Nema 23 and TB 6600 help guidance
learn to read instead of complain over peoples posts!
I read the topics you replied to earlier people not helpful at all.
good luck
Also no one else have issues to read my post you are the problem.
So dont say it useless label of post or label.
next time read it instead.
"kg" is not a unit of torque. Did you mean kg-cm?
If 75 is not fast enough then you need a different motor. So don't waste your money on drivers or power supplies that may not work.
Yes, I meant kg-cm. I actually need 6 to 10 kg-cm of torque.
What DIP switch settings should I use for that?
Thanks a lot for heads-up Yeah I will see how it goes with this solution very appreciated.
The torque/speed characteristics of you motor does not depend on those switch settings.
See post #18
If 75RPM is not fast enough, there is nothing you can do.
Set microstepping to 8 if you need it, none if you don't. Set current to max of your motor (2.8A).
Get 36V (min. 120W) power supply. That gives you max of your actual driver-motor combo.
Much too much. The stepper (2.8A and 0.9 Ohm per coil) needs (2.8x2.8x0.9) 7W per coil. That's 14W for both coils. Add some safety margin for driver losses and mechanical work, so 30-40W should at all be sufficent.
thanks a lot I will check out! very appreciated!
Doesn't matter what size supply or what driver you use, you won't get more torque than the motor can supply for a given speed.
So the TB 6600 works fine even when its 12V?
Little bit confused since most people says its to low voltage.
See post #31, 26, 23, 18 and 8
Depends on the speed you need. With higher voltage you get less torque drop at higher speeds.
This is the behaviour at 24V:
