Hi guys I'm a newbie, I need you to check if the codes I've written are correct... coz I'm not sure what's the problem.. I was supposed to come up with a HIGH value in (Arduino nano) pin8 only when pin 2 (input) send a high value (i used 5vdc, and then the LOW value of pin2 is 1.2vdc and HIGH value of 4vdc...)
But the problem here is that the output reading starts with a LOW value and even if a haven't set up a HIGH value yet on pin2 (input), pin8 (output) goes high for 3 to 4 seconds and then returns to zero.. this goes on and on... However, if a send a HIGH value to the Input pin2, the HIGH output is ok...
I'm confused why Im having a HIGH output even I haven't done in the INPUT...
Here are the codes....
//assign variables
int lev1 = 2; //input from ckt1
int alert1 = 8; //1st LED alarm output
// initialize input ckt pins as input:
pinMode(lev1, INPUT);
// initialize alarm LEDs as outputs
pinMode(alert1, OUTPUT);
// read input pins:
int voltagevalue = digitalRead(lev1);
if (voltagevalue == HIGH)
digitalWrite(alert1, HIGH);
digitalWrite(alert1, LOW);
Serial.println(voltagevalue);
