New modbus master slave library not working as expected
Hi All,
I am using the library discussed in this thread (New Modbus Master-Slave library ) and are using the example code as below.
Using radzio master modbus sim both the coils status and input status functions show the same information and both change simultaneously when pressing a push button connected to an input pin on the uno.
Holding register and input register functions bring up errors in the master sim and display no information.
I can set coil status to 1 from the sim but output pins do not change state,always low
Hopefully I have explained clearly enough,as I understand this code,all 4 of the function codes should be working.
Can someone tell me where I am going wrong here ?
 *  Modbus slave example 2:
 *  The purpose of this example is to link the Arduino digital and analog
 *	pins to an external device.
//Incluye la librería del protocolo Modbus
#include <ModbusRtu.h>
#define ID   1
// assign the Arduino pin that must be connected to RE-DE RS485 transceiver
//#define TXEN	4
//Crear instancia
//Modbus slave(ID, Serial, 0); //ID del nodo. 0 para el master, 1-247 para esclavo
                        //Puerto serie (0 = TX: 1 - RX: 0)
                        //Protocolo serie. 0 para RS-232 + USB (default), cualquier pin mayor a 1 para RS-485
//Modbus slave(ID,Serial,TXEN); // this is slave @1 and RS-485
 Modbus slave(1,0,0);   //testing using uno onboard USB to serial converter
boolean led;
int8_t state = 0;
unsigned long tempus;
uint16_t au16data[9]; //La tabla de registros que se desea compartir por la red
 Configuración del programa
  io_setup(); //configura las entradas y salidas
  Serial.begin(9600); //Abre la comunicación como esclavo
  slave.start();
  tempus = millis() + 100; //Guarda el tiempo actual + 100ms
  digitalWrite(13, HIGH ); //Prende el led del pin 13 (el de la placa)
 Inicio del programa
  //Comprueba el buffer de entrada
  state = slave.poll( au16data, 9 ); //Parámetros: Tabla de registros para el intercambio de info
                                     //            Tamaño de la tabla de registros
                                     //Devuelve 0 si no hay pedido de datos
                                     //Devuelve 1 al 4 si hubo error de comunicación
                                     //Devuelve mas de 4 si se procesó correctamente el pedido
  if (state > 4) { //Si es mayor a 4 = el pedido fué correcto
    tempus = millis() + 50; //Tiempo actual + 50ms
    digitalWrite(13, HIGH);//Prende el led
  if (millis() > tempus) digitalWrite(13, LOW );//Apaga el led 50ms después
  //Actualiza los pines de Arduino con la tabla de Modbus
  io_poll();
 * pin maping:
 * 2 - digital input
 * 3 - digital input
 * 4 - digital input
 * 5 - digital input
 * 6 - digital output
 * 7 - digital output
 * 8 - digital output
 * 9 - digital output
 * 10 - analog output
 * 11 - analog output
 * 14 - analog input
 * 15 - analog input
 * pin 13 reservado para ver el estado de la comunicación
void io_setup() {
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(13, OUTPUT);
  digitalWrite(6, LOW );
  digitalWrite(7, LOW );
  digitalWrite(8, LOW );
  digitalWrite(9, LOW );
  digitalWrite(13, HIGH ); //Led del pin 13 de la placa
  analogWrite(10, 0 ); //PWM 0%
  analogWrite(11, 0 ); //PWM 0%
Enlaza la tabla de registros con los pines
void io_poll() {
  // digital inputs -> au16data[0]
  // Lee las entradas digitales y las guarda en bits de la primera variable del vector
  // (es lo mismo que hacer una máscara)
  bitWrite( au16data[0], 0, digitalRead( 2 )); //Lee el pin 2 de Arduino y lo guarda en el bit 0 de la variable au16data[0]
  bitWrite( au16data[0], 1, digitalRead( 3 ));
  bitWrite( au16data[0], 2, digitalRead( 4 ));
  bitWrite( au16data[0], 3, digitalRead( 5 ));
  // digital outputs -> au16data[1]
  // Lee los bits de la segunda variable y los pone en las salidas digitales
  digitalWrite( 6, bitRead( au16data[1], 0 )); //Lee el bit 0 de la variable au16data[1] y lo pone en el pin 6 de Arduino
  digitalWrite( 7, bitRead( au16data[1], 1 ));
  digitalWrite( 8, bitRead( au16data[1], 2 ));
  digitalWrite( 9, bitRead( au16data[1], 3 ));
  // Cambia el valor del PWM
  analogWrite( 10, au16data[2] ); //El valor de au16data[2] se escribe en la salida de PWM del pin 10 de Arduino. (siendo 0=0% y 255=100%)
  analogWrite( 11, au16data[3] );
  // Lee las entradas analógicas (ADC)
  au16data[4] = analogRead( 0 ); //El valor analógico leido en el pin A0 se guarda en au16data[4]. (siendo 0=0v y 1023=5v)
  au16data[5] = analogRead( 1 );
  // Diagnóstico de la comunicación (para debug)
  au16data[6] = slave.getInCnt();  //Devuelve cuantos mensajes se recibieron
  au16data[7] = slave.getOutCnt(); //Devuelve cuantos mensajes se transmitieron
  au16data[8] = slave.getErrCnt(); //Devuelve cuantos errores hubieron
The oppinion here is No.
Hardware mistakes are very common here. Without schematics analysing the software is a waste of time.
Your code seems fine.
Regarding to your issues,
  1. Coils and Inputs share the same area. This area is also for the registers.
  2. I don't know your Master simulator. I did all my communication tests with QModbus and ModPoll. It seems that there's some problem with the data access and its function.
Have you ever tried to increase the au16data size and put same sort of data in consecutive registers?
Cheers,
@Railroader a fair comment,
The inputs have a push button from the relevant input pin to ground.
Output pins have a LED with a series resistor to ground.
A0 has a NTC to ground with a 10k pullup resistor to 5v,for a changing analogue input for testing purposes.
@suby I have put data into the registers,as you suggest,then all 4 functions work as expected in the simulator.
I will test again using Qmodbus and Modpoll.
Thanks for the replies.
Please refer to this blog where you will find all the information:
https://share.google/iqGzrdsqteHNlhghs
El dl., 1 de set. 2025, 20:17, Arduinodavidza via Arduino Forum <notifications@arduino.discoursemail.com> va escriure:
