This is a school project that I need help with.
I am trying to build a "Smart Home Hub" that displays time using RTC DS1307 and turn on LED using HC-05 Bluetooth Module. The RGB Matrix Board is supposed to display the time and status of the LED lights.
Eg. If "Bedroom Light" is turned on, a scrolling message will appear on the RGB Matrix Board displaying "Bedroom Light On".
The LED lights are buggy and I have no clue how to display the scrolling status message.
I'd appreciate any help in getting my project to work. Thank you in advanced.
Here is my code for the circuit :
#include <Arduino.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <Adafruit_GFX.h> // Core graphics library
#include <RGBmatrixPanel.h> // Hardware-specific library
#include <MD_DS1307.h>
#define CLK 11
#define OE 9
#define LAT 10
#define A A0
#define B A1
#define C A2
#define D A3
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false, 64); // Global variables
#define MAX_MESG 4
#define MAX_MES 20
unsigned int NewRTCh = 24;
unsigned int NewRTCm = 60;
unsigned int NewRTCs = 60;
char szTime[12]; // mm:ss\0
char szMesg[MAX_MESG+1] = "";
float Living_Room_Light = 0;
float Kitchen_Light = 0;
float Bedroom_Light = 0;
SoftwareSerial Bluetooth(12, 13); // RX|TX
char Data;
void sendData(String transmitData){
Bluetooth.println(transmitData);}
void getTime(char *psz, bool f = true) // Code for reading time
RTC.readTime();
if (NewRTCh != RTC.h)
sprintf(psz, "%02d", RTC.h);
matrix.setCursor(1, 4);
matrix.setTextSize(2);
matrix.setTextColor(matrix.Color333(7, 0, 0));
matrix.fillRect(1, 4, 64, 14, matrix.Color333(0, 0, 0));
matrix.print(szTime);
sprintf(psz, "%02d", RTC.m);
matrix.setCursor(27, 4);
matrix.fillRect(24, 4, 25, 14, matrix.Color333(0, 0, 0));
uint8_t y = 0;
NewRTCh=RTC.h;
else if (NewRTCm != RTC.m)
matrix.setCursor(20, 4);
matrix.fillRect(24, 8, 2, 6, matrix.Color333(0, 0, 0));
matrix.print(f ? ':' : ' ');
matrix.setCursor(51, 9);
matrix.setTextSize(1);
sprintf(psz, "%02d", RTC.s);
matrix.fillRect(51, 9, 11, 7, matrix.Color333(0, 0, 0));
NewRTCm=RTC.m;
else if (NewRTCs != RTC.s/10)
NewRTCs=RTC.s/10;
matrix.fillRect(57, 9, 5, 7, matrix.Color333(0, 0, 0));
void delaySeconds (int seconds)
delay(seconds*1000);
Bluetooth.begin(9600);
Bedroom_Light = 5;
Kitchen_Light = 6;
Living_Room_Light = 7;
pinMode(Bedroom_Light,OUTPUT);
pinMode(Kitchen_Light,OUTPUT);
pinMode(Living_Room_Light,OUTPUT);
matrix.begin();
matrix.setTextWrap(false);
RTC.control(DS1307_CLOCK_HALT, DS1307_OFF);
RTC.control(DS1307_12H, DS1307_OFF);
void _loop()
_loop();
static uint32_t lastime = 0; // Millis() memory
static bool flasher = false; // Seconds passing flasher
if (millis() - lastime >= 1000)
lastime = millis();
getTime(szTime, flasher);
flasher = !flasher;
Data = Bluetooth.read();
if(Data == '1')
digitalWrite(Bedroom_Light,HIGH);
sendData("Bedroom Light On");
if(Data== '2')
digitalWrite(Bedroom_Light,LOW);
sendData("Bedroom Light Off");
if(Data== '3')
digitalWrite(Kitchen_Light,HIGH);
sendData("Kitchen Light On");
if(Data == '4')
digitalWrite(Kitchen_Light,LOW);
sendData("Kitchen Light Off");
if(Data == '5')
digitalWrite(Living_Room_Light,HIGH);
sendData("Living Room Light On");
if(Data == '6')
digitalWrite(Living_Room_Light,LOW);
sendData("Living Room Light Off");
if(Data == '7')
sendData("All Lights On");
if(Data== '8')
sendData("All Lights Off");
_loop();
uint16_t Wheel(byte WheelPos)
if(WheelPos < 2)
return matrix.Color333(7, 0, 0);
else if(WheelPos < 5)
WheelPos -= 2;
return matrix.Color333(7 , 0, 0);
WheelPos -= 5;
