(Couldn't Read My Category DropMenu, So Srry if this isn't the right spot)
Kinda had this a while back, However i cant seem to find anyway or any form/post that can help figure out why no if statements Will Execute even with the variable Being set to match the if statement.
in short does anyone have an idea why any if Statements i put below (in OR out of the While Loop) Gets ignored, even With Different setups, this code has been troublesome.
As Seen one of my if statements should work here:
I marked alot of extra/Older Code to Prevent confusion, Along with trying to figure out the probem
Second Screen Shot:
Arduino and Settings Im Working With:(Not The Script Im Using In Background)
(Also I Changed My Password For Obvious Reasons)
Code Itself (215 Lines, Srry For Any Messy Or Hard to Read Code):
#include <ESP8266WiFi.h>
const char* ssid = "TELUS0361";
const char* password = "PassWord";
int Port=1337;
WiFiServer server(Port);
String Input="";
String Temp="";
String Temp1="";
const char* Temp2="";
const char* TempC1="";
int A1Val = 0;
bool debounce=false;
bool CTC=false;
void printWiFiStatus();
void Reconnect();
void Debounce();
#include <WiFiUdp.h>
#include <I2S.h>
#ifndef STASSID
#define STASSID "your-ssid"
#define STAPSK "your-password"
#endif
WiFiUDP udp;
String LIP = "";//Local IP
const int port = Port;//Local Port
int16_t buffer[100][2]; // Temp staging for samples
pinMode(LED_BUILTIN, OUTPUT);
delay(250);
digitalWrite(LED_BUILTIN, LOW);
WiFi.begin(ssid, password);
digitalWrite(LED_BUILTIN, HIGH);
Serial.printf("Connection status: %d\n", WiFi.status());
delay(750);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
if(Serial.available()){
//if serial is availible
Input = Serial.readStringUntil('\n');//get User input
if (!Input.indexOf(ssid) > 0){//if Not The Same As SSID then
Serial.print("Changed SSID To:");
Serial.println(ssid);
delay(250);
Serial.print("Reconnecting");
delay(250);
delay(250);
delay(250);
Serial.println("Connected, IP address: ");
Serial.println("Wifi Port: ");
Serial.println(Port);
// Serial.println("Testing Port..");
// delay(1000);
// i2s_rxtx_begin(true, false); // Enable I2S RX
// i2s_set_rate(11025);
// digitalWrite(LED_BUILTIN, LOW);
// delay(250);
// digitalWrite(LED_BUILTIN, HIGH);
// Serial.print("\nStart the listener on ");
// Serial.print(WiFi.localIP());
// Serial.print(":");
// Serial.print(Port);
// //Serial.println("ex: nc -u -p 8266 -l | play -t raw -r 11025 -b 16 -c 2 -e signed-integer -");
// delay(250);
// Temp2 = WiFi.localIP();
// LIP = Temp2;
// LIP.replace(" ", ",");
// Serial.println(LIP);
// delay(250);
// udp.beginPacket(LIP, Port);
// udp.write("I2S Receiver\r\n");
// udp.endPacket();
// delay(250);
Serial.println("connecting Server");
server.begin();
//printWiFiStatus();
Serial.println("----------------------");
Serial.println("Starting Server Client");
//Attempt Reconnect
void Reconnect(){
delay(250);
delay(250);
delay(250);
Serial.print(".");
if (WiFi.status() == WL_CONNECTED){
server.begin();
// Check if module is still connected to WiFi.
if (WiFi.status() != WL_CONNECTED) {
Reconnect();
// Print the new IP to Serial.
printWiFiStatus();
WiFiClient client = server.available();
if (client) {
Serial.println("Client connected.");
while (client.connected()) {
if (client.connected()){//Check Connection To Client
CTC=true;
}else{
CTC=false;
//Check For Inputs
if (client.available() && CTC==true) {
char command = client.read();
//Serial.print(command);
delay(100);//This If is Being Ignored For some reason
Input = client.readStringUntil('\n');//get User input
//if (isdigit(Input) {
// Temp = Temp+Input;//Save Numbers
if (!Input.indexOf(Input) > 0) { //if Not The Same As SSID then
Serial.println("Final Print V2 Worked");
Temp1 = Input;
A1Val = Temp.toInt();
Serial.printf("Temp Storage :", Temp1);
Serial.println(" ");
Serial.printf("A1Val: ", A1Val);
Serial.println(Temp1);
Serial.println(A1Val);
// if (!isdigit(command) && debounce==false){//Save Input to String
// Temp1 = Temp1+command;//Save Letters
// Serial.println(Temp1);
// Serial.println(" ");
// //Debounce();
// delay(100);
// if (command==';'){
// debounce = true;
// }//else{
// Serial.println("Ignored Digit ");
// debounce = false;
//Debounce();
//These Ifs Do Not Work, Ignored
//Set Commands Based Off "Input"
if (Temp1 == "High;") {//Changed This To "==" No Error Still No Serial Text
Serial.println("LED is now on.");
delay(100);
//Temp1="";
if (Input.equals("Low;")) {//Tried Using The "Input" Varible, Still Nope
Serial.println("LED is now off.");
delay(100);
//Temp1="";
if (Temp1.equals("Read;")) {//Also Tried Wothout The ";", But Still Nope
Serial.println("A1: ");
Serial.println("--------");
Serial.println("Temp1: ");
delay(100);
//Temp1="";
//Loop Based Code Runs Below(When Connected)
}else{//Loop Based Code Runs Below(When Not Connected)
//move this to CTC=false; Line:120
Serial.println("Client disconnected.");
delay(250);
client.stop();
//Get Connection Status
void printWiFiStatus() {
Serial.println("");
Serial.print("Connected to ");
Serial.print("IP address: ");
