need help with humidity sensor HIH 4000-001
Hi all,
I m using Honeywell humidity sensor called HIH 4000-001, the sensor is connected to mcp3204 A/D IC and further this ICs SPI o/p is connected to mega 2560.
My question is i cant able to get stable reading from sensor what to do for this??
I checked sensor o/p with multimeter bt mV o/p is very unstable e.g. 2000mV to 2060 and again 2060 mV to 2000mV and continue this process.. Is it sensors fault or anything else??
Please help me to stable this o/p or can i do any thing to smoothing or filtring this unstable mV o/p..??
Do you use 5V for the sensor ? Where is that 5V coming from ? If you use USB power, the 5V is not a good 5.0V.
You can test that by using an external power supply for the Arduino Mega 2560 board, and the 5V pin to power the humidity sensor.
dear peter,
Thanks for your reply. i cheked all power supply mostly i connect it with the laptop usb and as u mention it is very much stable.but still i cant find the solution on how to get stable mV output.
With an external power supply I ment for example a wall wart of 7.5V to the barrel jack of the Arduino board.
Did you measure the voltage when powered from the laptop ? You can measure the 5V pin of the Arduino. If it varies between 4.85 and 5.00V, that is the 3% I'm looking for.
It is also possible that some noise is in the circuit. Do you use long wires ? or a bad breadboard ? Perhaps you can take 5 to 20 samples and use the average.
Hii peter
Thanks for your valuable rply but i have a question that what u mean by "milli() is used for futur reference" ???
Hello
If you take a look at the data sheet, you will see that the HIH4000's need a load resistor of not less than 80K between 0V and output (check this as off top of head) - I have set one of these up and there are no problems with readings (approx 0.8V @0%RH, 3.8V @ 100%). In fact very stable.This is running on about 20cm hookup wire, but I wouldn't envisage problems up to 1m.
Take care you get everything wired up right as expensive bits of kit, assuming the genuine article.
Your 2000mV about right, approx 45%RH?
