);
// Obstacles are too close, so ensure that motors are stopped, then back up
// slightly, and then determine which direction to turn the car:
stop();
Serial.println("========== Too close to obstacles in front. ================");
go_backward(carSpeed);
digitalWrite (green_LED, HIGH);
delay(100); // Go backwards for only 100 ms
stop();
// Check distances to left and right:
check_for_obstacles_left_and_right();
// Turn car towards direction that has more open space:
turn_towards_open_space();
} // End of if/else block for (straightDistance > 30) && (rightCenterDistance > 20) && (leftCenterDistance > 20)
} // End of 'loop' function
// ========== Below are where we define the functions ===========
// ========== that are called above in the 'setup' ===========
// ========== and 'loop' functions. ===========
// Function 'set_speed' sets the 4 motors to the speed given by
// 'speed', which can range from 0 to 255:
void set_speed(int speed)
// Serial.print("Setting motor speed to: ");
// Serial.println(speed);
Motor_A->setSpeed(speed);
Motor_B->setSpeed(speed);
Motor_C->setSpeed(speed);
Motor_D->setSpeed(speed);
} // End of function 'set_speed'
// Function 'go_forward' sets the direction to forward for all
// 4 motors:
void go_forward(int speed)
Serial.println("Going forward...");
set_speed(speed);
Motor_A->run(FORWARD);
Motor_B->run(FORWARD);
Motor_C->run(FORWARD);
Motor_D->run(FORWARD);
} // End of function 'go_forward'
// Function 'go_backward' sets the direction to backward for all
// 4 motors:
void go_backward(int speed)
Serial.println("Going backward...");
set_speed(speed);
Motor_A->run(BACKWARD);
Motor_B->run(BACKWARD);
Motor_C->run(BACKWARD);
Motor_D->run(BACKWARD);
} // End of function 'go_backward'
// Function 'turn_right' sets the direction to forward for Motor1 and
// Motor2 (on left of car), and to backward for Motor3 and Motor4
// (on the right of car):
void turn_right(int speed)
Serial.println("Turning right...");
set_speed(speed);
} // End of function 'turn_right'
// Function 'turn_left' sets the direction to backward for Motor1 and
// Motor2 (on left of car), and to forward for Motor3 and Motor4
void turn_left(int speed)
Serial.println("Turning left...");
set_speed(speed);
} // End of function 'turn_left'
// Function 'stop' turns off all 4 motors:
void stop() {
Serial.println("Stopping all motors.");
set_speed(0);
Motor_A->run(RELEASE);
Motor_B->run(RELEASE);
Motor_C->run(RELEASE);
Motor_D->run(RELEASE);
} // End of function 'stop'
// Function 'get_distance' returns the distance (in cm) to an
// obstacle, as measured by the ultrasonic sensor:
int get_distance() {
// Create a "long" integer variable to accommodate a large number of microseconds:
unsigned long duration = 0;
// Create a floating-point variable for the distance:
float float_distance = 0.0;
// Read the ultrasonic sensor and return the sound wave travel time in microseconds.
// The 'ping_median()' method will quickly send 5 pings and return the median echo time,
// thereby discarding values that deviate from the average/median.
duration = sonar.ping_median(10);
// Check if the duration is zero. Sometimes the sensor reports zero microseconds, which is
// physically impossible. In these (rare) cases, substitute 1824 microseconds for the echo
// time, corresponding to an obstacle distance of ~31 cm:
if (duration == 0) {
duration = 1824;
Serial.println("*** WARNING: Substituted 1824 microseconds for a physically impossible zero-microsecond echo time. ***");
// Prints the round-trip delay in microseconds:
// Serial.print("||| In function get_distance: Round-trip delay: ");
// Serial.print(duration);
// Serial.println(" microseconds");
float_distance = duration *0.034/2; // Calculate distance in centimeters
// Convert the floating-point distance to an integer:
int distance = (int)float_distance;
// Prints the distance on the Serial Monitor:
// Serial.print("||| In function get_distance: Distance: ");
// Serial.print(distance);
// Serial.println(" cm");
return distance; // Return the distance to the calling program.
} // End of function 'get_distance'
// Function 'check_for_obstacles_ahead' measures the distances to
// obstacles straight ahead, and 45 degrees to each side. The function
// populates the following three variables with the distance (in cm) to
// obstacles: straightDistance, rightCenterDistance, and leftCenterDistance.
// Incidentally, if these distances are less than 30cm, 20cm, or 20cm
// (respectively), this function will stop the car immediately.
void check_for_obstacles_ahead() {
Serial.println("");
Serial.println("=========== Scanning straight and 45 degrees to either side ============");
// Get distance to obstacles straight ahead:
myservo.write(90); // Set servo motor to point straight ahead (angle = 90 degrees)
delay(300); // Wait for servo motor to stabilize
straightDistance = get_distance();
Serial.print("straightDistance = "); Serial.print(straightDistance); Serial.println(" cm.");
// If obstacle ahead is less than 30 cm, then stop motors immediately:
if (straightDistance <= 25 )
stop();
// Get distance to obstacles 45 degrees to right:
myservo.write(30); // Set servo motor to point 45 degrees to right (angle = 45 degrees)
delay(450); // Wait for servo motor to stabilize
rightCenterDistance = get_distance();
Serial.print("rightCenterDistance = "); Serial.print(rightCenterDistance); Serial.println(" cm.");
// If obstacle towards right is within 20 cm, then stop motors immediately:
if (rightCenterDistance <= 25)
stop();
// Swing servo back straight ahead and again get distance to obstacles:
delay(450);
// If obstacle straight ahead is within 30 cm, then stop motors immediately:
if (straightDistance <= 25)
stop();
// Get distance to obstacles 45 degrees to left:
myservo.write(135); // Set servo motor to point 45 degrees to left (angle = 135 degrees)
leftCenterDistance = get_distance();
Serial.print("leftCenterDistance = "); Serial.print(leftCenterDistance); Serial.println(" cm.");
// If obstacle towards left is within 20 cm, then stop motors immediately:
if (leftCenterDistance <= 20)
stop();
// Again, get distance to obstacles straight ahead:
// If obstacle is within 30 cm straight ahead, then stop motors immediately:
if (straightDistance <= 35)
stop();
} // End of function 'check_for_obstacles_ahead()'
// Function 'check_for_obstacles_left_and_right' measures the distances to
// obstacles 90 degrees to the left and right. The function populates the
// following two variables with the distance (in cm) to obstacles:
// leftDistance and rightDistance.
void check_for_obstacles_left_and_right() {
// Turn the sensor 90 degrees left and right to check for obstacles:
Serial.println("Checking left and right.");
myservo.write(80); // Turn ultrasonic sensor 90 degrees to right
rightDistance = get_distance();
Serial.print("rightDistance = "); Serial.print(rightDistance); Serial.println(" cm.");
myservo.write(80);
myservo.write(180); // Turn ultrasonic sensor 90 degrees to left
leftDistance = get_distance();
Serial.print("leftDistance = "); Serial.print(leftDistance); Serial.println(" cm.");
myservo.write(80); // Turn ultrasonic sensor straight ahead again
} // End of function 'check_for_obstacles_left_and_right()'
// Function 'turn_towards_open_space' turns the car left or right based
// on the values in the variables 'leftDistance' and 'rightDistance'.
// If leftDistance is larger than rightDistance (i.e., there's more open
// space to the left), then this function turns the car towards the left.
// The opposite occurs if rightDistance > leftDistance.
void turn_towards_open_space() {
// Determine whether obstacles are closer on the right or on the left.
// Turn in the direction that has more room:
if(rightDistance > leftDistance)
// There's more room towards the right, so turn in that direction:
Serial.println("rightDistance > leftDistance, so turning right.");
digitalWrite(red_LED, HIGH);
delay(150);
digitalWrite(red_LED, LOW);
delay(150);
turn_right(turningSpeed);
delay(turningDuration); // Lengthen the delay time to turn more; shorten time to turn less.
stop();
// There's more room towards the left, so turn in that direction:
Serial.println("leftDistance >= rightDistance, so turning left.");
digitalWrite(yellow_LED, HIGH);
delay(150);
digitalWrite(yellow_LED, LOW);
delay(150);
turn_left(turningSpeed);
stop();
} // End of if/else block for (rightDistance > leftDistance)
} // End of function 'turn_towards_open_space()'
