Hello,
Disclaimer: this is my first project using a controller with LED strip and C++ so please bare with me.
The plan is to have a long WS2812B addressable LED strip split into two parts using Adafruit_NeoPixel library.
It is controlled via Wemos D1 controller, which runs a webserver allowing me to control the lights via a web requests.
Here's a schematic of the wiring
Here's the code that my controller runs:
// load led lib
// Load Wi-Fi library
#include <ESP8266WiFi.h>
// load filesystem lib
#include <FS.h>
// define web server
#include <ESP8266WebServer.h>
// Define led strip
#define LED_COUNT1 75
#define LED_COUNT2 75
#define PIN D4
Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(LED_COUNT1, PIN, NEO_GRB | NEO_KHZ800);
Adafruit_NeoPixel strip2 = Adafruit_NeoPixel(LED_COUNT2, PIN, NEO_GRB | NEO_KHZ800);
// wifi info
const char* ssid = "my_wifi_name";
const char* password = "my_wifi_password";
// start webserver I guess?
ESP8266WebServer server;
// STATE
// strip 1
bool state_on = false;
uint16_t state_hue = 65536/6;
uint8_t state_saturation = 255;
uint8_t state_value = 255;
// strip 2
bool state_on2 = false;
uint16_t state_hue2 = 65536/6;
uint8_t state_saturation2 = 255;
uint8_t state_value2 = 255;
String boolToString(bool val) {
if (val == false) {
return "false";
return "true";
bool stringToBool(String val) {
if (val == "false") {
return false;
return true;
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH); // TODO set off by default
SPIFFS.begin();
// setup strip 1
strip1.begin();
strip1.setBrightness(255);
strip1.fill(strip1.Color(0, 0, 0), 0);
strip1.show();
// setup strip 2
strip2.begin();
strip2.setBrightness(255);
strip2.fill(strip2.Color(0, 0, 0), 0);
strip2.show();
// Connect to Wi-Fi network with SSID and password
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
// SERVER ROUTES
server.on("/", HTTP_GET, serveIndexFile);
server.on("/getLightState", HTTP_GET, getLightState);
server.on("/light/switch", HTTP_GET, setLightOnState);
server.on("/light/color", HTTP_POST, setStripColor);
server.begin();
// RETURN JSON
void getLightState()
String state = "{\"on\":" + boolToString(state_on) + ", \"hue\": " + state_hue + ", \"saturation\": " + state_saturation + ", \"value\": " + state_value
+ ", \"on2\":" + boolToString(state_on2) + ", \"hue2\": " + state_hue2 + ", \"saturation2\": " + state_saturation2 + ", \"value2\": " + state_value2 + "}";
server.send(200,"text/plain", state);
void serveIndexFile()
File file = SPIFFS.open("/index.html","r");
server.streamFile(file, "text/html");
file.close();
void fillAndShowStrips () {
strip1.fill(strip1.gamma32(strip1.ColorHSV(state_hue, state_saturation, state_on ? state_value : 0)));
strip1.show();
strip2.fill(strip2.gamma32(strip2.ColorHSV(state_hue2, state_saturation2, state_on2 ? state_value2 : 0)));
strip2.show();
void setLightOnState() {
bool firstOn = stringToBool((server.arg("on").c_str()));
bool secondOn = stringToBool((server.arg("on2").c_str()));
state_on = firstOn;
state_on2 = secondOn;
fillAndShowStrips();
server.send(200);
void setStripColor () {
// set strip 1
int newHue = std::atoi (server.arg("hue").c_str());
int newSaturation = std::atoi (server.arg("saturation").c_str());
int newValue = std::atoi (server.arg("value").c_str());
state_hue = newHue;
state_saturation = newSaturation;
state_value = newValue;
// set strip 2
int newHue2 = std::atoi (server.arg("hue2").c_str());
int newSaturation2 = std::atoi (server.arg("saturation2").c_str());
int newValue2 = std::atoi (server.arg("value2").c_str());
state_hue2 = newHue2;
state_saturation2 = newSaturation2;
state_value2 = newValue2;
server.send(200);
void loop(){
server.handleClient();
The problem:
For development I've used shorter 1m LED strip and everything worked flawlessly.
For the final product, I've connected the 5m LED strip (from a different brand) and set LED strip1/strip2 to be 75 LEDs each. In the code that is:
Unfortunately, only strip2 reacts to changes and it is displayed from 1st to 75th LED. Leaving the other half of the LED strip off.
If I set strip1/strip2 to be 1/149 LEDs, then again, first 149 light up and react to strip2 changes, and the last LED in the strip remains off.
Here's the interesting part - if I set the strip1/strip2 to be a low amount of LEDs, let's say 20/20, then it all works completely fine.
Since everything works completely fine with "small" strip1/strip2, I would guess that the problem is something with the hardware? Damaged data input?
But then if I set strips to 1/149 I can controll all but the last LED just fine. That kinda makes it sound like the data input is fine?
