Wondered if anyone can help . I've adapted this sketch for my purpose removed things i don't need and changed the display from oled to lcd . The problem in having is in the void setstep() { section when i scroll through the steps the last part of the text from the previous step setting remains and ends up garbled up. Any help would be appreciated im still trying to learn how things work
10kHz to 120MHz VFO / RF Generator with Si5351 and Arduino Nano, with Intermediate Frequency (IF)
offset (+ or -).ORIGINAL SKETCH BY By J. CesarSound - ver 1.0 - Dec/2020. Modded by recoil 2022
//Libraries
#include <Wire.h>
#include <Rotary.h>
#include <si5351.h>
//User preferences
#define IF +7801 //Enter your IF frequency, ex: 455 = 455kHz, 10700 = 10.7MHz, 0 = to direct convert receiver or RF generator, + will add and - will subtract IF offfset.
#define FREQ_INIT 28000000 //Enter your initial frequency at startup, ex: 7000000 = 7MHz, 10000000 = 10MHz, 840000 = 840kHz.
#define XT_CAL_F 16000 //Si5351 calibration factor, adjust to get exatcly 10MHz. Increasing this value will decreases the frequency and vice versa.
#define tunestep A0 //Change the pin used by encoder push button if you want.
Rotary r = Rotary(2, 3);
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
Si5351 si5351;
unsigned long freq = FREQ_INIT;
unsigned long freqold, fstep;
long interfreq = IF;
long cal = XT_CAL_F;
unsigned long long pll_freq = 90000000000ULL;
byte encoder = 1;
byte stp;
unsigned int period = 100; //millis display active
unsigned long time_now = 0; //millis display active
ISR(PCINT2_vect) {
char result = r.process();
if (result == DIR_CW) set_frequency(1);
else if (result == DIR_CCW) set_frequency(-1);
void set_frequency(short dir) {
if (encoder == 1) { //Up/Down frequency
if (dir == 1) freq = freq + fstep;
if (freq >= 120000000) freq = 120000000;
if (dir == -1) freq = freq - fstep;
if (fstep == 1000000 && freq <= 1000000) freq = 1000000;
else if (freq < 10000) freq = 10000;
Wire.begin();
lcd.init(); // initialize the lcd
lcd.init();
lcd.backlight();
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(tunestep, INPUT_PULLUP);
si5351.init(SI5351_CRYSTAL_LOAD_8PF, 0, cal);
si5351.output_enable(SI5351_CLK0, 1); //1 - Enable / 0 - Disable CLK
si5351.output_enable(SI5351_CLK1, 0);
si5351.output_enable(SI5351_CLK2, 0);
si5351.drive_strength(SI5351_CLK0, SI5351_DRIVE_2MA); //Output current 2MA, 4MA, 6MA or 8MA
PCICR |= (1 << PCIE2);
PCMSK2 |= (1 << PCINT18) | (1 << PCINT19);
sei();
stp = 5;
setstep();
layout();
displayfreq();
if (freqold != freq) {
time_now = millis();
tunegen();
freqold = freq;
if (digitalRead(tunestep) == LOW) {
time_now = (millis() + 300);
setstep();
delay(300);
if ((time_now + period) > millis()) {
displayfreq();
layout();
void tunegen() {
si5351.set_freq_manual((freq + (interfreq * 1000ULL+620)) * 100ULL, pll_freq, SI5351_CLK0);
void displayfreq() {
unsigned int m = freq / 1000000;
unsigned int k = (freq % 1000000) / 1000;
unsigned int h = (freq % 1000) / 1;
char buffer[15] = "";
if (m < 1) {
lcd.setCursor(0, 0); sprintf(buffer, "%003d.%003d", k, h);
else if (m < 100) {
lcd.setCursor(0, 0); sprintf(buffer, "%2d.%003d.%003d", m, k, h);
else if (m >= 100) {
unsigned int h = (freq % 1000) / 10;
lcd.setCursor(0, 0); sprintf(buffer, "%2d.%003d.%02d", m, k, h);
lcd.print(buffer);
void setstep() {
lcd.setCursor(5, 1);
switch (stp) {
case 1:
stp = 2;
fstep = 1;
lcd.print( "1hz");
case 2:
stp = 3;
fstep = 10;
lcd.print("10hz");
case 3:
stp = 4;
fstep = 1000;
lcd.print("1k");
case 4:
stp = 5;
fstep = 5000;
lcd.print("5k");
case 5:
stp = 6;
fstep = 10000;
lcd.print("10k");
case 6:
stp = 1;
fstep = 1000000;
lcd.print("1M");
void layout() {
lcd.setCursor(0, 1);
lcd.print("STEP:");
lcd.setCursor(13, 0);
lcd.print("MHz");
