Hello all,
For my first project I succesfully made a motion detector using Motion PIR and MEGA 2560. I would like to add a second sensor to the same unit (Sonar), so I can have the microcontroller notify the Pi that whatever it is detecting is really close (since I believe the max range for Sonar is 3 feet).
I only have one 5V supply. Is my only option to cut the wire and piggy back off the same pin? I'm sorry for the lack of correct terminology as I just started learning last week. Also, is it even possible to have two sensors on a single core microcontroller since we can't multithread?
Yes you can have multiple sensors.
You can scan them one at a time, very fast ;).
You can write a ‘state machine’ and change your code execution as needed.
The first image has a 2nd connector piggybacked/soldered onto the first.
Plugging this assembly into your Arduino header now gives 2 female pins for each header pin.
You could solder a third connector on the opposite side which would give 3 female pins for every header pin.
The second image should be self explanatory.
The third image shows an IDC connector with a wire zigzagging through all pins, therefore one input pin becomes 10.
Depending on the sensors, your assumption on programming would be correct.
larryd:
Thank you. I've taken your advice and sort of did #1 (it works). I just find it hard to believe that more people don't have this problem, and there aren't more adapters/devices to resolve this issue.
Here is where the 5V is available on the dual row header of the Mega. The 2 terminals at the other end of the header are ground. Also, there is a 5V and ground available on the ICSP connector.
