Nested Loops and Arrays
hi,
using the following code, i don't seem to get the result i'm looking for.
state is a variable, which is set outside this code. for this example, state is set to 1, which refers to the first line is sideState (4, 6, 2, 5) these are linked to addressable leds in segments of 2, numbers, (6,7) (10,11) (2,3) (8,9)
int sideLeds[NUM_LEDS_IN_SEGMENT * NUM_SIDES];
initialisation of the led array, this is based on static variables... in my current case its 2*4=8
sideLeds[k] = sideState[state - 1][i] * NUM_LEDS_IN_SEGMENT + (j - 2);
sideState [ x ] [ y ] refers to the 2D array, x is the state, y is the led cluster
#define NUM_LEDS_IN_SEGMENT 2
#define NUM_SIDES 4
byte sideState[6][4] = {
  {4, 6, 2, 5}, //  1   0,1
  {5, 1, 6, 3}, //  2   2,3
  {5, 2, 6, 4}, //  3   4,5
  {3, 6, 1, 5}, //  4   6,7
  {4, 1, 2, 3}, //  5   8,9
  {3, 2, 1, 4}  //  6   10,11
int state = 1;
  Serial.begin(9600);  // start serial for output
  for (int k = 0; k < NUM_LEDS_IN_SEGMENT * NUM_SIDES; k++) {
      for (int i = 0; i < 4; i++) {
          for (int j = 0; j < NUM_LEDS_IN_SEGMENT; j++) {
        Serial.print(sideLeds[k]);
my PERCEIVED output, for this instance, where the variables are shown as values
sideLeds[8] = {6,7,10,11,2,3,8,9); and the output on the serial monitor should be 6710112389
but the actual output is;
67101123896710112389671011238967101123896710112389671011238967101123896710112389
which is correct, except its repeated 8 times.
i can see why the code is repeated as the overlying for loop K repeats 8 times,
but i don't know how to input 8 single variables into the array, without it outputting the whole array 8 times.
Move the print() statement outside of the inner loops. The value will still be assigned 8 times, but it will only be printed once.
:o i get repeated 9s (99999999) when outside... which is a ludicrous result...!
I'm guessing you moved it out of all 3 of the loops. Since you are using k as an index in the print statement, if you move it all the way out of the for( int k = ... loop then k will be maxed out when the statement runs since that is the condition which causes the k loop to end which must happen in order to get to the print which is now outside that loop. So you are essentially always calling
print( sideLeds[ NUM_LEDS_IN_SEGMENT * NUM_SIDES ] );
at that point. Make sure you leave the print statement inside the outer k loop.
i have 4 stages of for loops and these are the results;
buried right in the centre;
next;
7113971139711397113971139711397113971139
next;
99999999
next;
'k' was not declared in this scope
it doesn't really make sense, but im going to try putting the right numbers (albeit 8 copies of them) into the full code and see how it works.
next;
That makes perfect sense - think about what happens at the end of a "for" statement
i understand the end error, but my formatting wasn't too clever. apologies, i've edited my post
ive put the equation into the main code. and unfortunately, the end result is
sideLeds[8]=99999999 (as values)
so i def need to fix this! :slight_smile:
I wonder if you have your nesting back to front. What would happen if you do
for (j
    for (i
       for (k
...R
jik is sideLeds[8]=66666666101010101010101022222222888888887777777711111111111111113333333399999999 (as values)
but im going to try all the different options now...
ijk = 66666666777777771010101010101010111111111111111122222222333333338888888899999999
ikj = 67676767676767671011101110111011101110111011101123232323232323238989898989898989
kji = 61028711396102871139610287113961028711396102871139610287113961028711396102871139
kij = 67101123896710112389671011238967101123896710112389671011238967101123896710112389
jik = 66666666101010101010101022222222888888887777777711111111111111113333333399999999
jki = 61028610286102861028610286102861028610287113971139711397113971139711397113971139
none of it really makes sense lol
ahha!
i know whats going on...!
its taking the 6710112389 generated as 1 figure in the array, so instead of
sideLeds[0] = 6
sideLeds[1] = 7
sideLeds[2] = 10
sideLeds[3] = 11
etc...
its doing
sideLeds[0] = 6710112389
sideLeds[1] = 6710112389
sideLeds[2] = 6710112389
sideLeds[3] = 6710112389
so... :o
after breaking down the code, and testing every single line... i have recoded and found a solution.
its definitely not pretty.... but it works.
#define NUM_SIDES 4
int state = 1;
      for (int i = 0; i < NUM_LEDS_IN_SEGMENT*NUM_SIDES; i+=2) {
          sideLeds[i] = (sideState[state-1][i/2]*NUM_LEDS_IN_SEGMENT)+(j-3);
          sideLeds[i+1] = (sideState[state-1][i/2]*NUM_LEDS_IN_SEGMENT)+(j-2);
          for (int x=0; x<NUM_LEDS_IN_SEGMENT*NUM_SIDES; x++) {
          Serial.print(sideLeds[x]);
There is nothing "not pretty" about code that works.
PaulS:
not pretty, as it will only work for led clusters of 2.
the full project is clusters of 9!
kelvinmead:
I have to say I have not properly grasped what you are trying to achieve. Perhaps if you explain that in English rather than in code someone will be able to suggest a better approach.
...R
for (int i=0; i<NUM_SIDES; i++) {
  for (int j=0; j<NUM_LEDS_IN_SEGMENT; j++) {
      sideLeds2[i]=(sideState[state-1][i]*NUM_LEDS_IN_SEGMENT)-NUM_LEDS_IN_SEGMENT;
      sideLeds2[i]+=j;
      Serial.print(sideLeds2[i]);
      sideLeds[i]=sideLeds2[i];
reworked code to be "pretty" now this will work with any sized led cluster!
the weird sideLeds_=sideLeds2*; is due to the weird way fastled shows leds... still working on that, but the bulk of the code is :)*_
yay!
