New using Arduino, checking Map sensor
Hi there! i'd like to know how to test it a GM Map sensor 12223861 i got with arduino.
I tried this and works:
but i'd like to convert values (i dont know what values is showing..right now is showing 214/216), i was wondering how to convert these value to Kpa and Psi if possible.
here some info about sensor.
Thanks in advance!.
If your Arduino is 5volt, the analog reading you have corresponds to 5 * 214 / 1024 volts which is just over 1 volt. There is a formula in the table you supplied to convert volts to pressure units.
thanks! do you can help me out to make the code please? Thanks again!
Maybe like this assuming the sensor is connected to A0:
float pressure = ( analogRead( A0 ) * 5.0 / ( 1024.0 * 0.0162 ) ) + 0.0179 ;
Serial.println( pressure) ;
Thank you a lot!!!!! i will learn more about this. Thanks!
