Hi guys,
i wanna power and control one 433mhz transmitter and one hall sensor.
I have problems powering them the same time. I only can get one to work with the
5V Pin of the Arduino UNO.
Transmitter:
5V
10 mW
Sensor:
4.5 - 24V
25 mA
Code:
#include <RH_ASK.h>
#include <SPI.h>
RH_ASK rf_driver;
int pushButton = 13;
rf_driver.init();
pinMode(pushButton, INPUT);
int buttonState = digitalRead(pushButton);
const char *msg = "a";
Serial.println(buttonState);
delay(0);
if (buttonState == 0) {
rf_driver.send((uint8_t *)msg, strlen(msg));
rf_driver.waitPacketSent();
delay(0);
Serial.println("send");
Circuit:
If picture does not show up this is the link: circut hosted at ImgBB — ImgBB
Hall sensor datasheet:
433 mhz transmitter datasheet:
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Can you post link to spec/data of your transmitter and sensor please?
Thanks.. Tom...
I edited my post i hope this is fine
I'm just not sure if you guys can see my circuit picture.
Thanks for the information, just is good practice to add info in a new post, rather than go back and edit an earlier one.
Tom....
What do you mean by only getting one to work with 5V.
What happens when you connect both 5V wires from the TX and the Hall Effect to 5V on the UNO?
Have you written code JUST to test and read the HallEffect?
Have you written code JUST to test and operate the TX?
Thanks.. Tom..
Idk what the mistake was tbh... But it works now perfectly with connecting them both on the 5V Pin...
Thank you Tom for trying to help me
The next time i post i will try to give all information the right way like you told me to.
