NEED i2c scanner for Pi Pico (in Arduino)
Pi Pico (or Xiao)
Arduino IDE (also can use CircuitPy or MicroPy)
NEED i2c scanner for Pi Pico preferably in Arduino IDE C++
The standard I2c scanner example from the IDE should work, it is compatible with any arduino , including pico, I think
Tried it, monitor shows no contact. Ill try with more sda/clk combos. I cant tell what its hooked to
Do you mean Rpi Pico 2040?
Rpi2040 has flexible pins, you should setup your I2c bus first
Yes, pi pico
Also i have a seeed xiao
Both rp2040
I dont know how to set that up
Where to start?
(I am running an i2c oled)
