t3acat
March 13, 2023, 4:11pm
1
Hello! I need help with some wiring. Is it possible to wire a VEX 2-wire Motor 393 to the project diagram in this link: https://docs.arduino.cc/built-in-examples/digital/Button
If it is possible, please let me know. Have a good day!
Any datasheet available for that motor?
t3acat
March 13, 2023, 4:49pm
3
xfpd
March 14, 2023, 12:51am
4
Some data on this link:
http://cmra.rec.ri.cmu.edu/products/cortex_video_trainer/lesson/media_files/IntegratedEncoderModule.pdf
The VEX Robotics Design System offers students an exciting platform for learning about areas rich with career opportunities spanning science, technology, engineering and math (STEM). These are just a few of the many fields students can explore by...
/* vexMotorLibraryExample.ino
Upload this program to your Arduino and open up the Serial Monitor
to manually control / specify the speed of your servo motor.
This example exercises all of the methods and properties that are
used in the vexMotor class. vexMotor uses the Servo library. You must
include both vexMotor.h and Servo.h.
Hardware connections:
To connect the standard 2-wire VEX motor 393 to an Arduino requires
a Motor Controller 29 module. Connect the wires on the Motor Controller
to the Arduino with the following pins:
MOTOR CONTROLLER 29 <--------> ARDUINO
WHITE (signal) Digital pin 9
RED (power) VIN (Battery Power -- 5V works too, but won't be as strong or fast)
BLACK (ground) Ground (GND)
This file has been truncated. show original
And, a button-motor simulation:
Run IoT and embedded projects in your browser: ESP32, Arduino, Pi Pico, and more. No installation required!
