I am looking for sensors which can detect presence of human whether human is in motion or in rest? kindly give me some suggestions about human sensing sensors.
Thanks.
It's very hard to distinguish a human from any other similar-sized warm-blooded animal.
Are you allowed to attach anything to subject?
"If you are human , please press the big red button..."
Infrared sensor that only detects above 4 feet or so.
raschemmel:
"If you are human and read English, please press the big red button..."
English? French? Spanish? Italian? German? Other languages?
Hand-Arrow pointing to a button picture?
How about just a big shiny red button? No instructions needed. Put a blinking light above it, and you'll get nearly 100% detection.
I built a jacob's ladder (rising arc) in a mad scientist looking wooden box with blinking lights and two big rotary knobs on it. Even in an artshow with signs saying "don't touch", and a sign next to it that said "Hazardous voltage! Do not touch!", people would still turn the knobs and put their hand on the plexi over the arc.
Connect output of one of these, mounted on a servo to pan back & forth. Arduino controls panning, triggers a reading. Take measurement - pan a few degrees - take measurement - pan a few degrees, etc. Program for back & forth panning if not located in an open area.
http://www.homedepot.com/s/infrared+thermometer?NCNI-5
While a PIR sensor will only nominally detect movement, it is hard for some one to sit so still as to not trigger it.
Consider using a Rasberry Pi (or similar) with a camera and face detection software.
(If it is dark you could consider using IR cameras, but may have poor performance)
It would help a lot to provide a more comprehensive description of the problem you want to solve. (= more details)
CrossRoads:
if (identity == Sasquatch )
runLikeHell();
You need to tell us a bit more about your project.
I'd probably try webcam, capacitive sensing or pressure sensors (under the floor), depending on what the application is.
