Hello,
I'm incredibly new to this-like a few hours new...so don't kill me.
I have an 02 touring Harley with the fairing and radio. I'd like to put an android tablet into the dash and remove all the gauges. I know there are a few threads on similar subjects, specifically by "TZ", however, his bike is new enough to have an ECM he can tap into. My bike is carburated with no ECM. I need to find a way to put these sensors into a format the tablet can understand. As best as I've been able to find, this is the best way. The plan is to remove the radio and gauges, install the tablet, feed the audio output from the tablet into an amplifier to run the speakers. There should be audio, GPS navigation, and the digital dash if all this works out.
Here's what I'm looking for from the Arduino -
Oil Pressure and Temp- I've seen elsewhere on the net that VDO sensors can be used, and I'm sure Autometer makes some as well.
Voltage-I found a voltage monitor module. As far as I can tell, it goes on a sensor shield that is plug in to an Arduino 2560 or Uno.
Fuel- I have no clue what to do with this, as it is an ohm reading from the in tank sensor.
Speedometer- GPS? not really sure what the best solution is here, but this seems easiest.
Tach- not a have to have, but I'd like to if possible. I've read that people have done it, but I'm not clear how it is done.
Neutral light and turn signals/High Beam- Neutral is an open/close switch, I'm sure there's a way to drop the voltage on the factory sensor, same with the turn signals and high beam indicator, and possibly the passing lamps.
I'd also like to power it from the bike's 12v system and be able to charge the tablet.
Now, will an Arduino be able to handle all of this, and if so, what recommendations do you have for hardware? If I use the sensor shield, can I still use the Android APK shield, and will it make this any easier? I don't want to think about what the code for this is going to look like. I'm hoping I can build it one piece at a time and compile it?
If you actually made it this far, I greatly appreciate any input!!
Shawn
