I recently got my first ever Arduino, it is an Arduino Giga R1 Wifi, a Nema 23 stepper motor (23HS45-4204S from StepperOnline) and a suitable driver (DM556Y from StepperOnline).
The driver gets power from a 48v 20a ac-dc power supply. The driver is set to 400 steps/rev. In the program seen below I'm trying to make the stepper motor do 1 full rotation (meaning 400 steps).
However, during testing I've noticed, that the stepper rotates less (each time by a different amount).
I've tried giving the motor more power from the drive (the motor is rated for 4.2a, I've tried 3.1-4.3a, 3.5-4,9 and even 4.0-5.6a), but there was no difference.
#include <AccelStepper.h>
#define dir 2
#define pul 22
AccelStepper stepper1(1,pul,dir);
stepper1.setMaxSpeed(1000);
stepper1.setAcceleration(200);
stepper1.moveTo(400);
stepper1.run();
When I start the program and images of the circuit:
The former link leads to a site where you can download the .mp4 and .png files:
I have tried using another Nema 23 (same model) and a different driver (same model) but just got the same results. I'd we incredibly happy if someone can help me to solve the problem I have.
welcome to the arduino-forum.
You have posted a picture and a code-section of your code.
Always post code as code-section.
Use smaller values for a basic test.
It might be that your acceleration is too high
// Bounce.pde
// -*- mode: C++ -*-
// Make a single stepper bounce from one limit to another
// Copyright (C) 2012 Mike McCauley
// $Id: Random.pde,v 1.1 2011/01/05 01:51:01 mikem Exp mikem $
// Define a stepper and the pins it will use
//AccelStepper stepper; // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3, 4, 5
AccelStepper stepper1(AccelStepper::DRIVER,pul,dir);
stepper.setMaxSpeed(100);
stepper.setAcceleration(20);
stepper.moveTo(400);
// If at the end of travel go to the other end
if (stepper.distanceToGo() == 0)
stepper.moveTo(-stepper.currentPosition());
stepper.run();
Thanks for the quick response. I've now decreased the values as you said, but still, the motor is not moving accurately.
When I execute the sketch, the motor starts spinning but jitters a bit, is skipping some steps and sometime makes a click.
You should really post pictures of your setup
For posting pictures you have to do a few things that are easy to do
You have to reach trustlevel 1 through these activities:
Get to trust level 1 by…
clicking on 5 different threads
reading 30 postings (they must have been visible on the screen)
beeing a minimum time of 10 minutes in the forum
Post the exact type of stepper-motor. There are unipolar and bipolar stepper-motors
They must be wired differently.
Additionally: never connect / disconnect the motorwires with powersupply switched on
Disconnecting under power causes high voltage spikes like on an electric fence that can destroy the stepper-driver
@jacobutermoehlen
The DM556Y DIR and STEP inputs require 5V at up to 15mA
The GIGA can only provide 3.3V at 8mA
You will need an interface circuit for reliable operation
I have updated my post. but because I'm new I couldn't post enough images. Thats why I included a link where you can download the files and a video. Sorry for the compromise.
Thanks for all the quick responses. Ok, how can I get higher Amps out of my Giga, do I need extra components? Or even a new board, would a Teensy 4.1be fine?
Thanks @jim-p and @StefanL38 for the quick responses. I bet your suggestions will work perfectly, unfortunately I accidentally fried my Arduino Giga R1 Wifi.
To use transistors for each of the -pins sound impractical, I've searched a bit, and it is possible to use a level-shifter, right. If I have a power supply, which outputs 12V what is a good and cheap one?
Since you fried the GIGA why don't you buy a board that uses 5V?
Level shifters will not work.
Why is a transistor circuit impracticle, it's just one transistor and one resistor.
