Neopixel sketch to control 2 strips differently
I can turn on and control a Neopixel strip no problem. I want to be able to control two separate neopixel strips. Strip one and strip two. Have strip one turn on and be red, delay or wait X seconds then be blue. Strip two would turned on and be green then wait X seconds and then be purple. The sequence would only run once, once powered up and then stop.
Where are you stuck ?
What have you tried so far ?
So far this. Can't get it to light up.
#include <FastLED.h>
#define NUM_STRIPS 2
#define NUM_LEDS_PER_STRIP 30
CRGB leds[NUM_STRIPS][NUM_LEDS_PER_STRIP];
  FastLED.addLeds<NEOPIXEL, 6>(leds[0], NUM_LEDS_PER_STRIP);
  FastLED.addLeds<NEOPIXEL, 7>(leds[1], NUM_LEDS_PER_STRIP);
    leds[6][30] = CRGB::Red;
    FastLED.show();
    delay(100);
    leds[7][30] = CRGB::Blue;
    FastLED.show();
    delay(100);
I just simply want to turn strip 1 red. Wait x seconds and turn on strip 2 and make it blue. From there I can add more strips as part of the code.
I ended up with this. One odd thing red is green and green is red?????
#include "FastLED.h"
#define NUM_LEDS 80
#define NUM_STRIPS 4
CRGB leds[NUM_LEDS];
CLEDController *controllers[NUM_STRIPS];
uint8_t gBrightness = 128;
  controllers[0] = &FastLED.addLeds<WS2812, 1>(leds, NUM_LEDS);
  controllers[1] = &FastLED.addLeds<WS2812, 2>(leds, NUM_LEDS);
  controllers[2] = &FastLED.addLeds<WS2812, 6>(leds, NUM_LEDS);
  controllers[3] = &FastLED.addLeds<WS2812, 11>(leds, NUM_LEDS);
  // draw led data for the first strand into leds
  fill_solid(leds, NUM_LEDS, CRGB::Red);
  controllers[0]->showLeds(gBrightness);
  // draw led data for the second strand into leds
  fill_solid(leds, NUM_LEDS, CRGB::Green);
  controllers[1]->showLeds(gBrightness);
  // draw led data for the third strand into leds
  fill_solid(leds, NUM_LEDS, CRGB::Blue);
  controllers[2]->showLeds(gBrightness);
  fill_solid(leds, NUM_LEDS, CRGB::White);
  controllers[3]->showLeds(gBrightness);
  delay (1000);
  fill_solid(leds, NUM_LEDS, CRGB::Black);
  delay (1000);
  delay (1000);
  delay (1000);
  delay (1000);
  delay (1000);
  delay (5000);
Your code does not appear to be for your stated intention in the first post.
You can try changing
CRGB leds [NUM_LEDS];
on
CGRB leds [NUM_LEDS] ;
. This sets a different arrangement of bytes for color.
