New IDE 2.0 issues
@ptillisch
I just downloaded the latest IDE, and I get this error when I try to upload to my Nano:
Sketch uses 860 bytes (2%) of program storage space. Maximum is 30720 bytes.
Global variables use 15 bytes (0%) of dynamic memory, leaving 2033 bytes for local variables. Maximum is 2048 bytes.
Warning: tool 'arduino:avrdude@6.3.0-arduino17' is not installed. It might not be available for your OS.Failed uploading: cannot execute upload tool: exec: "{runtime.tools.avrdude.path}/bin/avrdude": file does not exist
Hi @outbackhut. In order to gather more information that will allow me to provide you with detailed instructions for fixing the problem, I'm going to ask you to post the full output from the upload when in verbose mode.
Please do this:
  1. Select File > Preferences from the Arduino IDE menus.
  2. Check the checkbox next to Show verbose output during: ☐ compilation.
  3. Click the OK button.
  4. Attempt an upload, as you did before.
  5. After the upload fails, right click on the black "Output" pane at the bottom of the Arduino IDE 2.x window.
  6. From the context menu, click Copy All.
    This copies the full output to the clipboard.
  7. Open a forum reply here by clicking the Reply button.
  8. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  9. Press Ctrl+V.
    This will paste the error output from the upload into the code block.
  10. Move the cursor outside of the code tags before you add any additional text to your reply.
  11. Click the Reply button to post the output.
Here you go:
Using board 'nano' from platform in folder: C:\Users\hopin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Using core 'arduino' from platform in folder: C:\Users\hopin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Detecting libraries used...
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\sketch\\OLEDVoltmeter.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\sketch\\OLEDVoltmeter.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\sketch\\OLEDVoltmeter.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.11.3 Adafruit-GFX-Library-master@1.2.3]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit_GFX_Library@1.11.3 Adafruit-GFX-Library-master@1.2.3]
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\sketch\\OLEDVoltmeter.ino.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.13.2]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit_BusIO@1.13.2]
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\sketch\\OLEDVoltmeter.ino.cpp" -o nul
Alternatives for Adafruit_SSD1306.h: [Adafruit_SSD1306@2.5.7]
ResolveLibrary(Adafruit_SSD1306.h)
  -> candidates: [Adafruit_SSD1306@2.5.7]
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\sketch\\OLEDVoltmeter.ino.cpp" -o nul
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src\\SPI.cpp" -o nul
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\utility\\twi.c" -o nul
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o nul
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o nul
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306\\Adafruit_SSD1306.cpp" -o nul
Generating function prototypes...
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\sketch\\OLEDVoltmeter.ino.cpp" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\sketch\\OLEDVoltmeter.ino.cpp" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\sketch\\OLEDVoltmeter.ino.cpp.o"
Compiling libraries...
Compiling library "SPI"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src\\SPI.cpp" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\SPI\\SPI.cpp.o"
Compiling library "Wire"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Wire\\Wire.cpp.o"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\utility\\twi.c" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Wire\\utility\\twi.c.o"
Compiling library "Adafruit_GFX_Library"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp.o"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp.o"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp.o"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_GFX_Library\\glcdfont.c.o"
Compiling library "Adafruit_BusIO"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp.o"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp.o"
Compiling library "Adafruit_SSD1306"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\hopin\\Documents\\Arduino\\libraries\\Adafruit_SSD1306\\Adafruit_SSD1306.cpp" -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_SSD1306\\Adafruit_SSD1306.cpp.o"
Compiling core...
Using precompiled core: C:\Users\hopin\AppData\Local\Temp\arduino-core-cache\core_arduino_avr_nano_cpu_atmega328_d7003f7b976916192b93e7cb3c10b377.a
Linking everything together...
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74/OLEDVoltmeter.ino.elf" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\sketch\\OLEDVoltmeter.ino.cpp.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_GFX_Library\\glcdfont.c.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74\\libraries\\Adafruit_SSD1306\\Adafruit_SSD1306.cpp.o" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74/..\\arduino-core-cache\\core_arduino_avr_nano_cpu_atmega328_d7003f7b976916192b93e7cb3c10b377.a" "-LC:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74" -lm
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74/OLEDVoltmeter.ino.elf" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74/OLEDVoltmeter.ino.eep"
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74/OLEDVoltmeter.ino.elf" "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74/OLEDVoltmeter.ino.hex"
Multiple libraries were found for "Adafruit_GFX.h"
  Used: C:\Users\hopin\Documents\Arduino\libraries\Adafruit_GFX_Library
  Not used: C:\Users\hopin\Documents\Arduino\libraries\Adafruit-GFX-Library-master
Using library SPI at version 1.0 in folder: C:\Users\hopin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\hopin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire
Using library Adafruit_GFX_Library at version 1.11.3 in folder: C:\Users\hopin\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_BusIO at version 1.13.2 in folder: C:\Users\hopin\Documents\Arduino\libraries\Adafruit_BusIO
Using library Adafruit_SSD1306 at version 2.5.7 in folder: C:\Users\hopin\Documents\Arduino\libraries\Adafruit_SSD1306
"C:\\Users\\hopin\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\hopin\\AppData\\Local\\Temp\\arduino-sketch-22C9E8B9C3677255C2A9564A1CD74C74/OLEDVoltmeter.ino.elf"
Sketch uses 15286 bytes (49%) of program storage space. Maximum is 30720 bytes.
Global variables use 523 bytes (25%) of dynamic memory, leaving 1525 bytes for local variables. Maximum is 2048 bytes.
Hi @outbackhut. This type of error can occur if a Boards Manager installation is interrupted while in progress, or interfered with by something like an antivirus "on access" or "real-time" scan.
The problem is that the folder that should contain the installation of the AVRDUDE tool used for uploading to the Nano is missing.
The reason this problem might occur after updating from Arduino IDE 1.x to 2.x is that the AVRDUDE tool is included in the Arduino IDE 1.x installation. That is not the case with Arduino IDE 2.x installation, which consists of the IDE application alone, without any firmware toolchains. The approach taken by Arduino IDE 2.x is to automatically install these tools via the Boards Manager infrastructure on the first run after a new installation.
It should be possible to recover by uninstalling and then reinstalling the "Arduino AVR Boards" platform that provides that tool. I'll provide instructions:
  1. Select Tools > Board > Boards Manager from the Arduino IDE menus to open the "Boards Manager" view in the left side panel.
  2. Scroll down through the list of boards platforms until you see the "Arduino AVR Boards" entry. Hover the mouse pointer over it.
  3. Hover the mouse pointer over the "INSTALLED" label on the "Arduino AVR Boards" entry. You will now see it change to an "UNINSTALL" button.
  4. Click the "UNINSTALL" button.
  5. Wait for the uninstallation to finish.
  6. Hover the mouse pointer over the "Arduino AVR Boards" entry again.
  7. Click the "INSTALL" button.
  8. Wait for the installation to finish.
Now try uploading again. Hopefully the error will no longer occur.
Please let me know if you have any questions or problems while following those instructions.
That worked really well! No issues now! Thank you very much!
You are welcome. I'm glad it is working now. Thanks for taking the time to provide an update with your results.
Regards,
Per
