I've been playing with a 2560 layout so I could use it as a drop-in processor on projects into a 104 pin header.
This is what I have, all routed and with the caps, crystal, and resistor on the bottom, and ICSP and FTDI header for easy programming.
Thinking about pin labels - do you think having them around the outside like this is clear, or would moving a bunch inside the pins would be more clear?
EDIT:
If you enlarge the PCB add 6-32 mounting holes in the corners then you would have room for both the controller names and the IDE name side by side.
My plan is to have a 104 pin socket on perfboard, or a PCB eventually, that this would plug into.
Looking at a project where this and several other processors would be connected together.
Going to wirewrap them to start until I find a connection/interface scheme I am satisfied with, and then perhaps go to a larger PCB for them all.
This provides kind of a DIP option for me, and if something blows I can pull it out and insert another.
CrossRoads:
I would find that sort of thing more useful if there were just two rows of pins like a regular dip chip. I realize that would make it longer and would probably make the routing more complex.
Well, that's the engineering tradeoff, isn't it?
Remember the Intel/Motorola processors of the past, 1.5" to 2" square parts with 2 and 3 rows of parallel pins underneath? That's what I am after here.
Someone's already done a 2 x 50 DIP version of the Mega, I think using the leadless package. I wanted something more compact, yet still relatively easy to solder.
At 47.8 x 45.3, this still fits into the inexpensive 50mm x 50mm PCB also, vs jumping up into the 50 x 130mm range.
Perhaps. www.schmartboard.com and www.proto-advantage.com offer lines of similar components.
schmartboard are set up to be easy to solder. proto-advantage has board-stencil-solder kits, and will also order parts from digikey and do assembly for you.
