Hi guys! I'm doing a project for school and encountered a situation that I can't figure out.
Please bare in mind that my programming skills are on the low end of the scale.
What my system does (on the arduino side) is to generate different PWM signals that drive a DC motor. The processing acts as an interface.
Seperatly both parts do what I want, but when I finally tried everything together I encountered a situation: my motor doesn't stop.
When I choose one of the paths (in processing) it will start the the pwm signal I want, but when I try to leave or change said signal it gets stuck and the motor doesn't stop.
PVector[] vecsFisiologico = new PVector[11];
PVector[] vecsBisferiens = new PVector[13];
int currentCurvePointFisiologico;
int currentCurvePointBisferiens;
import processing.serial.*;
Serial myPort;
String myText="";
int pulso = -1;
size(900, 900);
setPointsFisiologico();
setPointsBisferiens();
smooth();
frameRate(150);
myPort = new Serial(this, "COM3", 115200);
myPort.bufferUntil('n');
void serialEvent (Serial myPort){
myText = myPort.readStringUntil('n');
void draw()
background(100,255,100);
switch(pulso)
case -1: // difficult selection mode
text("pulso a reproduzir", 10, 30);
text("1, 2 ou 3 ?", 10, 50);
pushStyle();
fill(255, 204, 40);
rect(30, 70, 20, 20);
rect(60, 70, 20, 20);
rect(90, 70, 20, 20);
popStyle();
text("1", 36, 86);
text("2", 66, 86);
text("3", 96, 86);
myPort.write('S');
case 1:
drawFisiologico();
rect(0, 0, 20, 20);
myPort.write('A');
case 2:
drawBisferiens();
rect(0, 0, 20, 20);
myPort.write('B');
case 3:
// difficult level 3 stuff here
fill(0);
text("Pulso = " + pulso, 10, 120);
public void mouseClicked()
if (pulso == -1)
if (mouseX > 29 && mouseX < 51 && mouseY > 69 && mouseY < 91)
pulso = 1;
else if (mouseX > 59 && mouseX < 71 && mouseY > 69 && mouseY < 91)
pulso = 2;
else if (mouseX > 89 && mouseX < 101 && mouseY > 69 && mouseY < 91)
pulso = 3;
if (mouseX > 0 && mouseX < 21 && mouseY > 0 && mouseY < 21)
pulso = -1;
//from this point on is just the definition of the graphs, don't lose time :b
void drawFisiologico()
drawShapeFisiologico();
drawPointsFisiologico();
if (frameCount % 20 == 0)
currentCurvePointFisiologico++;
drawCurvePointFisiologico(currentCurvePointFisiologico % (vecsFisiologico.length-3));
void setPointsFisiologico()
vecsFisiologico[0] = new PVector(0, 600);
vecsFisiologico[1] = new PVector(0, 600);
vecsFisiologico[2] = new PVector(50, 600);
vecsFisiologico[3] = new PVector(100, 318);
vecsFisiologico[4] = new PVector(150, 120);
vecsFisiologico[5] = new PVector(250, 352);
vecsFisiologico[6] = new PVector(325, 300);
vecsFisiologico[7] = new PVector(400, 350);
vecsFisiologico[8] = new PVector(700, 559);
vecsFisiologico[9] = new PVector(800, 600);
vecsFisiologico[10] = new PVector(800, 600);
void drawShapeFisiologico() {
noFill();
stroke(0);
beginShape();
for (int i=0; i<vecsFisiologico.length; i++) {
curveVertex(vecsFisiologico[i].x, vecsFisiologico[i].y);
endShape();
void drawPointsFisiologico() {
noStroke();
fill(255, 0, 0);
for (int i=1; i<vecsFisiologico.length-1; i++) {
ellipse(vecsFisiologico[i].x, vecsFisiologico[i].y, 5, 5);
void drawCurvePointFisiologico(int num) {
noStroke();
fill(0, 0, 255);
float t = (frameCount % 20)/20.0;
float x = curvePoint(vecsFisiologico[num].x, vecsFisiologico[num+1].x, vecsFisiologico[num+2].x, vecsFisiologico[num+3].x, t);
float y = curvePoint(vecsFisiologico[num].y, vecsFisiologico[num+1].y, vecsFisiologico[num+2].y, vecsFisiologico[num+3].y, t);
ellipse(x, y, 15, 15);
void drawBisferiens()
drawShapeBisferiens();
drawPointsBisferiens();
currentCurvePointBisferiens++;
drawCurvePointBisferiens(currentCurvePointBisferiens % (vecsBisferiens.length-3));
void setPointsBisferiens()
vecsBisferiens[0] = new PVector(0, 600);
vecsBisferiens[1] = new PVector(0, 600);
vecsBisferiens[2] = new PVector(50, 600);
vecsBisferiens[3] = new PVector(100, 318);
vecsBisferiens[4] = new PVector(150, 100);
vecsBisferiens[5] = new PVector(190, 350);
vecsBisferiens[6] = new PVector(230, 150);
vecsBisferiens[7] = new PVector(300, 450);
vecsBisferiens[8] = new PVector(370, 350);
vecsBisferiens[9] = new PVector(450, 400);
vecsBisferiens[10] = new PVector(600, 500);
vecsBisferiens[11] = new PVector(800, 600);
vecsBisferiens[12] = new PVector(800, 600);
void drawShapeBisferiens() {
noFill();
stroke(0);
beginShape();
for (int i=0; i<vecsBisferiens.length; i++) {
curveVertex(vecsBisferiens[i].x, vecsBisferiens[i].y);
endShape();
void drawPointsBisferiens() {
noStroke();
fill(255, 0, 0);
for (int i=1; i<vecsBisferiens.length-1; i++) {
ellipse(vecsBisferiens[i].x, vecsBisferiens[i].y, 5, 5);
void drawCurvePointBisferiens(int num) {
noStroke();
fill(0, 0, 255);
float x = curvePoint(vecsBisferiens[num].x, vecsBisferiens[num+1].x, vecsBisferiens[num+2].x, vecsBisferiens[num+3].x, t);
float y = curvePoint(vecsBisferiens[num].y, vecsBisferiens[num+1].y, vecsBisferiens[num+2].y, vecsBisferiens[num+3].y, t);
#include <TimerOne.h>
int motorPin = 9;
float PWMb;
int PWMb1;
float PWMd;
int PWMd1;
int data;
Timer1.initialize(40);
void functionA()
int y = 0;
for(int y = 0; y <= 5; y = y + 1)
int x = 0;
for(int x = 0; x <= 100; x = x + 1) {
PWMd = 10 * x;
PWMd1 = (int) PWMd;
Timer1.pwm(motorPin, PWMd1);
delay (10);
void functionB()
int y = 0;
int x = 0 ;
for(int x = 0; x<= 196; x = x + 1)
PWMb = 1000 * sin(0.016 * x);
PWMb1 = (int) PWMb;
Timer1.pwm(motorPin, PWMb1);
delay (10);
if(Serial.available())
//data = Serial.read();
char pulso = Serial.read();
if (pulso == 'A')
functionA();
delay(10);
if (pulso == 'S'){ goto bailout;}
if (pulso == 'B'){ //onda sinusoidal
functionB();
bailout:{
Timer1.pwm(9,0);
Thanks in advance! Any help is greatly appreciated
