Hello, trying to program the first Pi pico rp2040 with a 0.96 single color oled screen. The problem I'm having is there are a few i2c lines it shows on the board. I don't know which ones do I use for the oled screen. Can someone please help me out to figure out which one and which code should I use to make this work?
@sonofcy Its been a while since I played around with i2c. When I got these pico boards in I didn't know which I2C I can use as a default i2c. I have tired the other pins and they did find them but not the default i2c pins. I tired GP4 and GP5 on the pin and it showed up as the default i2c pins. which I saw in one of the google search pages. So I have tried and got this as a result.
I2C Scanner
Scanning...
I2C device found at address 0x3C !
done
Thank you for the scanner. the old one I was using doesn't work. It works on my uncle and leonardo boards but not the pico boards.
@EmilyJane You are right my fault there. I did not post about the screen itself. It is a 0.96 white OLED screen. This is where I got mine from is Amazon in the USA.
Yes, those are the default (no code needed) I2C0 pins, but by specifying in the code you have 5 other sets (SDA, SDL) you can use. Then the I2C1 chan has 6 in total as well.
All data pins have I2C functionality.
Pins marked I2C0 correspond to Wire, and those marked I2C1 to Wire1.
The default physical pins on Pico for I2C0 (Wire) are 6 and 7, but keep in mind that you must reference the GPIOs (that is, 4 and 5 respectively).
however, you can use the Wire.setSDA() and Wire.setSCL() methods to aselect other pins
e.g. a BMP280 using SDA GPIO20 and SCL GPIO21
// Interfacing RPi pico RP2040 with BMP280 temperature and pressure sensor.
#include <Wire.h> // include Wire library, required for I2C devices
#include <Adafruit_Sensor.h> // include Adafruit sensor library
#include <Adafruit_BMP280.h> // include adafruit library for BMP280 sensor
// define device I2C address: 0x76 or 0x77 (0x77 is library default address)
#define BMP280_I2C_ADDRESS 0x76
// define I2C1 RP2040 pins for BMP280
#define SDA 20
#define SCL 21
Adafruit_BMP280 bmp280(&Wire1);
delay(3000);
Serial.println(F("RPi pico RP2040 + BMP280"));
Wire1.setSDA(SDA); // setup SDA and SCL pins
Wire1.setSCL(SCL);
Wire1.begin();
if (!bmp280.begin(BMP280_I2C_ADDRESS)) {
Serial.println("Could not find a valid BMP280 sensor, check wiring!");
while (1)
Serial.println("Found BMP280 sensor!");
// get temperature, pressure and altitude from library
float temperature = bmp280.readTemperature(); // get temperature
float pressure = bmp280.readPressure(); // get pressure
float altitude_ = bmp280.readAltitude(1013.25); // get altitude (this should be adjusted to your local forecast)
// print data on the serial monitor software
// 1: print temperature
Serial.print("Temperature = ");
Serial.print(temperature);
Serial.println(" °C");
// 2: print pressure
Serial.print("Pressure = ");
Serial.print(pressure / 100);
Serial.println(" hPa");
// 3: print altitude
Serial.print("Approx Altitude = ");
Serial.print(altitude_);
Serial.println(" m");
Serial.println(); // start a new line
delay(2000); // wait 2 seconds
serial monitor output
Temperature = 24.33 °C
Pressure = 1001.57 hPa
Approx Altitude = 97.70 m
Temperature = 24.69 °C
Pressure = 1001.64 hPa
Approx Altitude = 97.10 m
Temperature = 24.71 °C
Pressure = 1001.62 hPa
Approx Altitude = 97.24 m
