Hello,
I am working on an automated gardening project using the arduino, and I have a few questions about valves and pumps. I have a water basin that I will need to drain periodically via the arduino, and I am trying to land on the best pump and valve combo to do that. I have heard people suggest solenoids for tasks like this but I am not sure if it is appropriate. The water basin will have liquid added to it for a minute about every 10 minutes. Currently I am using a 400 GPH pump, so I will need to drain around 6 and 2/3 gallons every ten minutes. I would like to drain the basin as quickly as possible. I'm thinking the solenoid is not needed because I don't want to store any water in the basin, just drain it as quickly as possible. Also, I think that using a gravity feed to drain the basin will not work as the liquid needs to return to another basin at a higher elevation. The best idea I can think of would be some sort of water level sensor, that when turned on signals a small pump to remove the water. I think this would have the added benefit of protecting the pump from running dry, which might be a concern when trying to drain a tank? I'm looking for advice on the feasibility of my method, or whether I should look in a different direction. Also, I would like some advice on what kind of pump would be ideal for my application?
Thanks
