neoway m590
Hola estoy comenzando con adruino y compre el modulo neoway m590 que viene separado lo arme pero no estoy seguro si este funciona en Chile por las frecuencias les dejo el detalle.
Voltage: 5V
Frequency: 900 1800 MHz
Stand by current: < 10 mA
Working current: < 80 mA
Baud: 9600 or change by sending AT+IPR=xxxx
Interface: TTL
Commands: Regular AT commands
Connector: 5V GND TxD RxD
Antenna: Please solder a copper wire to the board or use an IPEX socket
Temperatures: -30 C to 80 C
Functions: Send/receive SMS messages and GPRS data.
Excellent for remote sensing, experiments, alarms and automatic data collection.
The control port is a regular serial port. You may connect it directly with a microcontroller such as Arduin. Or you can use a USB to serial port adapter and send commands directly from a computer.
If you also need a USB to serial adapter, please contact us.
A complete instruction for using the AT commands will be provided.
Neoway M590 Hardware Design Manual V1.1.pdf (1000 KB)
Hola, yo compré y monté ese mismo módulo. Lo he testeado y lo he reflejado en mi blog por si te interesa probarlo:
Blog de ALRO
Un saludo.
