Need help with simple code for driving a motor and monitoring a "water sensor?"
Hi guys, I'm very new to Arduino and I'm looking for some help or someone to hopefully spit out a few lines of code for me. I have C and matlab training, but its been about 7 years since I've done any programming. I know what I'm looking to accomplish is very simple, I just don't have the time to read through a bunch of tutorials and spend a few nights trying to figure out exactly how to write the code for this.
Background: My GF's is a teacher of a special Ed class who started an organic garden to raise money for classroom materials, b/c our education systems suck. I've been tasked with creating an automatic watering system to make sure her garden doesn't die from lack of water. As cheap as possible.
The Plan: There will be 2X 55gal drums that will collect rain water from the school's gutters. I'll run a cheap garden hose between the bottom of both drums to keep the water levels even, with a "T" fitting between them going to a 12V RV water pump that draws up to 4 amps. **I need 2 portions of code, one basically wasting a day's worth of time then turning on the water pump for 10mins a day. I was thinking it could just count to what ever number was calculated by the Arduino's clock rate and 85800secs/day, which = 23hrs and 50mins. It would then flip on the pump and count to what ever number was calculated with the Arduino's clock rate and 600secs which =10mins. ** Seems simple enough. I will be using the output from the Arduino to a transistor to a relay to the motor. The entire system will be powered by a 12V deep cycle battery and a trickle charge solar panel. I realize I will probably have to adapt the 12V to whatever this bad boy needs, I'll use a voltage regulator. The second portion of code I'm looking for is to monitor the water level in 1 position near the bottom of the barrels to prevent the motor from turning on when the water source is depleted. Also, I need recommendations on the cheapest Arduino that would accomplish this task. I don't care about expansion possibilities bc this will be the sole purpose of this particular module.
Things I need from you guys:
-Recommendation on which Arduino module would be best/cheapest
-Code for timing and controlling motor
-Code for monitoring whether the water sensor is submerged or not
-What I can use as a water sensor
Once I have a starting program, I will understand it instantly and should be able to fine tune it myself with a few tuts and questions. Starting is the hard part. Any and all info is welcome and VERY appreciated by me and about 20 other people.
THANKS GUYS!!! ...OR GALS!!!
Locked by moderator for posting the same question in 4 different sections of the forum.
