Very grateful for this Jacgues.
It is best that you make all of your time variables for a use the same size unsigned integers. The lower 8 or 16 bits of millis() and micros() returns work fine as timers with limited max intervals.
I have a button class that debounces using 8 bit time variables. They take less room and use fewer cycles.
16 bit unsigned millis() is good to over a minute, Arduino variable type is word.
The compiler might not turn our mixed-math source into what we think it will in all circumstances.
Have you seen Nick Gammon's state machine example in his tutorial on reading text without blocking? It's at the 2nd address in my sig space.
Thanks for the push on State Machines. I once told the vendor of a $200,000 semiconductor tool that we wouldn't buy it until they provided us with a State Machine diagram of the factory communications interface. They grumbled for 3 months, sent the diagram, and said "Oh, there's a major upgrade of the software we just installed".
Here's a State Machine example for a Traffic Light that includes vehicle detection on the side street and a Walk request button. This is in a preprogrammed example package for young kids starting to connect hardware to Arduino.
Awww. it didn't fit in 9000 bytes. Ummm...
OK, put it on my wiki here: (NOT good formatting. I will figure it out.. )
https://arduinoinfo.mywikis.net/wiki/Easy-Connect-Software-Outline
Scroll down to last example..
Welease_Woggah:
Bit of a leap of faith to think that someone new to FSMs will know what an enum is.
Why is that?
An enum is a variable type which is present in many programming languages and is not more related to FSMs than any other variable types.
This is a very cool tutorial. I've been doing it somewhat sloppily the past few years, and this may help clean up my act. Also motivates me to look for and/or (eventually) come up with an object oriented version.
johnnycanuck:
Actually, state machines have been used in OOP code since at least 1970 when Charles Moore released Forth.
State machines are a technique, Johnny.
What part of Canada are you from? My family reunion is still held in NB, you might be a cousin.
nielyay:
enum LedStates{ON, OFF};*what is [enum] function?
It is not a function, more like a variable, it tells the compiler to associate labels with numbers under a certain name.
enum unoSpi { mosi=11, miso, sck }; // mosi starts as 11, miso is 12, sck is 13
enum rgbColor { red=1, green, blue }; // starts at 1
enum smallNumbers { zero, one, two, three }; // zero is by default 0, one is 1, etc
When I have a function that has an unoSpi arg, the compiler will only accept unoSpi values in that place.
Glad that you shared this and found it quite helpful.
But on Arduino I would be careful about how many enums I make since they do take up RAM.
One way to make enums use 1 byte instead of default int,
enum Color: byte
RED, GREEN, BLUE
The tutorial is superb, well written and clear. I really appreciate the time and effort you put into sharing that with us.
jbellavance:
Someone new to the state machine concept are not necessarily new to programming. This tutorial is not about C++. It is about implanting a state machine in Arduino's environment which happens to be written in C++.I my mind, using a "switch" construct is not easier than using enum, since I have met on this site, a few persons that only uses "if" constructs, "since you can to everything with that construct" and won't have anything to do with "switch". But I insist in using it because the "switch" construct is , IMHO, ideal to describe a state machine's behaviour.
A switch-case state machine is a good way to break a large or long top-down process into small pieces and wait intervals. A function with a state machine can achieve a whole process by running over and over. Your void loop() may run > 60 times a millisecond, over and over can get somewhere fast at that rate.
I have a demo showing how to use switch-case to remove calls to delay(). It hit me while I was de-blocking a greenhouse automation with a lot of wait-for's that one come-back-later code before the switch could replace any number of cases with timing code (the original GSM code had 10 delays).
// add-a-sketch_un-delay 2018 by GoForSmoke @ Arduino.cc Forum
// Free for use, Apr 30/18 by GFS. Compiled on Arduino IDE 1.6.9.
// This sketch shows a general method to get rid of delays in code.
// You could upgrade code with delays to work with add-a-sketch.
#include <avr/io.h>
#include "Arduino.h"
const byte ledPin = 13;
unsigned long delayStart, delayWait;
Serial.begin( 115200 );
Serial.println( F( "\n\n\n Un-Delay Example, free by GoForSmoke\n" ));
Serial.println( F( "This sketch shows how to get rid of delays in code.\n" ));
pinMode( ledPin, OUTPUT );
/* The section of the original sketch with delays:
* digitalWrite( ledPin, HIGH ); -- 0
* delay( 500 );
* digitalWrite( ledPin, LOW ); -- 1
* delay( 250 );
* digitalWrite( ledPin, HIGH ); -- 2
* delay( 250 );
* digitalWrite( ledPin, LOW ); -- 3
* delay( 250 );
* digitalWrite( ledPin, HIGH ); -- 4
* delay( 1000 );
* digitalWrite( ledPin, LOW ); -- 5
* delay( 1000 );
byte blinkStep; // state tracking for BlinkPattern() below
void BlinkPattern()
// This one-shot timer replaces every delay() removed in one spot.
// start of one-shot timer
if ( delayWait > 0 ) // one-shot timer only runs when set
if ( millis() - delayStart < delayWait )
return; // instead of blocking, the undelayed function returns
delayWait = 0; // time's up! turn off the timer and run the blinkStep case
// end of one-shot timer
// here each case has a timed wait but cases could change Step on pin or serial events.
switch( blinkStep ) // runs the case numbered in blinkStep
case 0 :
Serial.println( F( "Case 0 doing something unspecified here at " ));
Serial.println( delayStart = millis()); // able to set a var to a value I pass to function
delayWait = 500; // for the next half second, this function will return on entry.
blinkStep = 1; // when the switch-case runs again it will be case 1 that runs
break; // exit switch-case
case 1 :
Serial.println( F( "Case 1 doing something unspecified here at " ));
delayWait = 250;
blinkStep = 2;
case 2 :
Serial.println( F( "Case 2 doing something unspecified here at " ));
delayWait = 250;
blinkStep = 3;
case 3 :
Serial.println( F( "Case 3 doing something unspecified here at " ));
delayWait = 250;
blinkStep = 4;
case 4 :
Serial.println( F( "Case 4 doing something unspecified here at " ));
delayWait = 1000;
blinkStep = 5;
case 5 :
Serial.print( F( "Case 5 doing something unspecified here at " ));
delayWait = 1000;
blinkStep = 0;
void loop() // runs over and over, see how often
BlinkPattern();
A full state machine tutorial would show a state machine embedded in a state machine to handle delays indented to the ones you just replaced.
Having belatedly noticed the author's pdf, which includes all the necessary diagrams, I'm deleting this and the subsequent redundant posts with the diagrams I was making.
And so having belatedly noticed jbellavance's pdf (containing code, narrative and state diagrams) and having looked at it (admittedly quickly), I'm inclined to suggest it as "the" tutorial. Maybe Robin2, it's not necessary for you to do another one?
