Mod edit:
This topic follows on from:
Here is my attempt at writing a switch/case state machine:
// Devastator_Robot_StateMachine.ino
#include <Servo.h>
#include <NewPing.h> //https://bitbucket.org/teckel12/arduino-new-ping/downloads/
#include "DFRobot_HuskylensV2.h"
#include "Wire.h"
// Create object
HuskylensV2 huskylens;
// #define TRIG_PIN A4 // Change to A2 to prevent conflict with Husky Lens camera
// #define ECHO_PIN A5 // Chamge to A3 to prevent conflict with Husky Lens camera
#define TRIG_PIN A2
#define ECHO_PIN A3
#define MAX_DISTANCE 200
int E1 = 5; //M1 Speed Control
int E2 = 6; //M2 Speed Control
int M1 = 4; //M1 Direction Control
int M2 = 7; //M1 Direction Control
char input;
bool flag = 0;
int centerThreshold = 50; // Tolerance for steering
int xCenter = 320;
int distance = 100;
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
Servo myservo;
void setup(void) {
/* Setup baud rate for serial communication */
//Serial.begin(115200);
delay(100);
myservo.attach(8);
myservo.write(120);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
Serial.println("Hello World");
if (Serial.available() > 0) {
input = Serial.read();
/* Manual mode */
if (input == 'f' || input == 'b' || input == 'l' || input == 'r' || input == 's') {
manual();
/* Automatic mode */
else if (input == 'A') {
flag = 1;
automatic();
} else if (input == 'L') {
bootLeft();
} else if (input == 'R') {
bootRight();
} else if (input == 'C') {
camera();
/* Reading char 'M' on serial for stopping current mode */
void modeChange() {
if (input == 'M') {
Serial.println("Changing Mode ");
flag = 0;
stop();
/*Turn 180 Right */
void bootRight() {
Serial.println("Hard right turn");
hardRight();
stop();
/*Turn 180 Left */
void bootLeft() {
Serial.println("Hard left turn");
hardLeft();
stop();
/********************************************* MANUAL MODE ********************************************/
void manual() {
if (input == 'f') {
moveForward();
} else if (input == 'b') {
moveBackward();
} else if (input == 'l') {
turnLeft();
} else if (input == 'r') {
turnRight();
} else if (input == 's') {
stop();
/********************************************* AUTOMATIC MODE ********************************************/
void automatic(void) {
Serial.println(distance);
Serial.println("Automatic");
int distanceR = 0;
int distanceL = 0;
delay(40);
while (flag == 1) {
moveForward();
modeChange();
delay(100);
if (distance <= 20) {
stop();
delay(100);
moveBackward();
stop();
delay(200);
distanceR = lookRight();
delay(200);
distanceL = lookLeft();
delay(200);
if (distanceR >= distanceL) {
Serial.println("Turning Right");
turnRight();
moveForward();
Serial.println("Turning Left");
turnLeft();
moveForward();
void turnRight() {
analogWrite(E1, 155);
analogWrite(E2, 155);
digitalWrite(M1, LOW);
digitalWrite(M2, HIGH);
delay(1200);
digitalWrite(M1, HIGH);
void hardRight() {
delay(2400);
void turnLeft() {
digitalWrite(M2, LOW);
delay(1200);
void hardLeft() {
delay(2400);
void stop(void) //Stop
flag = 0;
Serial.println("Stoping");
digitalWrite(E1, 0);
digitalWrite(E2, 0);
void moveBackward() {
Serial.println("Moving backwards");
analogWrite(E2, 200);
analogWrite(E1, 200);
delay(5);
void moveForward() {
//Serial.println("Moving forwards");
analogWrite(E2, 200); //PWM Speed Control
delay(5);
int lookRight() {
myservo.write(50);
int distance = readPing();
delay(100);
myservo.write(120);
Serial.print("Looking right. Distance:");
return distance;
int lookLeft() {
myservo.write(170);
delay(100);
myservo.write(120);
Serial.print("Looking left. Distance:");
return distance;
int readPing() {
delay(70);
int cm = sonar.ping_cm();
if (cm == 0) {
cm = 250;
return cm;
/********************************************* Camera STATE MACHINE ********************************************/
void camera(void) {
while (!huskylens.begin(Wire)) {
Serial.println("Waiting ... ");
Serial.println("Huskylens not found! Check wiring.");
delay(100);
// Switch to Object Tracking mode
huskylens.switchAlgorithm(ALGORITHM_OBJECT_TRACKING);
Serial.println("Switching to tracking mode");
// Request results from the sensor
huskylens.getResult(ALGORITHM_OBJECT_TRACKING);
if (huskylens.available(ALGORITHM_OBJECT_TRACKING)) {
// Get the object closest to the center crosshair
auto target = huskylens.getCachedCenterResult(ALGORITHM_OBJECT_TRACKING);
///////////////// STATE MACHINE ///////////////////////////////////////
enum class State { Stoped,
Forward,
Left,
Right,
TooClose,
NoTarget };
class SimpleMachine {
State current = State::Stoped;
public:
switch (current) {
case State::Left:
if ((RET_ITEM_NUM(target, Result, xCenter)) < (320 - centerThreshold)) {
//Object on left: Turn Left
Serial.println(" Turning Left");
modeChange();
turnLeft();
case State::Right:
if ((RET_ITEM_NUM(target, Result, xCenter)) > (320 + centerThreshold)) {
//Object on right: Turn Right
Serial.println(" Turning Right");
modeChange();
turnRight();
case State::Forward:
//Move Forward
Serial.println(" Moving Forward");
modeChange();
moveForward();
case State::TooClose:
if ((RET_ITEM_NUM(target, Result, yCenter)) > 250) {
Serial.println("Too close");
case State::NoTarget:
Serial.println(" No Target");
And here are the errors:
C:\Projects\Book - 4 - Robots\Devastator Robot\Devastator_Robot_StateMachine\Devastator_Robot_StateMachine.ino: In function 'void camera()':
C:\Projects\Book - 4 - Robots\Devastator Robot\Devastator_Robot_StateMachine\Devastator_Robot_StateMachine.ino:300:5: error: 'huskylens' does not name a type
C:\Projects\Book - 4 - Robots\Devastator Robot\Devastator_Robot_StateMachine\Devastator_Robot_StateMachine.ino:301:5: error: expected unqualified-id before 'if'
C:\Projects\Book - 4 - Robots\Devastator Robot\Devastator_Robot_StateMachine\Devastator_Robot_StateMachine.ino:305:5: error: expected unqualified-id before 'switch'
switch (current) {
Multiple libraries were found for "Servo.h"
Used: C:\Users\Bill\Documents\Arduino\libraries\Servo
Not used: C:\Users\Bill\AppData\Local\Arduino15\libraries\Servo
exit status 1
Compilation error: 'huskylens' does not name a type
