I don't know if this belongs here, or another place.
But I am banging my head trying to retrieve from my serial output in time with a python script that is controlling my test equipment. This setup is doing an auto calibration for me. I have two different python scripts, one that calibrates voltage and the other that calibrates current. I got the voltage calibration to work and output into a speadsheet. But the current calibration I can't get the timing right. I've tried continuously outputting serial data and timing it like I am now. I have tried quite a few different values in my python script for sleep as well.
Anyway. Here is the relevant section of the serial output from my sketch:
void SerialData() {
#ifdef CAL_DISCHARGE
serialTime = millis();
if (serialTime >= serialTime0 + 2500) {
serialTime0 = millis();
// Calibrate for Cell 1 voltage
if (C1.cell > 0.90) {
Serial.println(C1.cell, 6);
// Calibrate for Cell 2 voltage
} else if (C2.cell > 0.90) {
Serial.println(C2.cell, 6);
// Calibrate for current
Serial.println(Icurrent);
if (Serial.available()) { // Check if data is available to read
char command = Serial.read(); // Read the incoming byte as a character
if (command == 'C') { // Check for a specific command
calibrateQOV(); // Call a function when the command 'C' is received
#endif // end CAL_DISCHARGE
Here is my python script that works for voltage:
import pyvisa
import time
import serial
import pandas as pd
import numpy as np
from pymeasure.instruments.keithley import KeithleyDMM6500
# Define the IP address for the Keithley DMM
ip_address_dmm = "XXX.XXX.XXX.XXX"
# Initialize the DMM
dmm = KeithleyDMM6500(f"TCPIP::{ip_address_dmm}::inst0::INSTR")
# Initialize Serial
ser = serial.Serial('COM7', 115200)
# Initialize data storage
data_log = []
cell_voltages = []
dmm_readings = []
def main():
try:
time.sleep(1)
# Initialize the VISA resource manager
rm = pyvisa.ResourceManager()
instadd = "TCPIP::XXX.XXX.XXX.XXX::INSTR"
inst = rm.open_resource(instadd)
inst.write_termination = '\n'
inst.read_termination = '\n'
# Turn on the output
inst.write('OUTP CH1,ON')
inst.write(f'SOUR:VOLT:SET CH1,(2.0)')
time.sleep(1)
dmm.auto_range() # Adjusts range automatically
# Sweep through voltage settings and measure with DMM
for i in range(20, 46, 1):
voltage = i / 10.00 # Convert to float
inst.write(f'SOUR:VOLT:SET CH1,{voltage}')
time.sleep(0.10)
dmm_reading = dmm.voltage # Read voltage from DMM
time.sleep(0.1)
data = ser.readline().decode('utf-8').strip() # Read serial data
# Convert serial data to float if possible
try:
cell_voltage = float(data)
except ValueError:
cell_voltage = None # Skip if invalid
if cell_voltage is not None:
cell_voltages.append(cell_voltage)
dmm_readings.append(dmm_reading)
else:
print(f"Invalid data received: {data}")
print(f"Voltage set to {voltage}V, DMM reading: {dmm_reading}V, Cell Voltage: {cell_voltage}")
# Append data to log
data_log.append({
"Set Voltage (V)": voltage,
"DMM Reading (V)": dmm_reading,
"Cell Voltage": cell_voltage
time.sleep(1)
# Turn off the output
inst.write('OUTP CH1,OFF')
print("Measurements are done, closing connections")
except Exception as e:
print(f"An error occurred: {e}")
finally:
# Ensure the instrument connection is closed
try:
inst.close()
dmm.close()
except NameError:
pass # If inst was never initialized due to an earlier error
# Compute the best-fit polynomial
if cell_voltages and dmm_readings:
poly_degree = 1 # Adjust degree as needed (linear = 1, quadratic = 2, etc.)
coefficients = np.polyfit(cell_voltages, dmm_readings, poly_degree)
polynomial = np.poly1d(coefficients)
print(f"Polynomial Fit: {polynomial}")
# Apply the correction to measured values
corrected_values = [polynomial(v) for v in cell_voltages]
# Add corrected values to log
for i in range(len(data_log)):
data_log[i]["Corrected Cell Voltage"] = corrected_values[i]
else:
print("No valid data for polynomial fitting.")
# Save data to an Excel file
df = pd.DataFrame(data_log)
df.to_excel("measurement_results_with_polynomial.xlsx", index=False)
print("Data saved to measurement_results_with_polynomial.xlsx")
if __name__ == '__main__':
main()
And lastly, the one I am having trouble with. But the settings need to be the same on the sketch side for both, well, I guess they really don't, but for ease of use it would be nice, lol.
import pyvisa
import time
import serial
import pandas as pd
import numpy as np
import matplotlib.pyplot as plt
# Set DL3021(DL3031A) to DCLOAD
DCLOAD = rm.open_resource("TCPIP::XXX.XXX.XXX.XXX::INSTR")
# Initialize Serial
ser = serial.Serial('COM7', 115200, timeout=2)
data_log = []
def main():
try:
time.sleep(4)
ser.write(b'C') # 'b'A'' sends the byte 'A' over serial
DCLOAD.write(':SOUR:CURR:RANG 6')
# Sweep through Current range 4.0 - 5.5A in steps of 0.5A
for i in range(40, 56, 5): # Steps of 0.5A (4.0A, 4.5A, ..., 5.5A)
current = i / 10.00 # Convert to float
DCLOAD.write(f':SOUR:CURR:LEV:IMM {current}')
DCLOAD.write(':SOUR:INP:STAT 1')
time.sleep(2.0)
scaled_reading = dmm_reading * 2000 # Multiply by 2000
# Read serial data for Icurrent
try:
serial_data = ser.readline().decode('utf-8').strip() # Read and decode
Icurrent = float(serial_data) if serial_data else None # Convert to float
except ValueError:
Icurrent = None # Handle non-numeric data
# Store data
data_log.append({
"Current (A)": current,
"Voltage (V)": dmm_reading,
"Scaled Voltage (V * 2000)": scaled_reading,
"Icurrent (Serial)": Icurrent
# Print data to the screen
print(f"Current (A): {current}, Voltage (V): {dmm_reading}, Scaled Voltage (V * 2000): {scaled_reading}, Icurrent (Serial): {Icurrent}")
DCLOAD.write(':SOUR:INP:STAT 0')
time.sleep(1)
time.sleep(1)
# Sweep through Current range 6.0 - 45.0A in steps of 0.5A
for i in range(60, 451, 5): # Steps of 0.5A (6.0A, 6.5A, ..., 45.0A)
current = i / 10.00 # Convert to float with one decimal place
DCLOAD.write(':SOUR:CURR:RANG 60')
time.sleep(2.0)
try:
except ValueError:
# Store data
data_log.append({
time.sleep(2)
time.sleep(2)
finally:
try:
DCLOAD.close()
dmm.close()
ser.close()
print(f"Error closing instruments: {e}")
df.to_excel("Current_Cal.xlsx", index=False)
# Polynomial Approximation
fit_polynomial(df)
def fit_polynomial(df):
"""Fit a polynomial to Icurrent vs. Scaled Voltage"""
df = df.dropna() # Remove rows with missing values
if len(df) < 2:
print("Not enough data for polynomial fitting.")
return
x = df["Scaled Voltage (V * 2000)"].values
y = df["Icurrent (Serial)"].values
# Fit a second-degree polynomial (quadratic fit)
coeffs = np.polyfit(x, y, 1) # Use degree 1 for linear fit, 2 for quadratic, etc.
poly_eq = np.poly1d(coeffs)
# Generate fit values
x_fit = np.linspace(min(x), max(x), 100)
y_fit = poly_eq(x_fit)
# Print polynomial equation
print("Fitted Polynomial Equation:")
print(poly_eq)
# Plot data and fit curve
plt.scatter(x, y, label="Measured Data", color="blue")
plt.plot(x_fit, y_fit, label=f"Polynomial Fit: {poly_eq}", color="red")
plt.xlabel("Scaled Voltage (V * 2000)")
plt.ylabel("Icurrent (Serial)")
plt.title("Polynomial Fit of Icurrent vs. Scaled Voltage")
plt.legend()
plt.grid(True)
plt.show()
# Run the main function
if __name__ == "__main__":
main()
Sample output from the cmd line running the python script. When I setup the voltage cal, the same thing happened, it is like the output from the serial is way behind, which is why I added the updates. Funny thing, I originally figured that since the output was behind, I would make the serial update faster, but that made it worse.
Current (A): 4.5, Voltage (V): 0.00225574, Scaled Voltage (V * 2000): 4.51148, Icurrent (Serial): 3.93
Current (A): 5.0, Voltage (V): 0.00250311, Scaled Voltage (V * 2000): 5.00622, Icurrent (Serial): 4.17
Current (A): 5.5, Voltage (V): 0.002752242, Scaled Voltage (V * 2000): 5.504484, Icurrent (Serial): 0.0
Current (A): 6.0, Voltage (V): 0.003002149, Scaled Voltage (V * 2000): 6.004298, Icurrent (Serial): 0.01
Current (A): 6.5, Voltage (V): 0.003253038, Scaled Voltage (V * 2000): 6.506076, Icurrent (Serial): 5.43
Current (A): 7.0, Voltage (V): 0.003504164, Scaled Voltage (V * 2000): 7.008328000000001, Icurrent (Serial): 5.43
Current (A): 7.5, Voltage (V): 0.003754905, Scaled Voltage (V * 2000): 7.50981, Icurrent (Serial): 5.61
Current (A): 8.0, Voltage (V): 0.004005878, Scaled Voltage (V * 2000): 8.011756, Icurrent (Serial): 0.0
Current (A): 8.5, Voltage (V): 0.004256282, Scaled Voltage (V * 2000): 8.512564000000001, Icurrent (Serial): 0.0
Thanks in advance
