Greetings,
I have a strip of 10 WS2812 RGB LEDs and I am trying to do the following:
- Make the first 7 LEDs (0-6) flicker using the Adafruit Neopixel Fire function
- Make LEDs 7 and 8 a constant colour (BLUE) or flash, etc.
- The last LED (9) I want to flash (RED 1Hz) or remain a constant colour, etc.
I think my issue is understanding the Adafruit library because without using the fire function I can handle the LEDs separately no issue. Or I can use only the fire function and handle all the LEDS but my knowledge breaks down when I try to mix the two.
- I have implemented an interrupt to handle the flash currently it is only blinking the on-board LED.
Any help splitting my strip would be really appreciated.
Here is the code i am trying to use but I'm not sure how to start handling the last 3 LEDs :
* Arduino Uno - NeoPixel Fire
* v. 1.0
* Copyright (C) 2015 Robert Ulbricht
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#define ledPin 13
// data pin
#define PIN 5
// led count
#define CNT 9
//first 7 lEDS are engine
#define engine1_cnt 6
//two interior lights
#define interior2 7
#define interior1 8
// front Navation light
#define NAV_light 9
boolean timer =false;
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_RGB Pixels are wired for RGB bitstream
// NEO_GRB Pixels are wired for GRB bitstream
// NEO_KHZ400 400 KHz bitstream (e.g. FLORA pixels)
// NEO_KHZ800 800 KHz bitstream (e.g. High Density LED strip)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(CNT, PIN, NEO_GRB + NEO_KHZ800);
//uint32_t fire_color = strip.Color ( 0, 0, 255); //( 200, 35, 0);
uint32_t fire_color = strip.Color ( 200, 50, 10); //( 200, 35, 0);
uint32_t off_color = strip.Color ( 0, 0, 0);
uint32_t white_color = strip.Color ( 255, 255, 255);
/// Fire simulator
class NeoFire
Adafruit_NeoPixel &strip;
public:
NeoFire(Adafruit_NeoPixel&);
void Draw();
void Clear();
void ClearALL();
void AddColor(uint8_t position, uint32_t color);
void SubstractColor(uint8_t position, uint32_t color);
uint32_t Blend(uint32_t color1, uint32_t color2);
uint32_t Substract(uint32_t color1, uint32_t color2);
/// Constructor
NeoFire::NeoFire(Adafruit_NeoPixel& n_strip)
: strip (n_strip)
/// Set all colors
void NeoFire::Draw()
Clear();
for(int i=0;i<CNT;i++) //for(int i=0;i<CNT;i++)
AddColor(i, fire_color);
int r = random(80);
uint32_t diff_color = strip.Color ( r, r/2, r/2);
SubstractColor(i, diff_color);
strip.show();
/// Set color of LED
void NeoFire::AddColor(uint8_t position, uint32_t color)
uint32_t blended_color = Blend(strip.getPixelColor(position), color);
strip.setPixelColor(position, blended_color);
void NeoFire::SubstractColor(uint8_t position, uint32_t color)
uint32_t blended_color = Substract(strip.getPixelColor(position), color);
/// Color blending
uint32_t NeoFire::Blend(uint32_t color1, uint32_t color2)
uint8_t r1,g1,b1;
uint8_t r2,g2,b2;
uint8_t r3,g3,b3;
r1 = (uint8_t)(color1 >> 16),
g1 = (uint8_t)(color1 >> 8),
b1 = (uint8_t)(color1 >> 0);
r2 = (uint8_t)(color2 >> 16),
g2 = (uint8_t)(color2 >> 8),
b2 = (uint8_t)(color2 >> 0);
return strip.Color(constrain(r1+r2, 0, 255), constrain(g1+g2, 0, 255), constrain(b1+b2, 0, 255));
/// Color blending
uint32_t NeoFire::Substract(uint32_t color1, uint32_t color2)
uint8_t r1,g1,b1;
uint8_t r2,g2,b2;
uint8_t r3,g3,b3;
int16_t r,g,b;
r=(int16_t)r1-(int16_t)r2;
g=(int16_t)g1-(int16_t)g2;
b=(int16_t)b1-(int16_t)b2;
if(r<0) r=0;
if(g<0) g=0;
if(b<0) b=0;
return strip.Color(r, g, b);
/// Every LED to black
void NeoFire::Clear()
for(uint16_t i=0; i<strip.numPixels(); i++) //for(uint16_t i=0; i<strip.numPixels (); i++)
strip.setPixelColor(i, off_color);
NeoFire fire(strip);
/// Setup
pinMode(ledPin, OUTPUT);
// initialize timer1
noInterrupts(); // disable all interrupts
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 34286; // preload timer 65536-16MHz/256/2Hz
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << TOIE1); // enable timer overflow interrupt
interrupts(); // enable all interrupts
strip.begin();
strip.show(); // Initialize all pixels to 'off'
/// ISR
ISR(TIMER1_OVF_vect) // interrupt service routine that wraps a user defined function supplied by attachInterrupt
timer = !timer;
digitalWrite(ledPin, digitalRead(ledPin) ^ 1); // flast onboard LED to indicate interrupt
/// Main loop
fire.Draw();
delay(random(2,20));
