Need help with MDFly AU-5016 MP3 player
I am trying to get this module to play files. Here is the datasheet:
http://mdfly.net/Download/Module/AU5016.pdf
I've tried using Serial.write (0x01) at 9600 baud with no luck. I'm only trying to get the first track to play at this point. I think I am just not sending Hex commands correctly. I posted this originally in Programming , but thought I'd get a better response here, I'm hoping someone else has used this module.
Here's my original code:
#include <SoftwareSerial.h>
SoftwareSerial mp3(4,3); //RX, TX
// initialize the serial communication:
Serial.begin(9600); //Set to 9600 bps
mp3.begin(9600); //Set mp3 serial to 9600 bps
delay(2000);
  mp3.write(0x01); // Play 1st file
  delay(5000);
I've also tried using both Serial.write and mp3.write, Serial.print, mp3.print both with (0x01) and (0x01,HEX) and all combinations. I have gotten the songs to play by grounding k1-k8, so I know my naming conventions are correct and that the module works, I just cannot control it with the arduino.
I've also tried 2 different arduino's in case it was on that end. Any ideas? I really appreciate everyone's help. Thanks.
Hi, I too just received this card and have been trying to get it to work. I'm a newbie to all this, but I eventually got it to play files randomly over serial control. One thing that made all the difference, was resetting the card by grounding the RST pad for a second, then removing and reinstalling power.
I'm using the sample audio files at:
http://www.mdfly.net/Download/Module/AU5016-SampleMus.rar
and have:
Arduino pin 1--> MDFly RXD
Arduino pin 2--> MDFly BUSY
Power and Speaker as expected
The Sketch I cobbled together is attached. I'm still working through accessing specific files directly, but that was before I added the busy loop. Again, I apologize that while this specific Sketch works for me, I'm still learning and not altogether savvy about this.
EDIT: Learned how to add code inline
const int busyPin = 2; // the number of the Busy pin
void setup(){
  Serial.begin(9600,SERIAL_8N1);
  Serial.write(0xFA);        // Reset board
  delay(2000);               // wait for a 2 seconds
  pinMode(busyPin, INPUT);
void loop(){
  if (digitalRead(busyPin) ==HIGH) {
//device busy
else {
  Serial.write(0xEB);
  delay(5000);               // wait for a 5 seconds
Hope this helps,
Patrick
Play_Random_Audio_File.ino (386 Bytes)
