When you write sketches, always write them in a non-blocking fashion.
i.e. we never use delay( ) as it stops normal program execution for the delay period.
When delay( ) is used the sketch becomes unresponsive and appears to stutter.
Suggest you not use while( ) either unless you are sure it will quickly execute.
This sketch uses the millis( ) / micros( ) functions to create non-blocking delays or TIMERs.
We call this technique Blink Without Delay.
This sketch goes one step further, we create a structure makeTIMER to automate TIMER creation.
A structure or a class is used to define a object.
Objects contain built-in variables and functions.
We will not cover writing of a structure or class, however, we will use them to create TIMERs for our sketches.
In this sketch we can define all the TIMERs we need as seen in the example below.
Below we make a TIMER called heartbeatTIMER.
- It times in milliseconds
- It expires in 500ms
- At power up time it is ENABLED
- It will reset and run again and again.
makeTIMER heartbeatTIMER =
MILLIS, 0, 500ul, ENABLED, YES //.TimerType, .Time, .Interval, .TimerFlag, .Restart
- We have access to several TIMER functions.
In our makeTIMER structure, where XXX is the name of our TIMER, we can use:
XXX.checkTIMER(); Checks to see if the TIMER has expired
XXX.enableRestartTIMER(); Enables and restarts our TIMER
XXX.disableTIMER(); Disables our TIMER
XXX.expireTimer(); Makes our TIMER expire before it should
XXX.setInterval(????); Allows us to set a new TIMER interval
- See the code section below.
- Here we ask the question “has this TIMER expired”.
- If it has expired, we toggle the heartbeat LED, then continue to execute our code.
- When the TIMER does expire, the TIMER automatically restarts as that’s the way we defined it to operate.
Hence the operation repeats again and again.
- If the TIMER has not expired, we do not toggle the LED.
//======================================================================== T I M E R heartbeatLED
//is it time to toggle the heartbeat LED ?
if (heartbeatTIMER.checkTIMER() == EXPIRED)
//toggle the heartbeat LED
digitalWrite(heartbeatLED, digitalRead(heartbeatLED) == HIGH ? LOW : HIGH);
In the sketch below, modify the heartbeat TIMER definition so the heartbeat LED toggles every 1 second.
Does the heartbeat LED now toggle every 1 second ?
As we progress, ask questions about things you do not understand.
// S u r f C o m p e t i t i o n T i m e r
// https://forum.arduino.cc/t/newbie-building-a-surf-comp-timer-does-my-code-look-ok/1358758/1
// Name
// Version YY/MM/DD Comments
// 1.00 25/03/01 Running code
// For wiring connections, see the T i m e r S u r f S c h e m a t i c
// Sketch Notes:
// Surf Competition Timer
// - 2 rotary switches control the timer function (off/Run/Pause) and (timer set 20,25,30,35,40 minutes)
// - when timer starts, hooter sounds for 3 seconds, green light ON and timer counts down (no delays)
// - when timer reaches 5 minute mark - Green light OFF and Amber light ON
// - when timer reaches 0 - amber light OFF, red light ON, hooter sounds (high 3 seconds, low 1 second, high 3 Seconds, Low)
// - when timer reaches 0 a 30 second reset time starts ( time frame between Heats)
// a 30 second countdown is seen on the TM1637
// - when 30 second reset timer reaches 0, red light OFF, the main timer restarts - hooter, green light etc.
// - once timers starts the selected time can not change unless timer is turned Off/Reset.
// - if pause is selected - count down time paused, hooter sounds twice and red light on.
// - if un paused, timer resumes from current state, red light goes OFF, hooter sounds for 3 seconds
#include <TM1637Display.h>
//TM1637 Notes:
//reference: https://github.com/avishorp/TM1637/blob/master/TM1637Display.h
// showNumberDecEx(int num, uint8_t dots = 0, bool leading_zero = false, uint8_t length = 4, uint8_t pos = 0);
#define colon 0b01000000
#define LEDon HIGH //PIN---[220R]---A[LED]K---GND
#define LEDoff LOW
#define PRESSED LOW //+5V---[Internal 50k]---PIN---[Switch]---GND
#define RELEASED HIGH
#define CLOSED LOW //+5V---[Internal 50k]---PIN---[Switch]---GND
#define OPENED HIGH
#define relayON HIGH
#define relayOFF LOW
#define ENABLED true
#define DISABLED false
#define MAXIMUM 180
#define MINIMUM 0
// millis() / micros() B a s e d T I M E R S
//To keep the sketch tidy, you can put this structure in a different tab in the IDE
//These TIMER objects are non-blocking
struct makeTIMER
#define MILLIS 0
#define MICROS 1
#define YES true
#define NO false
#define STILLtiming 0
#define EXPIRED 1
#define TIMERdisabled 2
//these are the bare minimum "members" needed when defining a TIMER
byte TimerType; //what kind of TIMER is this? MILLIS/MICROS
unsigned long Time; //when the TIMER started
unsigned long Interval; //delay time which we are looking for
bool TimerFlag; //is the TIMER enabled ? ENABLED/DISABLED
bool Restart; //do we restart this TIMER ? YES/NO
//condition returned: STILLtiming (0), EXPIRED (1) or TIMERdisabled (2)
//function to check the state of our TIMER ex: if(myTimer.checkTIMER() == EXPIRED);
byte checkTIMER()
//is this TIMER enabled ?
if (TimerFlag == ENABLED)
//has this TIMER expired ?
if (getTime() - Time >= Interval)
//should this TIMER restart again?
if (Restart == YES)
//restart this TIMER
Time = getTime();
//this TIMER has expired
return EXPIRED;
//this TIMER has not expired
return STILLtiming;
} //END of if (TimerFlag == ENABLED)
//this TIMER is disabled
return TIMERdisabled;
} //END of checkTime()
//function to enable and restart this TIMER ex: myTimer.enableRestartTIMER();
void enableRestartTIMER()
TimerFlag = ENABLED;
Time = getTime();
} //END of enableRestartTIMER()
//function to disable this TIMER ex: myTimer.disableTIMER();
void disableTIMER()
TimerFlag = DISABLED;
} //END of disableTIMER()
//function to restart this TIMER ex: myTimer.restartTIMER();
void restartTIMER()
Time = getTime();
} //END of restartTIMER()
//function to force this TIMER to expire ex: myTimer.expireTimer();
void expireTimer()
//force this TIMER to expire
Time = getTime() - Interval;
} //END of expireTimer()
//function to set the Interval for this TIMER ex: myTimer.setInterval(100);
void setInterval(unsigned long value)
//set the Interval
Interval = value;
} //END of setInterval()
//function to return the current time
unsigned long getTime()
//return the time i.e. millis() or micros()
if (TimerType == MILLIS)
return millis();
return micros();
} //END of getTime()
}; //END of struct makeTIMER
// D e f i n e a l l o u r T I M E R S
/*example
makeTIMER toggleLED =
MILLIS/MICROS, 0, 500ul, ENABLED/DISABLED, YES/NO //.TimerType, .Time, .Interval, .TimerFlag, .Restart
TIMER functions we can access:
toggleLED.checkTIMER();
toggleLED.enableRestartTIMER();
toggleLED.disableTIMER();
toggleLED.expireTimer();
toggleLED.setInterval(100ul);
makeTIMER switchesTIMER =
MILLIS, 0, 50ul, ENABLED, YES //.TimerType, .Time, .Interval, .TimerFlag, .Restart
makeTIMER machineTIMER =
MICROS, 0, 1000ul, ENABLED, YES //.TimerType, .Time, .Interval, .TimerFlag, .Restart
makeTIMER countDownTIMER =
MILLIS, 0, 1000ul, DISABLED, YES //.TimerType, .Time, .Interval, .TimerFlag, .Restart
makeTIMER hooterTIMER =
makeTIMER heatTIMER =
// S t a t e M a c h i n e s
//states in our countdown machine
enum STATES : byte
POWERUP, RESET, START, RUNNING, RESTARTtiming, HOOTERsequence, WAITING, PAUSED, FINISHED
STATES mState = POWERUP; //mState is machine state
//states in our hooter sequence machine
enum {sequenceStart = 0, sequence1, sequence2, sequence3, sequence4, sequenceTiming};
byte sequenceState = 0;
byte lastSequenceState = 0;
// G P I O s A n d V a r i a b l e s
//GPIOs
//5 position switch
const byte switch1 = 2;
const byte switch2 = 3;
const byte switch3 = 4;
const byte switch4 = 5;
const byte switch5 = 6;
//TM1637 display module
const byte CLK_PIN = 7;
const byte DIO_PIN = 8;
//relays
const byte RedLight = 9;
const byte AmberLight = 10;
const byte GreenLight = 11;
const byte Hooter = 12;
const byte heartbeatLED = 13;
//3 position switch
const byte RESET_PIN = 14; //A0
const byte START_PIN = 15; //A1
const byte PAUSE_PIN = 16; //A2
//create display object
TM1637Display display(CLK_PIN, DIO_PIN);
//VARIABLES
bool restartFlag = DISABLED; //when ENABLED, the next "Heat" will start in 30 seconds
//const byte Time1 = 20 * 60; //seconds
const unsigned int Time1 = 40; //40 seconds for testing <---------------<<<<<<
const unsigned int Time2 = 25 * 60; //seconds
const unsigned int Time3 = 30 * 60; //seconds
const unsigned int Time4 = 35 * 60; //seconds
const unsigned int Time5 = 40 * 60; //seconds
unsigned int timeSelected;
byte lastSwitch1 = OPENED;
byte lastSwitch2 = OPENED;
byte lastSwitch3 = OPENED;
byte lastSwitch4 = OPENED;
byte lastSwitch5 = OPENED;
byte lastRESET_PIN = OPENED;
byte lastSTART_PIN = OPENED;
byte lastPAUSE_PIN = OPENED;
//timing stuff
const unsigned int GreenOffTime = 5 * 60; //seconds
const unsigned int nextHeatTime = 30; //seconds
const unsigned int hooterOnTime = 3 * 1000; //3000 milliseconds
unsigned int heatRestartCounter;
unsigned int heatCounter ;
// s e t u p ( )
//wait for the serial
while (!Serial);
//internal pull-ups are turned on
pinMode(switch1, INPUT_PULLUP);
pinMode(switch2, INPUT_PULLUP);
pinMode(switch3, INPUT_PULLUP);
pinMode(switch4, INPUT_PULLUP);
pinMode(switch5, INPUT_PULLUP);
pinMode(RESET_PIN, INPUT_PULLUP);
pinMode(START_PIN, INPUT_PULLUP);
pinMode(PAUSE_PIN, INPUT_PULLUP);
//relays are off at power up time
digitalWrite(RedLight, relayOFF);
pinMode(RedLight, OUTPUT);
digitalWrite(AmberLight, relayOFF);
pinMode(AmberLight, OUTPUT);
digitalWrite(GreenLight, relayOFF);
pinMode(GreenLight, OUTPUT);
digitalWrite(Hooter, relayOFF);
pinMode(Hooter, OUTPUT);
digitalWrite(heartbeatLED, LEDoff);
pinMode(heartbeatLED, OUTPUT);
display.setBrightness(7); //display brightness (0-7)
display.clear();
updateTM1637(0);
} //END of setup()
// l o o p ( )
//======================================================================== T I M E R switches
//is it time to check our switches ?
if (switchesTIMER.checkTIMER() == EXPIRED)
checkSwitches();
//======================================================================== T I M E R machine
//is it time to service our State Machine ?
if (machineTIMER.checkTIMER() == EXPIRED)
checkMachine();
//other non blocking code goes here
} //END of loop()
// c h e c k M a c h i n e ( )
void checkMachine()
} //END of checkMachine()
// c h e c k S w i t c h e s ( )
void checkSwitches()
} //END of checkSwitches()
// u p d a t e T M 1 6 3 7 ( )
void updateTM1637(unsigned int counter)
unsigned int minutes = counter / 60;
unsigned int seconds = counter % 60;
unsigned int num = minutes * 100 + seconds;
//update TM1637
// num, dots, leading 0s, digits, LSD position
display.showNumberDecEx(num, colon, true, 4, 0);
} //END of updateTM1637()
