So, I built a little obstacle avoidance robot, so far it's working fine. But I would like to make it work with a Neural Network, searching I found this code:
#include <Servo.h> //servo library
Servo myservo; // create servo object to control servo
int Echo = A4;
int Trig = A5;
#define ENA 5
#define ENB 6
#define IN1 7
#define IN2 8
#define IN3 9
#define IN4 11
Network Configuration
const int InputNodes = 3; // includes BIAS neuron
const int HiddenNodes = 4; //includes BIAS neuron
const int OutputNodes = 4;
int i, j;
double Accum;
double Hidden[HiddenNodes];
double Output[OutputNodes];
float HiddenWeights[3][4] = {{-0.5617644549564086, 1.0942893946497538, -1.0682572021248855, 1.304429946291011}, {0.8068076878837755, -4.010636506524299, 4.023499996501605, -0.3342896095417134}, {0.2122339991590681, -1.5699936019785983, -1.6506637473608512, 0.22538199584563273}};
float OutputWeights[4][4] = {{-1.371854399267592, -0.8997542122405253, -0.8681163843245009, 0.025905325213148457}, {-0.9808612938288105, -0.33757346882199263, -1.7677793863252733, 1.8239271557047205}, {-1.4958911354789663, 1.6436091911381543, 0.23187132309438943, 0.6119086932832044}, {1.0923727805142454, 1.2928498659973917, 1.3430060270009385, 1.5636986805649136}};
End Network Configuration
void stop() {
digitalWrite(ENA, LOW); //We deactivate the engines
digitalWrite(ENB, LOW); //We deactivate the engines
Serial.println("Stop!");
//Measure distance in Centimeters
int Distance_test() {
digitalWrite(Trig, LOW);
delayMicroseconds(2);
digitalWrite(Trig, HIGH);
delayMicroseconds(20);
float Fdistance = pulseIn(Echo, HIGH);
Fdistance= Fdistance / 58;
return (int)Fdistance;
myservo.attach(3); // attach servo on pin 3 to servo object
pinMode(Echo, INPUT);
pinMode(Trig, OUTPUT);
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
stop();
myservo.write(90); //starting position in the center
unsigned long previousMillis = 0; // to measure time cycles
const long interval = 25; // intervals every x milliseconds
int grados_servo = 90; // position of the servo that moves the ultrasonic sensor
bool clockwise = true; // direction of servo rotation
const long ANGULO_MIN = 30;
const long ANGULO_MAX = 150;
double ditanciaMaxima = 50.0; // far distance from which the NN begins to act
int incrementos = 9; // increments per cycle of servo position
int accionEnCurso = 1; // number of cycles executing an action
int multiplicador = 1000/interval; // multiply the number of cycles to give the car time to turn
const int SPEED = 100; // speed of the car from all 4 wheels at a time
if (currentMillis - previousMillis >= interval) {
HANDLE SERVO TURN
if(grados_servo<=ANGULO_MIN || grados_servo>=ANGULO_MAX){
clockwise=!clockwise; // cambio de sentido
grados_servo = constrain(grados_servo, ANGULO_MIN, ANGULO_MAX);
if(clockwise)
grados_servo=grados_servo+incrementos;
grados_servo=grados_servo-incrementos;
if(accionEnCurso>0){
accionEnCurso=accionEnCurso-1;
}else{
WE CALL THE DRIVING FUNCTION
conducir();
myservo.write(grados_servo);
//USE THE NEURONAL NETWORK ALREADY TRAINED
void conducir()
double TestInput[] = {0, 0,0};
double entrada1=0,entrada2=0;
GET SENSOR DISTANCE
double distance = double(Distance_test());
distance= double(constrain(distance, 0.0, ditanciaMaxima));
entrada1= ((-2.0/ditanciaMaxima)*double(distance))+1.0; //use a linear function to get closeness
accionEnCurso = ((entrada1 +1) * multiplicador)+1; // If it is very close to the obstacle, it need more time to react
GET DIRECTION ACCORDING TO THE SERVO ANGLE
entrada2 = map(grados_servo, ANGULO_MIN, ANGULO_MAX, -100, 100);
entrada2 = double(constrain(entrada2, -100.00, 100.00));
WE CALL THE FEED FORWARD NETWORK WITH THE TICKETS
Serial.print("Entrada1:");
Serial.println(entrada1);
Serial.print("Entrada2:");
Serial.println(entrada2/100.0);
TestInput[0] = 1.0;//BIAS UNIT
TestInput[1] = entrada1;
TestInput[2] = entrada2/100.0;
InputToOutput(TestInput[0], TestInput[1], TestInput[2]); //INPUT to ANN to obtain OUTPUT
int out1 = round(abs(Output[0]));
int out2 = round(abs(Output[1]));
int out3 = round(abs(Output[2]));
int out4 = round(abs(Output[3]));
Serial.print("Salida1:");
Serial.println(out1);
Serial.print("Salida2:");
Serial.println(out2);
Serial.println(Output[1]);
Serial.print("Salida3:");
Serial.println(out3);
Serial.print("Salida4:");
Serial.println(out4);
POWERING MOTORS WITH THE NETWORK OUTPUT
int carSpeed = SPEED; //forward or backward
if((out1+out3)==2 || (out2+out4)==2){ // if it is twist, the motors need double power
carSpeed = SPEED * 2;
analogWrite(ENA, carSpeed);
analogWrite(ENB, carSpeed);
digitalWrite(IN1, out1 * HIGH);
digitalWrite(IN2, out2 * HIGH);
digitalWrite(IN3, out3 * HIGH);
digitalWrite(IN4, out4 * HIGH);
void InputToOutput(double In1, double In2, double In3)
TestInput[0] = In1;
TestInput[1] = In2;
TestInput[2] = In3;
Calculate triggers on hidden layers
for ( i = 0 ; i < HiddenNodes ; i++ ) {
Accum = 0;//HiddenWeights[InputNodes][i] ;
for ( j = 0 ; j < InputNodes ; j++ ) {
Accum += TestInput[j] * HiddenWeights[j][i] ;
//Hidden[i] = 1.0 / (1.0 + exp(-Accum)) ; //Sigmoid
Hidden[i] = tanh(Accum) ; //tanh
Calculate activation and error in the Output layer
for ( i = 0 ; i < OutputNodes ; i++ ) {
Accum = 0;//OutputWeights[HiddenNodes][i];
for ( j = 0 ; j < HiddenNodes ; j++ ) {
Accum += Hidden[j] * OutputWeights[j][i] ;
Output[i] = tanh(Accum) ;//tanh
In it an L298N driver is used to control the motors, but I have an L293D. So...
It is there a way it could work with my driver instead.
What do I need to modify for this code to work with my driver?
Thanks for your help
