Hi, im working on project using ESP32-S3 LVGL and using touch screen to control DC charging module DC charging module This Charging module using CAN bus to set Voltage,Current,On/Off or Reading Output
(Sorry, if the manual is not english)
充电模块CAN通讯协议V108_241028_123244.pdf (1.3 MB) Then i decide to use TJA1050 TJA1050 to Communicate between My LVGL (ESP32-S3) and Charging module, When come to Arduino IDE, im using this library Arduino CAN When i include this library in my code and compile, the code get a lot of error
In file included from C:\Users\MSI_GF63\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_reg.h:21,
from D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:7:
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp: In member function 'virtual int ESP32SJA1000Class::begin(long int)':
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:56:29: error: 'DPORT_PERIP_RST_EN_REG' was not declared in this scope
DPORT_CLEAR_PERI_REG_MASK(DPORT_PERIP_RST_EN_REG, DPORT_CAN_RST);
C:\Users\MSI_GF63\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:75:67: note: in definition of macro '_DPORT_WRITE_PERI_REG'
#define _DPORT_WRITE_PERI_REG(addr, val) (*((volatile uint32_t *)(addr))) = (uint32_t)(val)
C:\Users\MSI_GF63\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:85:46: note: in expansion of macro 'DPORT_WRITE_PERI_REG'
#define DPORT_CLEAR_PERI_REG_MASK(reg, mask) DPORT_WRITE_PERI_REG((reg), (DPORT_READ_PERI_REG(reg)&(~(mask))))
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:56:3: note: in expansion of macro 'DPORT_CLEAR_PERI_REG_MASK'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:56:29: note: suggested alternative: 'SYSTEM_PERIP_RST_EN1_REG'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:56:53: error: 'DPORT_CAN_RST' was not declared in this scope
C:\Users\MSI_GF63\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:75:88: note: in definition of macro '_DPORT_WRITE_PERI_REG'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:56:53: note: suggested alternative: 'DPORT_DATE_REG'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:57:27: error: 'DPORT_PERIP_CLK_EN_REG' was not declared in this scope
DPORT_SET_PERI_REG_MASK(DPORT_PERIP_CLK_EN_REG, DPORT_CAN_CLK_EN);
C:\Users\MSI_GF63\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:88:46: note: in expansion of macro 'DPORT_WRITE_PERI_REG'
#define DPORT_SET_PERI_REG_MASK(reg, mask) DPORT_WRITE_PERI_REG((reg), (DPORT_READ_PERI_REG(reg)|(mask)))
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:57:3: note: in expansion of macro 'DPORT_SET_PERI_REG_MASK'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:57:27: note: suggested alternative: 'SYSTEM_PERIP_CLK_EN1_REG'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:57:51: error: 'DPORT_CAN_CLK_EN' was not declared in this scope
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:57:51: note: suggested alternative: 'DPORT_REG_CLR_BIT'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:61:26: error: 'CAN_RX_IDX' was not declared in this scope
gpio_matrix_in(_rxPin, CAN_RX_IDX, 0);
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:61:26: note: suggested alternative: 'TWAI_RX_IDX'
TWAI_RX_IDX
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:66:27: error: 'CAN_TX_IDX' was not declared in this scope
gpio_matrix_out(_txPin, CAN_TX_IDX, 0, 0);
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:66:27: note: suggested alternative: 'TWAI_TX_IDX'
TWAI_TX_IDX
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp: In member function 'virtual void ESP32SJA1000Class::end()':
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:159:27: error: 'DPORT_PERIP_RST_EN_REG' was not declared in this scope
DPORT_SET_PERI_REG_MASK(DPORT_PERIP_RST_EN_REG, DPORT_CAN_RST);
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:159:3: note: in expansion of macro 'DPORT_SET_PERI_REG_MASK'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:159:27: note: suggested alternative: 'SYSTEM_PERIP_RST_EN1_REG'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:159:51: error: 'DPORT_CAN_RST' was not declared in this scope
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:159:51: note: suggested alternative: 'DPORT_DATE_REG'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:160:29: error: 'DPORT_PERIP_CLK_EN_REG' was not declared in this scope
DPORT_CLEAR_PERI_REG_MASK(DPORT_PERIP_CLK_EN_REG, DPORT_CAN_CLK_EN);
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:160:3: note: in expansion of macro 'DPORT_CLEAR_PERI_REG_MASK'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:160:29: note: suggested alternative: 'SYSTEM_PERIP_CLK_EN1_REG'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:160:53: error: 'DPORT_CAN_CLK_EN' was not declared in this scope
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:160:53: note: suggested alternative: 'DPORT_REG_CLR_BIT'
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp: In member function 'virtual void ESP32SJA1000Class::onReceive(void (*)(int))':
D:\20kW.2\MAX\libraries\arduino-CAN-master\src\ESP32SJA1000.cpp:271:20: error: 'ETS_CAN_INTR_SOURCE' was not declared in this scope
esp_intr_alloc(ETS_CAN_INTR_SOURCE, 0, ESP32SJA1000Class::onInterrupt, this, &_intrHandle);
I Wonder how can i fix this ,excuse my poor english.
Thanks
