Need to an .HEX example file for test OLED(SSD1306)
Hi everybody
Guys, I need to a .HEX file for test my OLED. I have designed an adaptor for it but I don't know that is it well or not! my OLED is 0.96" 128x64 with SSD1306 driver and my MCU is ATMEGA32A. I need for SPI(4 wire) bus.
Hi
There are still some questions:
  • What is your board (Arduino Uno, i assume)?
  • How is the OLED connected to Arduino Uno: What are the four pin numbers?
  • Is the OLED in the correct operation mode for SPI?
  • Probably it will display "something", but to obtain a correct picture, the correct type of the OLED is also important.
Which lib did you use so far? From the feedback i got so far, i think U8glib should at least display something.
Oliver
Thanks Oliver for reply
In fact, I don't have any board! I have just one ATMEGA32A.
My Code is this(my Compiler is CodeVision):
Chip type               : ATmega32A
Program type            : Application
AVR Core Clock frequency: 16.000000 MHz
Memory model            : Small
External RAM size       : 0
Data Stack size         : 512
#include <mega32a.h>
#include <delay.h>
// SPI functions
#include <spi.h>
#define	Brightness	0xCF
#define CSN	PORTA.2
#define DC	PORTA.0
#define RST	PORTA.1
// Declare your global variables here
void OLED_Init_I();
void Fill_RAM(unsigned char Data);
void main(void)
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=Out Func1=Out Func0=Out
// State7=T State6=T State5=T State4=T State3=T State2=0 State1=0 State0=0
PORTA=0x00;
DDRA=0x07;
// Port B initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=In Func2=In Func1=In Func0=In
// State7=0 State6=0 State5=0 State4=0 State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0xF0;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0x00;
// SPI initialization
// SPI Type: Master
// SPI Clock Rate: 4000.000 kHz
// SPI Clock Phase: Cycle Start
// SPI Clock Polarity: Low
// SPI Data Order: MSB First
SPCR=0x50;
SPSR=0x00;
OLED_Init_I();
while (1)
        Fill_RAM(0xFF);
        delay_ms(1000);
        Fill_RAM(0x00);
        delay_ms(1000);  // Place your code here
void spi_transfer_nr(unsigned char data)
        DC=0;
        SPDR = data;
        while(!(SPSR & (1<<SPIF)));
    void spi_transfer_nr1(unsigned char data)
        DC=1;
        SPDR = data;
    void Set_Display_On_Off(unsigned char d)
        spi_transfer_nr(0xAE|d);            // Set Display On/Off
                        //   Default => 0xAE
                        //     0xAE (0x00) => Display Off
                        //     0xAF (0x01) => Display On
    void Set_Display_Clock(unsigned char d)
        spi_transfer_nr(0xD5);            // Set Display Clock Divide Ratio / Oscillator Frequency
        spi_transfer_nr(d);            //   Default => 0x80
                        //     D[3:0] => Display Clock Divider
                        //     D[7:4] => Oscillator Frequency
    void Set_Multiplex_Ratio(unsigned char d)
        spi_transfer_nr(0xA8);            // Set Multiplex Ratio
        spi_transfer_nr(d);            //   Default => 0x3F (1/64 Duty)
    void Set_Display_Offset(unsigned char d)
        spi_transfer_nr(0xD3);            // Set Display Offset
        spi_transfer_nr(d);            //   Default => 0x00
    void Set_Start_Line(unsigned char d)
        spi_transfer_nr(0x40|d);            // Set Display Start Line
                        //   Default => 0x40 (0x00)
    void Set_Charge_Pump(unsigned char d)
        spi_transfer_nr(0x8D);            // Set Charge Pump
        spi_transfer_nr(0x10|d);            //   Default => 0x10
                        //     0x10 (0x00) => Disable Charge Pump
                        //     0x14 (0x04) => Enable Charge Pump
    void Set_Addressing_Mode(unsigned char d)
        spi_transfer_nr(0x20);            // Set Memory Addressing Mode
        spi_transfer_nr(d);            //   Default => 0x02
                        //     0x00 => Horizontal Addressing Mode
                        //     0x01 => Vertical Addressing Mode
                        //     0x02 => Page Addressing Mode
    void Set_Segment_Remap(unsigned char d)
        spi_transfer_nr(0xA0|d);            // Set Segment Re-Map
                        //   Default => 0xA0
                        //     0xA0 (0x00) => Column Address 0 Mapped to SEG0
                        //     0xA1 (0x01) => Column Address 0 Mapped to SEG127
    void Set_Common_Remap(unsigned char d)
        spi_transfer_nr(0xC0|d);            // Set COM Output Scan Direction
                        //   Default => 0xC0
                        //     0xC0 (0x00) => Scan from COM0 to 63
                        //     0xC8 (0x08) => Scan from COM63 to 0
    void Set_Common_Config(unsigned char d)
        spi_transfer_nr(0xDA);            // Set COM Pins Hardware Configuration
        spi_transfer_nr(0x02|d);            //   Default => 0x12 (0x10)
                        //     Alternative COM Pin Configuration
                        //     Disable COM Left/Right Re-Map
    void Set_Contrast_Control(unsigned char d)
        spi_transfer_nr(0x81);            // Set Contrast Control
        spi_transfer_nr(d);            //   Default => 0x7F
    void Set_Precharge_Period(unsigned char d)
    spi_transfer_nr(0xD9);            // Set Pre-Charge Period
    spi_transfer_nr(d);            //   Default => 0x22 (2 Display Clocks [Phase 2] / 2 Display Clocks [Phase 1])
                        //     D[3:0] => Phase 1 Period in 1~15 Display Clocks
                        //     D[7:4] => Phase 2 Period in 1~15 Display Clocks
    void Set_VCOMH(unsigned char d)
        spi_transfer_nr(0xDB);            // Set VCOMH Deselect Level
        spi_transfer_nr(d);            //   Default => 0x20 (0.77*VCC)
    void Set_Entire_Display(unsigned char d)
        spi_transfer_nr(0xA4|d);            // Set Entire Display On / Off
                        //   Default => 0xA4
                        //     0xA4 (0x00) => Normal Display
                        //     0xA5 (0x01) => Entire Display On
    void Set_Inverse_Display(unsigned char d)
        spi_transfer_nr(0xA6|d);            // Set Inverse Display On/Off
                        //   Default => 0xA6
                        //     0xA6 (0x00) => Normal Display
                        //     0xA7 (0x01) => Inverse Display On
    void Set_Start_Column(unsigned char d)
        spi_transfer_nr(0x00+d%16);        // Set Lower Column Start Address for Page Addressing Mode
                        //   Default => 0x00
        spi_transfer_nr(0x10+d/16);        // Set Higher Column Start Address for Page Addressing Mode
                        //   Default => 0x10
    void Set_Start_Page(unsigned char d)
        spi_transfer_nr(0xB0|d);            // Set Page Start Address for Page Addressing Mode
                        //   Default => 0xB0 (0x00)
        unsigned char i,j;
            for(i=0;i<8;i++)
                Set_Start_Page(i);
                Set_Start_Column(0x00);
                for(j=0;j<128;j++)
                    spi_transfer_nr1(Data);
    void OLED_Init_I()				// VCC Generated by Internal DC/DC Circuit
        unsigned char i;
	    RST=0;
	    for(i=0;i<200;i++)
		    delay_us(200);
		    //uDelay(200);
	    RST=1;
	    Set_Display_On_Off(0x00);		// Display Off (0x00/0x01)
	    Set_Display_Clock(0x80);		// Set Clock as 100 Frames/Sec
	    Set_Multiplex_Ratio(0x3F);		// 1/64 Duty (0x0F~0x3F)
	    Set_Display_Offset(0x00);		// Shift Mapping RAM Counter (0x00~0x3F)
	    Set_Start_Line(0x00);			// Set Mapping RAM Display Start Line (0x00~0x3F)
	    Set_Charge_Pump(0x04);			// Enable Embedded DC/DC Converter (0x00/0x04)
	    Set_Addressing_Mode(0x02);		// Set Page Addressing Mode (0x00/0x01/0x02)
	    Set_Segment_Remap(0x01);		// Set SEG/Column Mapping (0x00/0x01)
	    Set_Common_Remap(0x08);			// Set COM/Row Scan Direction (0x00/0x08)
	    Set_Common_Config(0x10);		// Set Sequential Configuration (0x00/0x10)
	    Set_Contrast_Control(Brightness);	// Set SEG Output Current
	    Set_Precharge_Period(0xF1);		// Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
	    Set_VCOMH(0x40);			// Set VCOM Deselect Level
	    Set_Entire_Display(0x00);		// Disable Entire Display On (0x00/0x01)
	    Set_Inverse_Display(0x00);		// Disable Inverse Display On (0x00/0x01)
	    Fill_RAM(0x00);				// Clear Screen
	    Set_Display_On_Off(0x01);		// Display On (0x00/0x01)
Hmm... still difficult. My environment differs a lot from your setup and I do not have such MCU.
What about classical debug options? Use a scope/logic analyzer to check the signals.
Reset --> should be high most of the time
Clock --> regular up and down
Data --> not so regular up and down
A0/RS --> less freqent up and down
CS --> very less frequent up and down (depends on your code)
BTW: I assume CS is CSN in your code, but it seems that it is not used. Chip select is very important, as it resynchronizes the SPI transfer. Maybe you just missed this.
Oliver
Do you have a sample program+HEX file for testing my OLED that works on other interfaces(I2C or 8080 or 6800)(by ATMEGA32 or ATMEGA8 MCU)?
I do not have such CPUs available...
But even if i would be able to generate the hex file for this type of MCU, you did not answer my previous questions. In order to produce some suitable hex file, it is mandatory to know exactly the type of your display and how your display is connected.
If you do not provide this information, nobody will be able to help you.
Oliver
