Need to update potentiometer all the time
Potentiometer value is updated only before pressing button gotoPositionAPin or gotoPositionBPin can't change value of speed and aceleration during go to position.
 Stepper Motor Single Channel Manual Controller
 language: Wiring/Arduino
 This program drives a single bi-polar stepper motor using an EasyDriver
 stepper motor controller from SparkFun.
 It takes input from a set of switches and potentiometers.
 The goal is to create smooth motion of the steppper motor without having a
 PC attached to the Arduino.
 The motor moves 1600 steps in one rotation. (8th step microstepping on a 200 s/r motor)
 Created 08/18/2010
 by Brian Schmalz
 Version 0.2  01/30/2011  Added accel/decl
 Version 0.3  10/09/2011  Fixed two bugs found by Daniel Schweinert:
                           1) Speed Pot not working during Rotate Left or Rotate Right moves
                           2) When Goto A or Goto B is pressed after using Rotate Left or Right, motor moves in the
                           wrong directly for a little bit before moving in the right direction.
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <AccelStepper.h>
#define OLED_Address 0x3C
Adafruit_SSD1306 oled(1);
AccelStepper stepper1(1, 12, 11);
#define stepsPerRev      5000
#define stepPin          12
#define dirPin           11
#define ledPin           13
#define rotateLeftPin    7
#define rotateRightPin   6
#define savePositionAPin 5
#define savePositionBPin 4
#define gotoPositionAPin 3
#define gotoPositionBPin 2
#define maxSpeedPin      0
#define accelPin         1
// Set this to zero if you don't want debug messages printed
#define printDebug       1
// These are the constants that define the speed associated with the MaxSpeed pot
#define MAX_STEPS_PER_SECOND  1000    // At 200 s/r and 1/8th microstepping, this will be 333 rev/minute
#define MIN_STEPS_PER_SECOND  27      // At 200 steps/rev and 1/8th microstepping, this will be 1 rev/minute
// Change this value to scale the acceleration pot's scaling factor
#define ACCEL_RATIO           1
int buttonState = 0;
int stepNumber = 0;
int curSpeed = 100;
int dir = 0;
int maxSpeed = 0;
int accel = 0;
long savedPosA = 0;
long savedPosB = 0;
int loopCtr = 0;
float fMaxSpeed = 0.0;
float fStepsPerSecond = 0.0;
  oled.begin(SSD1306_SWITCHCAPVCC, OLED_Address);
  pinMode(stepPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(rotateLeftPin, INPUT);
  pinMode(rotateRightPin, INPUT);
  pinMode(savePositionAPin, INPUT);
  pinMode(savePositionBPin, INPUT);
  pinMode(gotoPositionAPin, INPUT);
  pinMode(gotoPositionBPin, INPUT);
  if (printDebug)
    // Initialize the Serial port
  // blink the LED:
  blink(2);
  stepper1.setMaxSpeed(800.0);
  stepper1.setAcceleration(600.0);
  // Grab both speed and accel before we start
  maxSpeed = analogRead(maxSpeedPin);
  // Do the math to scale the 0-1023 value (maxSpeed) to
  // a range of MIN_STEPS_PER_SECOND to MAX_STEPS_PER_SECOND
  fMaxSpeed = maxSpeed / 1023.0;
  fStepsPerSecond = MIN_STEPS_PER_SECOND + (fMaxSpeed * (MAX_STEPS_PER_SECOND - MIN_STEPS_PER_SECOND));
  if (fStepsPerSecond > 1000)
    fStepsPerSecond = 1000;
  accel = analogRead(accelPin)/ACCEL_RATIO;
  oled.clearDisplay();
  oled.setTextSize(1);             // Normal 1:1 pixel scale
  oled.setTextColor(WHITE);
  // First, we need to see if either rotate button is down. They always take precidence.
  if(digitalRead(rotateLeftPin))
    stepper1.setSpeed(-fStepsPerSecond);
    while(digitalRead(rotateLeftPin))
      CheckPots();
      stepper1.runSpeed();
  else if (digitalRead(rotateRightPin))
    stepper1.setSpeed(fStepsPerSecond);
    while(digitalRead(rotateRightPin))
      CheckPots();
  // Go see if we need to update our analog conversions
  CheckPots();
  // Check to see if user is trying to save position A or B
  if(digitalRead(savePositionAPin))
    savedPosA = stepper1.currentPosition();
    if (printDebug)
      oled.setCursor(1, 10);
      oled.print("Saved A at : ");
      oled.println(savedPosA);
      oled.display();
    while(digitalRead(savePositionAPin));
  if(digitalRead(savePositionBPin))
    savedPosB = stepper1.currentPosition();
    if (printDebug)
      oled.setCursor(10, 10);
      oled.print("Saved B at : ");
      oled.println(savedPosB);
      oled.display();
    while(digitalRead(savePositionBPin));
  // Check to see if the user wants to go to position A or B
  if (digitalRead(gotoPositionAPin))
    if (printDebug)
      // Yup, let's go to position A
      oled.setCursor(10, 0);
      oled.print("cur pos = ");
      oled.println(stepper1.currentPosition());
      oled.print("Going to A = ");
      oled.print("Speed = ");
      oled.println(fStepsPerSecond);
      oled.print("Accel = ");
      oled.println(accel);
      oled.display();
    stepper1.setAcceleration(0);
    stepper1.runToNewPosition(stepper1.currentPosition());
    stepper1.setMaxSpeed(fStepsPerSecond);
    stepper1.setAcceleration(accel);
    stepper1.runToNewPosition(savedPosA);
    if (printDebug)
       oled.setTextSize(2);             // Normal 1:1 pixel scale
      oled.print("new pos = ");
      oled.display();
    while(digitalRead(gotoPositionAPin));
  else if (digitalRead(gotoPositionBPin))
    // Yup, let's go to position B
    if (printDebug)
      oled.setCursor(0, 0);
      oled.print("Going to B = ");
      oled.display();
    stepper1.runToNewPosition(savedPosB);
    if (printDebug)
      oled.display();
    while(digitalRead(gotoPositionBPin));
// Blink the reset LED:
void blink(int howManyTimes)
  int i;
  for (i=0; i < howManyTimes; i++)
    digitalWrite(ledPin, HIGH);
    delay(200);
    digitalWrite(ledPin, LOW);
    delay(200);
void CheckPots(void)
  loopCtr++;
  // Only read these once in a while because they take a LONG time
  if (loopCtr == 100)
  // Read in the acceleration analog value
  // This needs to be scaled too, but to what?
  if (loopCtr >= 200)
    loopCtr = 0;
You will have to completely redesign the program logic to do that. Would be much simpler and quicker to write a whole new program. Start with a flowchart showing the logic you need.
Could it be because 'CheckPots(void)' does nothing 199 out of 200 times it is called?
this is schema of all buttons and potentiometers
And a flowchart of your new logic?
everything works fine except speed change during going to position
And once the code sets the speed for the library, how would you change it?
no idea
And that is why you need to rework the program logic so you can do what you want.
runToPosition()
Moves the motor (with acceleration/deceleration) to the new target position and blocks until it is at position. Dont use this in event loops, since it blocks.
so you'll have to use other non-blocking features of the library and keep your own track of whether it is arrived or not.
a7
the general approach of accelstepper has two flaws and you can only choose which flaw of the two flaws you want to accept:
either the flaw of beeing blocking
or
the flaw of requiring that all the rest of the code has to execute the whole loop faster than step-pulses must be created.
There is a different library for driving stepper-motors that has a different approach which of course has a different limitation.
This approach is to use a timer-interrupt tp create the step-pulses in the background.
This means your code can do things in "parallel" to creating the step-pulses.
This library can even change stepper-speed at any point even in the middle of a movement.
The cost of this is that a hardware-timer is occupied and can't be used for other things.
This library is called MobaTools and can be installed with the library-manager of the Arduino-IDE
best regards Stefan
cool lib but main problem that anotation is in german
use google translate or read the english documentation
MobaTools-243-en.pdf
in the library-folder
