Hallo,
ich hab nun alles angeschlossen was ich habe und auch soweit das Tuturial von ihm angesehen.
Aber wenn ich ab 10:15 das starte bekomme ich immer wieder diese meldung
ant -f C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk -Dnb.internal.action.name=run run
init:
Deleting: C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\build\built-jar.properties
deps-jar:
Updating property file: C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\build\built-jar.properties
Compiling 22 source files to C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\build\classes
warning: [options] bootstrap class path not set in conjunction with -source 1.5
warning: [options] source value 1.5 is obsolete and will be removed in a future release
warning: [options] target value 1.5 is obsolete and will be removed in a future release
warning: [options] To suppress warnings about obsolete options, use -Xlint:-options.
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\src\moppydesk\MoppyUI.java:22: error: package org.jdesktop.application does not exist
import org.jdesktop.application.SingleFrameApplication;
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\src\moppydesk\MoppyUI.java:28: error: cannot find symbol
public class MoppyUI extends SingleFrameApplication {
symbol: class SingleFrameApplication
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\src\moppydesk\testing\MoppyFloppySim.java:17: error: package org.jdesktop.application does not exist
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\src\moppydesk\testing\MoppyFloppySim.java:23: error: cannot find symbol
public class MoppyFloppySim extends SingleFrameApplication{
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\src\moppydesk\MoppyUI.java:40: error: method does not override or implement a method from a supertype
@Override
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\src\moppydesk\MoppyUI.java:48: error: cannot find symbol
JOptionPane.showMessageDialog(this.getMainFrame(), ex.toString());
symbol: method getMainFrame()
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\src\moppydesk\MoppyUI.java:52: error: cannot find symbol
show(mainWindow);
symbol: method show(MoppyControlWindow)
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\src\moppydesk\MoppyUI.java:60: error: cannot find symbol
launch(MoppyUI.class, args);
symbol: method launch(Class,String[])
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\src\moppydesk\testing\MoppyFloppySim.java:31: error: cannot find symbol
launch(MoppyFloppySim.class, args);
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\src\moppydesk\testing\MoppyFloppySim.java:34: error: method does not override or implement a method from a supertype
@Override
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\src\moppydesk\testing\MoppyFloppySim.java:38: error: cannot find symbol
show(mainWindow);
symbol: method show(FloppySimWindow)
Note: Some input files use unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
11 errors
4 warnings
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\nbproject\build-impl.xml:923: The following error occurred while executing this line:
C:\Users\Shark\Desktop\Moppy-moppy-advanced\Java\MoppyDesk\nbproject\build-impl.xml:303: Compile failed; see the compiler error output for details.
BUILD FAILED (total time: 0 seconds)
Ich hab keine Ahnung was dies bedeutet
