Update #2;
SUCCESS!! The LED matrix works! I found the library that you mentioned, aarg, and installed it into the directory that contains the Arduino IDE program. I found an example sketch called '16x8 matrix', and uploaded it to the Nano. All the LEDs on the matrix light up in various patterns ( I can't see the full patterns since my matrix is 3x18, and the text and graphics are being split up into three sections (it is wired as a 6x9 matrix, but laid out as a 3x18 matrix physically).
I am trying to find the part of the code that controls the brightness of the LEDs; the HT16K33 supports 16 levels of brightness, and they are currently not bright enough to match the LEDs that are separately powered.
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_8x16matrix matrix = Adafruit_8x16matrix();
Serial.println("16x8 LED Matrix Test");
matrix.begin(0x70); // pass in the address
static const uint8_t PROGMEM
smile_bmp[] =
{ B00111100,
B01000010,
B10100101,
B10000001,
B10100101,
B10011001,
B01000010,
B00111100 },
neutral_bmp[] =
{ B00111100,
B01000010,
B10100101,
B10000001,
B10111101,
B10000001,
B01000010,
B00111100 },
frown_bmp[] =
{ B00111100,
B01000010,
B10100101,
B10000001,
B10011001,
B10100101,
B01000010,
B00111100 };
matrix.clear();
matrix.drawBitmap(0, 0, smile_bmp, 8, 8, LED_ON);
matrix.writeDisplay();
matrix.clear();
matrix.drawBitmap(0, 8, neutral_bmp, 8, 8, LED_ON);
matrix.clear();
matrix.drawBitmap(0, 0, frown_bmp, 8, 8, LED_ON);
matrix.clear(); // clear display
matrix.drawPixel(0, 0, LED_ON);
matrix.writeDisplay(); // write the changes we just made to the display
matrix.clear();
matrix.drawLine(0,0, 7,15, LED_ON);
matrix.clear();
matrix.drawRect(0,0, 8,16, LED_ON);
matrix.fillRect(2,2, 4,12, LED_ON);
matrix.clear();
matrix.drawCircle(3,8, 3, LED_ON);
matrix.setTextSize(2);
matrix.setTextWrap(false); // we dont want text to wrap so it scrolls nicely
matrix.setTextColor(LED_ON);
for (int8_t x=0; x>=-64; x--) {
matrix.clear();
matrix.setCursor(x,0);
matrix.print("Hello");
delay(100);
matrix.setTextSize(1);
matrix.setRotation(1);
for (int8_t x=7; x>=-36; x--) {
matrix.clear();
matrix.print("World");
delay(100);
matrix.setRotation(0);
So all that is left on the hardware side is to hook up the buttons to set the clock. I have a 1x4 Membrane keypad that I would like to use; it has a common input pin and four separate output pins. I assume that the common pin could be either positive or negative, depending on how the keypad is connected to the circuit.
