Hi there,
I'm trying to hook up a motorized fader to my arduino, and I'm having a hard time getting the code together.
What I want is for the motorized fader to lock into a position specified by a fader on my other midi keyboard. That way I can control the position of the motorized fader by moving the keyboard's fader manually.
Here's the issue: I'm sending MIDI data from my keyboard into the Serial Monitor in one part of my code just fine, but when I use the same line in the next part of my code, the numbers in the Serial Monitor seem very off, and very jumpy. Note: The line that is commented out of the code is where I'm getting good readings. The next time I use Serial Monitor however, the numbers aren't quite right.
Here's the code (tried to reduce it as much as I could)
#include <AltSoftSerial.h>
#include <CapacitiveSensor.h>
AltSoftSerial midiSerial;
#define RXPIN 8
#define TXPIN 1
const int dir1PinA = 5;
const int dir2PinA = 6;
int faderValue = analogRead(A0);
int velocityByte;
CapacitiveSensor cs_7_2 = CapacitiveSensor(7, 2);
cs_7_2.set_CS_AutocaL_Millis(0xFFFFFFFF);
Serial.begin(250000);
midiSerial.begin(31250);
pinMode(dir1PinA, OUTPUT);
pinMode(dir2PinA, OUTPUT);
analogRead(faderValue);
analogWrite(3, 255);
int touchSensorLow = digitalRead(7);
int touchSensorHigh = digitalRead(2);
long start = millis();
long total = cs_7_2.capacitiveSensor(30);
if (total <= 1) {
motorControl();
else {
stopMotor();
while ( midiSerial.available() > 2 )
int commandByte = midiSerial.read();
int noteByte = midiSerial.read();
velocityByte = midiSerial.read();
midiSerial.write( commandByte);
midiSerial.write( noteByte);
midiSerial.write( velocityByte);
//Serial.println(velocityByte);
void motorControl() {
int sensorValue = analogRead(A0);
int number=500;
if (sensorValue <= number-5) {
moveMotorUp();
if (sensorValue >= number+5) {
moveMotorDown();
if (sensorValue == number) {
stopMotor();
void moveMotorUp() {
digitalWrite(dir1PinA, LOW);
digitalWrite(dir2PinA, HIGH);
delay(1);
digitalWrite(dir2PinA, LOW);
delay(1);
void moveMotorDown() {
digitalWrite(dir1PinA, HIGH);
delay(1);
delay(1);
void stopMotor() {
