Need help with inactivity timeout for park assist sensor
I wrote a code to assist in parking my car in garage.
The ultrasonic sensor I have outputs in "inches" for each time through the loop.
Conditions:
  1. if inches>200 then I want no LED on
  2. if inches<200 and >120 I want red LED on
  3. if inches<120 I want green LED on
  4. On top of this, I want the sensor to turn off after 1 minute of inactivity. My code does not
    currently do this.
My code so far meets the first three conditions:
const int trigPin = 7;
const int echoPin = 8;
  // initialize serial communication:
  pinMode(trigPin,OUTPUT);
  pinMode(echoPin,INPUT);
  pinMode(13,OUTPUT);
  pinMode(4,OUTPUT);
  long duration, inches, cm;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimeters(duration);
  if((inches>200)){
    digitalWrite(13,LOW);
    digitalWrite(4,LOW);
  if((inches<200)&&(inches>110)){
    digitalWrite(13,HIGH);
  if((inches<110)){
    digitalWrite(4,HIGH);
  Serial.print(inches);
  Serial.print("in, ");
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
long microsecondsToInches(long microseconds) {
  // According to Parallax's datasheet for the PING))), there are 73.746
  // microseconds per inch (i.e. sound travels at 1130 feet per second).
  // This gives the distance travelled by the ping, outbound and return,
  // so we divide by 2 to get the distance of the obstacle.
  // See: https://www.parallax.com/package/ping-ultrasonic-distance-sensor-downloads/
  return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds) {
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the object we
  // take half of the distance travelled.
  return microseconds / 29 / 2;
How do I have it timeout? Seems simple but just not sure how to implement.
Describe what your code does (not the list of what you want).
What do you consider "timedout?" What happens after you do not want it timedout?
Timed out means no LED's are on. Right now I have a green led and a red led.
Green is on when:
RED is on when:
Have you worked with millis() (a timer)? If not, search "arduino blink without delay()" and "arduino multiple events" to get some working knowledge.
For now... let's assume you are there... (1) identify the time motion has stopped, (2) wait one minute, (3) turn off the LEDs.
While you were parking, the sensor was showing a decrease in time of flight of the echoes (translated to a decrease in distance). I imagine if you monitored "distance" (or time of flight), and when it stopped changing [give or take an inch (few cm)], then you will start a timer. Once that timer has reached your one-minute timeout, write LOW to each LED.
Does that sound right? Give it an adjustment if not? Give it a try if it looks good.
Not germane to your question but, what if inches == 200 ?
This is what I tried implementing but the LED's now don't turn on at all:
unsigned long lastActiveTime = 0;
const int timeoutDuration = 10000;
  pinMode(13,OUTPUT);
  pinMode(4,OUTPUT);
  long inches_prior;
  bool timingInProgress=false;
  unsigned long timeout_duration;
  if((inches==inches_prior)){
    timingInProgress==true;
    timeout_duration=millis();
  if(timeout_duration>10000){
  if((inches>=200)){
  if((inches<200)&&(inches>110)&&(timeout_duration<=10000)){
  if((inches<110)&&(timeout_duration<=10000)){
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
  inches_prior=inches;
Use these three things:
  1. distance is (the closest distance you want) - a measurement
  2. distance has not changed - requires "distanceOld"
  3. time (ten seconds for testing)
Something like...
if (distance > distanceOld - 1 && distance < distanceOld + 1) // two inch deadband - distance will never be static
  start the one minute/tenseconds timer
Not sure why this is still not working...
  if((inches>inches_prior-1)&&(inches<inches_prior+1)){
  if((inches>=200)){
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
Ask yourself: If inches is 300, start the timer?
Write a "one minute" (or ten seconds) timeout sketch. Start with an LED on. Press a button to start the timer. Wait for the timeout. Turn the LED off. The button press will eventually be your "close enough" distance.
Not sure where you get 300 from. As shown in the code above I have inches_prior saved as the old measurement for the distance. I just want the timer to start when there is no change between the old and new value of "inches". For some reason the LED's do not turn on at all.
It is beyond the limit you set... so distance (300) will start > 200 and turn your LEDs off
That is what this condition is for:
  if((inches>=200)){
right now my car is parked in front of it but the LED's are not lit.
And if inches > 200 for 61 seconds?
Is that not the goal, to timeout?
When I walk in front of it, the LED's still won't turn on. I want them to turn on when there is a change in the distance value.
Constantly read distance and compare with a stored distance. A change (of greater than a normal error) means movement. You are trying to solve three things. Solve one at a time.
The HC-SR04 is not omnidirectional It has a 15 degree cone.
What I have so far. I do not have this working yet.
I want to turn off both LED's during periods of inactivity, like when the car is parked or the car is not in garage. That is why I compare old value with new and if old == new then it will start timer.
// this constant won't change. It's the pin number of the sensor's output:
  pinMode(13,OUTPUT);
  pinMode(4,OUTPUT);
  long inches_prior;
  if((inches>=200)){
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
This.
All uses of timeout_duration in any posted sketches are incoherent.
Here's the simplest way to get you inactivity timeout going.
  1. Use a static or global variable, here I use a global:
unsigned long lastActivity;
const unsigned long activityInterval = 30000UL;  // how long, 30 seconds in this example
  1. Any time there is activity to keep the thing alive, set that variable to the current time, viz:
    lastActivity = millis();
  1. Finally, Just once elsewhere in your loop where it will get execute frequently enough, see if the time has moved ahead of the activity time by enough to cause a timeout:
  if (millis() - lastActivity >= activityInterval) {
// no activity for the activityInteravl so
// do whatever timing out means right here
Three parts. A timing variable and a time constant for how long to wait for activity. A reset of the timer variable whenever there is activity and finally a test for the time getting far enough ahead of the last activity to mean timeout should occru.
I have a simulation of that I'll try to find, but that's it nutshelled.
HTH
a7
Here is a simulation of the "keep alive" idea:
Wokwi_badge simple keep alive
a7
In my case one of the conditions will always be true, unlike in the simulation where you release the button and it starts counting.
inches will be:
<=110
110<inches<200
inches>=200
So if I do:
  if((inches>=200)){
won't lastActivity always equal the current time millis()? So then the below condition will never be met?(ie. millis() - lastActivity = 0)
